Ford 4.6L Durability?
by Auae85
06/20/18 11:00 PM
Mercedes Benz High Mileage Badges
by Snagglefoot
06/20/18 10:46 PM
Lawn Tractor Tire Sealer
by 97K15004WD
06/20/18 10:01 PM
Fireworks Stores
by Warstud
06/20/18 09:36 PM
1994 Ranger fuel tank/frame cleanup & NOS part
by 01rangerxl
06/20/18 09:27 PM
Koreans top J.D. Power qlty; Ford, GM, FCA make strides
by wemay
06/20/18 09:18 PM
How Fast to Run a ZeroTurn Mower
by Gebo
06/20/18 09:10 PM
Bosch 3300 C&P Yamaha FZ-07
by bmwpowere36m3
06/20/18 08:49 PM
My FIL in hospice
by fdcg27
06/20/18 08:41 PM
Spraying Polyurethane
by Texican
06/20/18 08:37 PM
Dehumidifier icing
by Kestas
06/20/18 08:37 PM
Diesel lube in Petrol Engine
by Ducked
06/20/18 07:46 PM
New key programming cost
by 92saturnsl2
06/20/18 07:27 PM
When you help someone and its time to walk away
by RazorsEdge
06/20/18 07:09 PM
Sightly overfilled oil..ok or drain?
by flinter
06/20/18 07:08 PM
Wheel says 50 mph max
by pda1122
06/20/18 06:54 PM
15w40 Maxlife in Motorcycle
by Brian553
06/20/18 06:39 PM
BITOGer in Ottawa/Orleans Canada area ? ...
by Papa Bear
06/20/18 06:36 PM
Old Engine SOUND
by MasterSolenoid
06/20/18 06:06 PM
ProMotive PH 2500 CUT OPEN
by car51
06/20/18 04:54 PM
yamahaboy125, Turboholic, TrpNY, bcj, Ilia
65282 Registered Users
35 registered (bbhero, BusyLittleShop, carviewsonic, clinebarger, Charlie2015, 2 invisible), 994 Guests and 37 Spiders online.
65282 Members
67 Forums
285682 Topics
Page 1 of 2 1 2 >
#4618487 - 12/30/17 05:59 AM Bullet keyholed
clarkflower Offline
Loc: US
I just got a new seecamp. I bought 1 box of Buffalo Bore BUFFALO-BARNES .32 ACP +P LEAD FREE ( I didn't want to own more if they didn't cycle)
Shot all but 7 and they worked flawlessly and accurately
After looking at my target I see the Buffalo Bore BUFFALO-BARNES .32 ACP +P LEAD FR keyholed for sure (The rounds to the right of the head)
Any thoughts...stop using?
Edited by clarkflower (12/30/17 06:00 AM)
#4618490 - 12/30/17 06:11 AM Re: Bullet keyholed [Re: clarkflower]
JohnnyJohnson Online   content
Loc: Wet side WA
Non lead bullets are longer than lead bullets they take more twist to stabilize. I've seen this same problem in non lead bullets in 20 caliber and 22 caliber.
2004 Toyota Corolla 121682
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4618498 - 12/30/17 06:31 AM Re: Bullet keyholed [Re: JohnnyJohnson]
clarkflower Offline
Loc: US
This may be stupid but what are the issues. The range just let me run in and shoot 13 quick to see if they cycled. That was 15 feet on a target someone left.
Barnes claims 950 FPS vs many 770 FPS from stock rounds. Seems to me you would lose velocity. Less penetration. No expansion or none.. Correct?
#4618506 - 12/30/17 06:58 AM Re: Bullet keyholed [Re: JohnnyJohnson]
billt460 Offline
Loc: Glendale, Arizona
This is true, and is the main reason so many guns have difficulty shooting Barnes solid copper bullets with any degree of accuracy. Copper does not have the density of lead. Because of that most every solid copper bullet has to be made longer to achieve the same weight as a standard lead core, copper jacketed projectile. In many cases this requires a higher twist rate to stabilize it. In a rifle caliber like .223 this isn't as big of an issue, because there are a ton of AR platform weapons out there with 1 in 7" twist barrels. While some bolt action sporters in .223 used mostly for varmint hunting can have twist rates as high as 1 in 12" twist.
Varmint hunters using centerfire .223's like light weight, thin jacketed explosive bullets, driven at very high velocities. These type of bullets will disintegrate in flight, if they are driven too fast and over rotated in a high twist rate barrel. By the same token if you like and want to shoot homogenous solid copper bullets, you want the highest twist rate possible, or you will have accuracy issues. Keyholing among them. The biggest issue with handguns is the twist rate is pretty much standard for the caliber of weapon, regardless of the manufacturer. All of this is not a fault of Barnes lack of quality. Their bullets are some of the highest quality out there. But rather the result of physics.
#4618515 - 12/30/17 07:10 AM Re: Bullet keyholed [Re: clarkflower]
demarpaint Offline
Loc: NY
It sounds like the barrel twist isn't right for those bullets. You'll have to select another bullet.
God Bless Our Troops
#4618534 - 12/30/17 07:50 AM Re: Bullet keyholed [Re: clarkflower]
Al Offline
Loc: Elizabethtown, Pa
Just curious. Why would someone to a non lead bullet. I appreciatr the philosophical environmental impact. So if its like "I want to help preserve the earth"..I get that.
BTW I am not trying to start an argument.
#4618544 - 12/30/17 08:04 AM Re: Bullet keyholed [Re: Al]
MolaKule Offline
Loc: Iowegia - USA
I had the same question Al. Both are metals but with different densities.
Was this just an experiment to see what the bullet type would do?
BTW, I have yet to see a .32 ACP score for any accuracy over 5 meters.
Edited by MolaKule (12/30/17 08:05 AM)
#4618545 - 12/30/17 08:06 AM Re: Bullet keyholed [Re: Al]
clarkflower Offline
Loc: US
Copper had nothing to do with it (for me)
I was looking for a round that would function in my Seecamp, and give the best velocity expansion and penetration.
Most of the commercial rounds give you around 770-850 in the Seecamp 2 inch barrel and don't expand or underpenatrate. That round claims 950ish out of a Seecamp 2 inch barrel.
The Corbon's (similar velocity) are all out of stock everywhere I look. From what I read the 32 ACP 50 Grain Xtreme Cavitator have some feeding/ejecting issues.
I do have bigger caliber guns. I just want the best round for that one and it's fun to test.
#4618549 - 12/30/17 08:13 AM Re: Bullet keyholed [Re: MolaKule]
clarkflower Offline
Loc: US
Originally Posted By: MolaKule
[quote=Al]
At 20 feet I can put all shots in the torso and I can walk around with the gun in my top shirt pocket. It has its place in a very hot climate. That old: The 32 in your pocket is better that the 44 in your dresser. I used to leave my bigger guns at home many times. I don't plan on stopping a bank robbery with it but I can take cover and perhaps make someone retreat rather than advance into fire.
Edited by clarkflower (12/30/17 08:16 AM)
#4618566 - 12/30/17 08:21 AM Re: Bullet keyholed [Re: clarkflower]
AZjeff Offline
Loc: PV Az
You say they were accurate at 15 feet so what's the problem? A tumbling bullet could well have better terminal performance than one behaving normally. This pistol/round is a head scratcher. You mention penetration and expansion so you're going to use it for SD? It's a pretty little thing but for $169 these days you can buy a Ruger LCP that with standard 90g ammo has more energy at 200 fp vs 161 and if you go to the BB lead free .380 almost double the energy at 289 fp. Going back to a non +P .32 you're back to 120-130 fp. Is it about recoil?
Interested to hear your thoughts on choosing the Seacamp.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP *gasp*
16 Silverado 1500 4.3 Ecotec3, DI, AFM 5W-30 PP
Why know when you can guess?!
#4618580 - 12/30/17 08:41 AM Re: Bullet keyholed [Re: AZjeff]
clarkflower Offline
Loc: US
1) Yes SD gun. I agree and thought of the tumbling but I don't know. I thought I asked that above >This may be stupid but what are the issues.
I guess I would have to test velocity for the tumbling barnes and fire it into Gel?
2) I have the smallest 380 and its much bigger than the Seecamp which as I said above easily goes in my top shirt pocket. The 380 will not and paints in my pants pocket. The Seecamp does not. I tend to always have the Seecamp on me when I would leave a bigger gun behind.
3) Not recoil. Most 32's do not expand and the ones that do get 4-6 inches in gel. I love the gun why not find the best round that works?
Edited by clarkflower (12/30/17 08:48 AM)
#4618625 - 12/30/17 09:38 AM Re: Bullet keyholed [Re: AZjeff]
clarkflower Offline
Loc: US
Question on this: If the bullet hits flat what have you got?
Complete unknown?
#4618631 - 12/30/17 09:51 AM Re: Bullet keyholed [Re: clarkflower]
billt460 Offline
ALL bullets are designed and tested to perform with a straight, nose forward delivery. Tumbling bullets are totally unpredictable in both accuracy, as well as performance. If the gun won't deliver it's ammunition properly, something is wrong. Either with the weapon, or the ammunition. And it should be corrected.
#4618632 - 12/30/17 09:51 AM Re: Bullet keyholed [Re: clarkflower]
bigj_16 Offline
Loc: Douglas County, Colorado
I carry a a Kahr CW380 in a Recluse holster(back pocket). One of the smallest .380's. In the Recluse it does not print. Looks like a wallet(I use the extra magazine one, which is squarish). There ARE some pants pockets, where just the top of it sticks out. There are others where it disappears inside. Most fall in between. I can also put it in the front pockets of the most of the button up shirts I own. I understand you may have to wear certain types of clothes for a job, or size, but you can get clothes that work. It is certainly much easier than trying to buy clothes that work for an IWB holster. I also have a front pocket Recluse for the CW380, which I can use in certain situations. Both of those holsters work just fine in MOST left (or right) inside jacket pockets, like the one in Carhartt jackets. I also have a Recluse front pocket holster for the Kahr CT9, which works with some pants and situations, and goes into the inside jacket pocket.
Now admittedly, the CW380 is small. The Ruger LCP is about a quarter inch longer, which doesn't sound like much, but could make a lot of difference in what sticks out. That is one reason I went with the CW380.
https://recluseholster.com/kahr-p380-recluse-square-pocket-holster
Edited by bigj_16 (12/30/17 10:03 AM)
#4618661 - 12/30/17 10:16 AM Re: Bullet keyholed [Re: bigj_16]
clarkflower Offline
Loc: US
Kahr CW380 length of 4.96 inches and a height of 3.9 inches.
Seecamp 32 length of 4.2 inches and a height of 3.2
My 380 is 5.2 and 3.7. Sticky Holster. Many times I leave it at home as I do my Colt 38. Just a personal choice to have something smaller
Edited by clarkflower (12/30/17 10:17 AM)
Page 1 of 2 1 2 >
