Converting .45 ACP 1911 to .460 Rowland
Dickson, TN.
I'm sure most of y'all have heard of this, but if you haven't, it's a conversion that's available for 1911s, Glocks and Springfield XDs that gives you .44 MAG-like power levels out of a pistol chambered for .45 ACP.
The .460 Rowland cartridges do this by almost doubling the chamber pressure of standard .45 ACP, but the ported or compensated barrel makes it safe to shoot in a standard .45 ACP gun by momentarily delaying the opening of the slide in order to vent the excess gas pressure. Power gains over, say, 10mm Auto, are substantial.
The round overall length is the same length as .45 ACP, though the case is a bit longer.
The compensated barrel also actually reduces muzzle flip when compared to standard .45 ACP. It works very well due to the high pressure of the .460 Rowland round, as evidenced by watching the video of Sootch00 shooting his .460 Rowland-converted Colt vs. a standard .45 ACP 5" barreled handgun:
I've been thinking about getting a conversion kit for my Dan Wesson 1911. It would be $332 plus $25 for a stainless compensator, since my DW is stainless.
Any of y'all done the .460 Rowland conversion?
I use my .45 as my home defense gun. It's fine just the way it is. Maybe if I had multiple .45 pistols I'd consider a conversion but probably not even then. .45 is plenty powerful enough for me.
I guess the concept is lost on me.
I think 10mm is overkill for most any handgun use.
For big game hunting in Montana, I did use to use my Ruger .44 mag, though.
I just never felt like I needed a semi-auto with that power.
I guess it’s similat to owning a powerful automobile. If you have to ask “why?”, then it’s not for you.
And then there are those of us whose immediate reaction is, THAT’S FREAKING AWESOME! I WANT ONE!!
Just do it. Life's too short to worry about it. It's a good conversion if you are comfortable with the increased power. It's really not that big of a deal.
This is the part I'm not getting. Going by the gun in the photo, by the time the bullet reaches the compensator, it would have been out of the barrel on a standard 5" 1911. So where is the "delayed" part coming from? I can't see that system being any less hard on the gun. Especially if it's running over double the chamber pressure of a standard .45 ACP. As fine of a gun as the 1911 is, it's not "Magnumized". Even the .38 Super was hard on it when it first came out.
I remember when Colt first introduced the 10 MM Delta Elite. They had issues with slides cracking on several guns. I don't know what they did to fix it. If in fact they did anything. This was back when the 10 MM first came out, and was loaded hot. Perhaps the problem was self correcting when all the ammo makers started loading down the 10 MM to the anemic levels it now enjoys. Same with the .38 Super. That cartridge is loaded to nowhere near the power levels it was when it came out in the 30's.
I’m not sure, Bill. I also wondered how it is doing it. Maybe the weight? I’ll have to do some more research.
I know the Rowland Company says that 1911s that don’t have heat-treated slides shouldn’t be converted. They also have a list of 1911s they say are good to go. The Dan Wesson is on that list. And a quick search over on the DW section on the 1911 Forum revealed at least one person who’s done it.
I remember about twenty five years ago, I went in my local gun store. The guy that worked there had just got a Grizzly .45 Win Mag in. Now, I am a pretty big, strong guy(and a lot younger back then
). I grabbed a hold of the slide like I would a 1911, and that sucker wouldn't move. I couldn't believe how hard I had to grip it, to rack the slide.
Ever look at the Magnum Research 44 Mag semi auto already built to handle the heavy loads and common ammo readily available in case you don't have the reloads ready when the zombie apocalypse begins.
I almost did this about 15 years ago. I had custom Caspian that already had a slide cut in it for an integral ramped barrel. I bought a Clark .460 barrel and was about to fit it and then tool up to reload for it.
I decided a dedicated .44 Magnum was more suitable for my needs (bear gun), more reliable, and a good excuse to get a beautiful classic S&S .44 mag. So I sold the barrel and stepped away. But those were my needs and as a range gun and for the fun of it, it's a very compelling project.
How available is the ammo?
According to most 1911 .45 Auto people a .45 Auto already has the stopping power of a Howtizer. This ought to really excited them. I d watch for the fine print like not liable for condition of your firearm.
Nice video. Very informative. I had a compensator like that for my Glock 21 which is 45 ACP and it would cause it to jam. Tried it for bowling pin shoots but the jamming was a real problem. It may have been the recoil reduction did not allow the slide to fully blowback. Also a friend had the Glock 20 10mm version and we were able to swap barrels and clips and shoot the other caliber just fine in each others gun.
Originally Posted By: Marco620
Goodnight! I like 45 but apparently that aint enough for you. Dan Coonan makes 1911 in 38 Super,357, and 44mag.
Thing is, .45 ACP is not that powerful! It’s a Low-pressure cartridge. That’s why when you shoot a .45, it’s not that sharp of a recoil. More of a shove...unlike, say, .40 S&W, which has the tendency to be sharp and snappy to many people.
LOL!
Gun shop commandos!
I got a kick out of a dude at Walmart while I was buying ammo. Told the clerk he needed ammo for a “AR-15 assault rifle”. After waiting to see if the clerk knew anything (he didn’t), I piped up. Turned out he had a picture on his phone of the last ammo box he had. It was 7.62 NATO. Ended up being a super-nice guy. Black dude in his 50s who’s a scoutmaster and was planning a shoot for his troop.
I thought you had to swap slides also on order to go from .45 ACP to 10mm Auto and vice-versa on G20 & 21. Because I own the G20 and was thinking it might actually be a better plan to buy the .460 Rowland kit for my Glock instead of the DW 1911, mainly due to the fact that the Glock would be able to hold 13+1 instead of the 8+1 of the 1911. But, it says on the site that although the lowers between the G20 & 21 are the same, the slide/barrel/mag are not.
Whatever pressure that round makes will be handled by the barrel lugs to slide and breach face. ...or NOT!
I would expect a very short service life, but I would also expect most owners just show it off and fire a clip every year or two.
I think your assessment is correct on all fronts.
Well...who knows on the service life. And...who cares?
I too have been skeptical of the 460 Rowland, but know someone who hunts with a converted Colt Gold Cup and absolutely loves it.
With that said, I have a friend with a L.A.R. Grizzly in 45 Win Mag. Even though it's a 1911-type gun, it's somewhat more reassuring to shoot in that you can tell it was built for the beating that the 45 Win Mag gives it.
I have to admit that I get a bit worried about slide velocities on my cheapie RIA 38 Super loaded like it was meant to be loaded. In my circle of friends, RIA 1911s are quite popular, and I'm the odd one out who has a Super. Most die-hard 1911 shooters are quite surprised the first time they shoot a Super as the recoil is quite different from a 45. As mentioned, the familiar 45 recoil is more of a push, while the Super is fairly "snappy."
