WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
Looking to replace 2005 Sienna with SUV
by i6pwr
06/23/18 07:26 PM
Trying to fix chainsaw
by turtlevette
06/23/18 06:48 PM
tire rotation
by marine65
06/23/18 06:48 PM
Reese hitch $30 Walmart YMMV
by pda1122
06/23/18 06:14 PM
Managing Anger During Unexpected Tire Change
by TheLawnRanger
06/23/18 06:14 PM
2016 Honda Pilot appears to be consuming oil
by pilot1226
06/23/18 06:00 PM
New belt squeal cause damage to belt?
by pda1122
06/23/18 05:33 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
25 registered (555, Chris B., CapriRacer, 1998CamryCE, 5 invisible), 796 Guests and 35 Spiders online.
65303 Members
67 Forums
285888 Topics
#4619110 - 12/30/17 07:10 PM Champ PH820 011514ES1 cut & post #1
WellOiled Offline
Loc: Houston, Texas
If nothing is eventful, I usually do not make a cut & post but, someone wanted to see some recent eCore cut and posts. Since these had not been recycled yet, it was easy. smile
Enjoy!!! smile
Oil change date: 07/29/2017
Miles on vehicle: 176428
Miles in service: 3046
Days in service: 56
Oil: Motorcraft Premium Synthetic Blend 5W30
Filter: Champ PH820
Champ Labs PH820
Date code: 011514ES1 08:34 --> January 15, 2014 08:34am
Combo valve was pliable. No issues noted.
Base plate interior. All the holes were smooth and did not cut the ADBV/Combo Valve.
Base plate exterior.
Leaf spring.
Combo valve, element end view.
Leaf spring end. Easy way to check the pleat spacing.
Combo valve end. Easy way to check the pleat spacing.
The seam was easy to spot on this one. Sometimes they can be hard to spot because Champ Labs turns the cut ends toward the core.
Element view #1
Element view #2
Element view #3
The end caps can be removed but takes maybe 90 seconds per end. Then you can do a visual inspection for metal fines and in this case,
I observed some small bits of carbon. The PH820 has 56 pleats counting the seam.
More carbon.
More carbon.
Old style cage with 4 sectors and 4 windows.
I have run eCores to 6K without issues. This run was short for cleanup purposes.
2004 Ford Ranger 4.0L V6
NAPA Full Synthetic 5W30 + Fram Tough Guard
#4619160 - 12/30/17 07:56 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: WellOiled]
BigD1 Offline
Loc: NC
Yes that's the old style cage.
Looks fine to me. I have run a few of the new cage design ecores, and they all look fine when I cut them open. Still prefer the ACDelco Classic though.
Thanks for the pictures!
1992 Toyota Pickup--Havoline HM 10W-30--Motorcraft FL-910S
#4619164 - 12/30/17 08:05 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: WellOiled]
ZeeOSix Offline
Loc: PNW
Nice C&P ... thanks! Engine looks to be pretty clean since there wasn't much carbon or other debris found in the filter.
#4619167 - 12/30/17 08:16 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: ZeeOSix]
WellOiled Offline
Loc: Houston, Texas
When I get to the AC Delco PF1250, you will see quite a bit more carbon. Likely it is time to lengthen these changes out. The truck was short tripped a lot more than I thought before I took possession of it.
Those 3 cam chains seem to shear the oil down quickly. I am thinking this may relate to why I am hearing startup rattle about 2500 miles into a change.
And, you are welcome.
#4619169 - 12/30/17 08:16 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: BigD1]
WellOiled Offline
Loc: Houston, Texas
BigD1, you are welcome.
#4619232 - 12/30/17 09:28 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: WellOiled]
car51 Offline
Loc: Southwest PA
Filter looks good. Thanks for c&p smile
2009 Toyota Camry LE
#4619239 - 12/30/17 09:45 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: car51]
WellOiled Offline
Loc: Houston, Texas
Car51 - you are welcome.
#4619400 - 12/31/17 05:44 AM Re: Champ PH820 011514ES1 cut & post #1 [Re: WellOiled]
Sayjac Offline
Loc: The Old North State
Looks fine. I'm still not enamored with the with the "combo valve" concept/design, but at the topic ~3k miles fci should be ok. If I used them, because of the combo valve I wouldn't go beyond ~5k miles/6months.
Thanks for c&p.
#4619739 - 12/31/17 02:00 PM Re: Champ PH820 011514ES1 cut & post #1 [Re: Sayjac]
WellOiled Offline
Loc: Houston, Texas
Thanks for c&p.
Agreed. The Champ PH820 uses nitrile for the combo valve. At roughly 2500 miles the engine would startup with rattle. Oddly I have had filters with silicone ADBV do the same. The oilís viscosity may have something to do with it. The element paper is cellulose thus the 6 month / 5000 mile limit. For $1.50 each, they were not bad for cleanup purposes.
