Pennzoil Platinum 5w30 at walmart.com
by Irishman. 12/16/18 11:08 AM
pcv cleaning
by macdole99. 12/16/18 10:39 AM
Solar lights that last all night
by Snagglefoot. 12/16/18 09:20 AM
Things Santa might say......
by ZZman. 12/16/18 08:24 AM
ULTRA-POWER 57082
by ET16. 12/16/18 06:56 AM
No collision totaled vehicle
by madRiver. 12/16/18 06:32 AM
Brightest backup light for my daughters car?
by BobsArmory. 12/16/18 06:26 AM
M1 0W20 EP Good To At Least 10K Miles ?
by ChrisD46. 12/16/18 03:29 AM
Gift for young Army Cadet
by Snagglefoot. 12/16/18 12:33 AM
Instacart Grocery Delivery
by dogememe. 12/16/18 12:26 AM
My brother bought this...
by miden851. 12/15/18 09:12 PM
Watch out for scammers
by Chris142. 12/15/18 08:45 PM
15K OCI R53 2006 Mini Cooper S 144k
by dx92beater. 12/15/18 08:32 PM
Beneficial clean fuel.injectors in Ultrasonic Cleaner
by JLawrence08648. 12/15/18 06:54 PM
Cpcz9382, PPWarrior, Robwashere4oil, saleen367, Rickeagle
66696 Registered Users
85 registered members (amblerman, 69GTX, anndel, Audios, 94astro, 10 invisible), 2,189 guests, and 38 spiders.
Topics295,145
Posts4,928,685
Members66,696
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
Hopefully my last thread: HEEELLLP! #4618913
12/30/17 03:29 PM
12/30/17 03:29 PM
Virginia
Hemispheres Offline OP
Virginia
So um. I may have to pull a head. Hoping to get advice from you all. If youíre familiar with me youíll know Iíve had issue after issue with exhaust. First EGR, The crossover that took ages to seal. Once that was fixed I still heard leaks and found one by cylinder 6, EGR had sprung a leak again and the downpipe flange gasket.
Got that all done and was so fed up after 2-3 weeks of being out under the hood til 3am 5 days out of the week I grabbed the biggest ratchet I could find and wrenched them [censored] down.
A few days later I snapped a stud after losing all common sense due to sleep deprivation, frustration and arguably hunger.
Spent close to 7 hours pulling it out with an extractor followed by a hammered on 1/4 in socket and an Allen wrench. Started out plugging exhaust ports but rags kept falling out so I said [censored] it. Have spent most of today using magnets, air and my fingers pulling out fine particles. Anything from dust sized which I couldnít feel between my fingers, to dirt sized which felt no different than some particles I get in the bottom of my oil catch pan, and the largest bring a few human hairs thick - 1/8 inch long.
This on the number 2 cylinder which appears to be closed.
I found more in Cylinder 4 which is a good 4-6 inches away from #2 but the bad news is that most likely means itís open partially if not fully. To make matters worse the brass tubing is on the compressor is snapped from getting hot and making contact with a solid object. (Iím obviously a bit heavy handed). So Iíve been using keyboard cleaner on the #2 cylinder, thankfully havenít blasted #4 yet.
Soooooo...... big question is how likely is Iíll need to pull the head given the size of the particles? =\
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4618924
12/30/17 03:40 PM
12/30/17 03:40 PM
Virginia
Virginia
Might be my lucky day. This is #4
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4618939
12/30/17 03:53 PM
12/30/17 03:53 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Blow it out with an air gun then pull the plug on any cylinder with a valve open and blow it out with the gun before cranking the engine. It will be okay.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4618983
12/30/17 04:26 PM
12/30/17 04:26 PM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Why didn't you just tape over the hole with painters tape?
2015 Civic LX Coupe
Re: Hopefully my last thread: HEEELLLP! [Re: Trav] #4618989
12/30/17 04:29 PM
12/30/17 04:29 PM
Virginia
Virginia
Ty Sir.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4619032
12/30/17 05:20 PM
12/30/17 05:20 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
You're thinking in reverse.
Blowing is not the answer here.
Sucking is your answer.
I'd attach a small hose to a shop vac and suck all that out.
Re: Hopefully my last thread: HEEELLLP! [Re: Trav] #4619034
12/30/17 05:22 PM
12/30/17 05:22 PM
Maryland
HDoc Offline
HDoc  Offline
Maryland
This. Think positive. Cheers2
1998 Ranger (170k)RP/MC
2001 Outback (95k)ST/Wix
2005 Liberty (57k)ST/Wix
2008 Sienna (235k)ST/Wix(made in Poland)
2011 Avenger (94k)ST/Wix
All 5w30
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4619064
12/30/17 06:03 PM
12/30/17 06:03 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Take out the spark plug and crank it over a few seconds.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4619236
12/30/17 09:42 PM
12/30/17 09:42 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
So these are bits of the stud? If so, they are steel and will be picked up with a magnet. Get your telescoping magnet and run all around in there and you'll get most smile
Vacuum is good too. I would not pull the head. Just reassemble and light the kitty laugh
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4619807
12/31/17 02:49 PM
12/31/17 02:49 PM
Virginia
Virginia
Yes theyíre off the stud. Mostly filings but possibly some larger pieces from using the fluted extractor and hammering on the socket. Iím opting for the vacuum method simply because I have no way telling which valves are open or closed without pulling the valve cover or renting a borescope. Compressed air runs the risk of blowing the stuff into the intake. I doubt the air in can I was using had enough pressure to blow anything much farther past the valve.
Cylinder 2 looks closed but 4 and 6 are sitting lower according to my fingers of I stick em in the port. Just gonna pull the spark plugs and take my time using plastic hose affixed to the end of the vac hose to clean each rear cylinder and exhaust port out.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4619939
12/31/17 05:08 PM
12/31/17 05:08 PM
Virginia
Virginia
Quick update. All 3 rear valves are open. Pulled the #2 spark plug and found penetrating oil on it, along with the valve being clear of ash deposits. I first used PB Blasted then moved to a mix of mineral spirits and ATF. If itís on the plug then the penetrating oil moved past an open valves and is probably on the top of the pistons and areas of cylinder wall closest to the exhaust valve. Unless I can find a way to seal off the intake and exhaust ports for each cylinder to apply vacuum Iím cleaning Iím seeing no option but to pull the head.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4620005
12/31/17 06:12 PM
12/31/17 06:12 PM
Trav Offline
Trav  Offline
You cant have the intake and exhaust open at the same time. If the particles got into the cylinder through the open exhaust valve there is no way it can get in the intake unless you turned the engine over which is a no no.
100-120 psi down the plug hole with a open exhaust valve will blow the garbage out, if you didnt disturb the engine then just use some brake cleaner to clean the oil off then blow it out.
Vacuum through such a small pipe isn't going to get into all the places, you could hold the sshop vac hose on the exhaust por and blow air down the plug hole. Air in a can isn't cutting it.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4620012
12/31/17 06:21 PM
12/31/17 06:21 PM
Virginia
Virginia
I understand that but there is a small overlap during the intake stroke in which both valves are open and Iím also running high lift rockers which exaggerates things quite a bit.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4620056
12/31/17 07:04 PM
12/31/17 07:04 PM
Trav Offline
Trav  Offline
The way I understood it the exhaust valve was open. Try a long flexible magnet as someone suggested.
Re: Hopefully my last thread: HEEELLLP! [Re: Hemispheres] #4620062
12/31/17 07:13 PM
12/31/17 07:13 PM
Virginia
Virginia
It is open and I grabbed a flexible magnet from Loweís today, however the valve is not open enough to insert anything into the engine from the exhaust port. Iíve calculated .464 lift on the exhaust maximum but I can even see into the cylinder around the valve. Even with magnets, air, and vacuum I donít feel confident that all debris can be removed without pulling the head. I can do it myself for about $150 for gaskets and bolts. Made sure to buy shop rags and spray a gasket as well.
Page 1 of 3 1 2 3
