Classic road brake pads
by buck91. 09/23/18 06:18 PM
Air up your vehicle's tires
by Papa Bear. 09/23/18 06:07 PM
A cool litttle Fall foliage site
by Papa Bear. 09/23/18 06:02 PM
Suggestion: "Likes"
by SnowDrifter. 09/23/18 05:36 PM
Condensation in headlights?
by irv. 09/23/18 05:06 PM
Nissan VQ V-6 Engines
by Al. 09/23/18 04:57 PM
List of dexos licensed oils?
by k1xv. 09/23/18 04:24 PM
High flow oil pump? Thinner oil?
by SnowDrifter. 09/23/18 04:06 PM
Is Tiger back?
by gman2304. 09/23/18 03:51 PM
Castrol Edge Pro OE LLIV FE 0W20 for VW508
by BrandonT. 09/23/18 03:33 PM
Value of 90's stereo equipment
by wrcsixeight. 09/23/18 03:28 PM
Wisdom of BITOG'ers wanted- 19 Avalon Hybrid oil
by scion_xb. 09/23/18 02:36 PM
w116 300sd Mercedes Diesel HPR fuel
by Gito. 09/23/18 02:14 PM
Power Stop Wheel Bearing/Hubs?
by oilpsi2high. 09/23/18 01:37 PM
Dump the 30k ATF in the 17 Kia?
by 3Aone. 09/23/18 01:31 PM
Miata Aisin 6 speed question
by 10ecfarmer. 09/23/18 12:36 PM
Shortest time you owned a car?
by Corollaman. 09/23/18 12:21 PM
Winter tires pinned for studs, but without studs
by Corollaman. 09/23/18 12:12 PM
03 Accord V6 "needs" iridium plugs?
by columnshift. 09/23/18 11:40 AM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
114 registered members (02z, Astro14, Ablebody, 2010Civic, anndel, 13 invisible), 1,686 guests, and 42 spiders.
Topics290,904
Posts4,852,218
Members66,047
Most Online3,590
Jan 24th, 2017
Pentofrost A2 Q #4618651
12/30/17 11:08 AM
12/30/17 11:08 AM
upstate new york
foresthawk Offline OP
upstate new york
I want to put some coolant in the overflow tank on a 2007 Subaru Outback. I look around for what coolant is OK to use, and find Pentofrost A2 can be used for this car make and year, according to their website. Then I see on the container it says not to use with other coolants. The coolant in the radiator is "green" in color, but I don't know what it is. Would you use this stuff to "top up?" If not, what coolant? I'm inclined to just use it, of course at 50/50 but want to hear other views. Thank you very much.
Re: Pentofrost A2 Q [Re: foresthawk] #4618756
12/30/17 12:31 PM
12/30/17 12:31 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I labor under the allusion that Subarus are the most unforgiving when it comes to coolant.
Mess this up and she'll leak.
I'd take my 10 year old Subaru to a dealer and ask if the coolant (green, you say?) looked correct.
If the coolant is supposed to be pale blue (my suspicion) I'd drain and refill with genuine Subaru or have it done.
I say all of this out of fear of creating another leaky Subaru engine. I've seen 'em.
AS ALWAYS: The Pentofrost product might be chemically perfect but why spend time verifying it? Just go with what you know works.
In your case the mystery you should solve is learning what's in there now.
Re: Pentofrost A2 Q [Re: foresthawk] #4618776
12/30/17 12:50 PM
12/30/17 12:50 PM
TX
mooferz Offline
mooferz  Offline
TX
Subaru uses your typical Asian PHOAT coolant, which comes tinted in a variety of colors. That Pentofrost will be formulated virtually identically to the Subaru coolant.
As a less expensive alternative, I'd opt for the Recochem green from Pep Boys- ~$18 delivered via ebay or $15 instore pickup.
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
Re: Pentofrost A2 Q [Re: foresthawk] #4618937
12/30/17 04:52 PM
12/30/17 04:52 PM
NJ
Padawan Offline
Padawan  Offline
NJ
The OEM Subaru coolant for your model year is green, so if it's been serviced at the dealer, that's almost certainly what's in there.
You'll have no issues using the Pentofrost A2 to top off the overflow. It's the coolant I always suggest as an alternative to OEM, and what I use in our '06 Saab 9-2x (rebadged WRX).
Re: Pentofrost A2 Q [Re: Padawan] #4619314
12/31/17 01:15 AM
12/31/17 01:15 AM
North of you Idaho
KneeGrinder Offline
KneeGrinder  Offline
North of you Idaho
^THIS, chemically the same. I always suggest it as the highest quality OEM replacement coolant. Its in my Subaru, Honda's and Acura.
08 Tribeca 82k PUP 5w30 wix
06 Accord Hybrid 131k PUP 5w20 wix
02 Chevy k3500 97k Delvac 1 esp 5w40 wix
00 F350 133k Delvac 1300 15w40 wix
