B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
108 registered members (AdditiveOCD, Arob, 53' Stude, ABerns, 14 invisible), 2,349 guests, and 42 spiders.
Topics296,878
Posts4,960,699
Members66,987
Most Online2,688
Jan 19th, 2019
1984 jeep 2.5,winter oil #4618124
12/29/17 07:12 PM
12/29/17 07:12 PM
appalachia va
troutfisher Offline OP
appalachia va
Hello,just picked up a 1984 jeep/amc cherokee xj with 2.5 i-4
Runs great,195k on the clock
First thing I did was change the oil,had a driveworks filter on it.Changed it out with a carquest red and 4 quarts of supertech 10w-30 dino,is this a good combo for 15f-30f temps?
Is super tech 10w-30 good for this engine or should I go with a syn blend? Any help would be great
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618127
12/29/17 07:14 PM
12/29/17 07:14 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
ST 10w30 is a good combination for sure.
Is this a toy or a daily driver? Just curious.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: 1984 jeep 2.5,winter oil [Re: dlundblad] #4618137
12/29/17 07:22 PM
12/29/17 07:22 PM
appalachia va
appalachia va
Daily Driver,4x4 is a must where I live
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618147
12/29/17 07:32 PM
12/29/17 07:32 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Our 2.5 runs great on 5W-30 Maxlife.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618153
12/29/17 07:37 PM
12/29/17 07:37 PM
md, usa
dieselfarmboy Offline
md, usa
Use to have one of them. 4x4 never worked due to vacuum lines or axle disconnect or transfer case switch. Never ran good was a [censored] of engine part jeep part ford part who knows what else they used. Good luck.
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618175
12/29/17 07:48 PM
12/29/17 07:48 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
With a 195,000 on it, I'd prolly switch to Maxlife 5W-30 or 10W-40 smile
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618180
12/29/17 07:53 PM
12/29/17 07:53 PM
Phoenix
dishdude Online content
dishdude  Online Content
Phoenix
1984 should be the Pontiac 2.5. I'd say you're good with the ST 10w-30.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618192
12/29/17 08:01 PM
12/29/17 08:01 PM
Crawfordville FL
SilverFusion2010 Offline
Crawfordville FL
10w-30 will be fine. Go to 10-40 if you find the engine needs it
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: 1984 jeep 2.5,winter oil [Re: dishdude] #4618199
12/29/17 08:05 PM
12/29/17 08:05 PM
md, usa
md, usa
Pretty sure it was an AMC engine. They used some ford electronics on it. The carb was a night mare from what I remember. Id be more worried about starting a carbed engine in the cold then what oil is in it. At that mileage if it is true, it has to be TIRED.
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618217
12/29/17 08:16 PM
12/29/17 08:16 PM
appalachia va
appalachia va
This was a old park service jeep,so it had pretty good maintenance,the carb is definitely newer
engine runs perfect even in the coldest temps,gonna stick with the 10w-30 might try mobile super,with a wix for the long term
Re: 1984 jeep 2.5,winter oil [Re: dieselfarmboy] #4618220
12/29/17 08:20 PM
12/29/17 08:20 PM
Phoenix
Phoenix
You're right.
2018 GTI
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618223
12/29/17 08:22 PM
12/29/17 08:22 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Basically the 4.0's little brother then?
I'd run a 10 or 5w40 personally.
Re: 1984 jeep 2.5,winter oil [Re: dieselfarmboy] #4618230
12/29/17 08:30 PM
12/29/17 08:30 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
I ha 2 grand wags with the vacuum switched front ends. All kinds of of horror stories about trying a cable operation, etc. One afternoon, I fixed the problem with 5' of vacuum hose. AMC, in its thriftiness, used a few pieces of steel tubing run hard and tight under the left exhaust maniifold. Thin steel. It rotted out. Routing the replacement hose cable tied to the fender fixed it for good. Cost <5$ The Grand Wag had about 30 feet of vacuum hose under the hood. The potential for leaks was massive as the cars aged.
Thick oil is better grin2
Re: 1984 jeep 2.5,winter oil [Re: andyd] #4618247
12/29/17 08:45 PM
12/29/17 08:45 PM
md, usa
md, usa
If I had to deal with one again id see if I could swap a newer axle under it. My current Grand Cherokees front axle spins all the time and it dont seem to affect fuel mileage that much.
Re: 1984 jeep 2.5,winter oil [Re: troutfisher] #4618304
12/29/17 09:48 PM
12/29/17 09:48 PM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
The 2.5 is tough. Doesn't get a lot of credit because most of the vehicles it was put in needed 30 more horsepower than it could give, but they'll go a long time and I've personally gotten 24 MPG with one in an XJ.
With that many miles, in warmer weather I'd bump up to a HM or syn blend, or 10w40, but 10w30 is one of the best weights for your engine even if it's substantially colder than that.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
