The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
30 registered members (DoubleWasp, berniedd, dishdude, Agnosto, 4 invisible), 623 guests, and 66 spiders.
Topics286,097
Posts4,902,476
Members67,560
Most Online2,967
Mar 10th, 2019
What makes extended oil drain oil extended. #4617514
12/29/17 09:40 AM
12/29/17 09:40 AM
Northeastern Vermont
littleant Offline OP
What makes extended oil drain oils extended. Stronger add pack? Because its synthetic? Better cleaning?. Is Quaker State UD consider an extended drain oil. Thanks
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: What makes extended oil drain oil extended. [Re: littleant] #4617519
12/29/17 09:48 AM
12/29/17 09:48 AM
Kendall, FL
wemay Offline
wemay  Offline
Kendall, FL
Specific equipment (PFI vs GDI and/or Turbo...) and how it's used, i.e., severe service vs normal etc.
For confirmation on how long an oil can go in your application, a few UOA at more conservative mileage would serve you better than any marketing claims, lab testing or slick wording on labels. This will give you confidence moving forward since you will also have data to back up your decision.
18 KIA Sportage 2.4 AWD
M1HM 10W30, OEM
13 Hyundai Santa Fe Sport 2.0T
PPeL 5W30, OEM
Re: What makes extended oil drain oil extended. [Re: wemay] #4617524
12/29/17 09:54 AM
12/29/17 09:54 AM
Wet side WA
JohnnyJohnson Offline
Wet side WA
For confirmation on how long an oil can go in your application, a few UOA at a more conservative mileage would serve you better than any marketing claims or slick wording on labels.
thumbsup
2004 Corolla 129932
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: What makes extended oil drain oil extended. [Re: littleant] #4617551
12/29/17 10:17 AM
12/29/17 10:17 AM
MN
oil_film_movies Offline
MN
Chemistry. ... Oxidation resistance, which mean using expensive base oils like PAO, and using advanced anti-oxidant chemicals thrown in. Also, the anti-wear chemicals must be robust, and the Viscosity Index Improver chemicals as well. Then, there must be plenty of antacid overbased stuff to continue to buffer acid buildup over time, and the amount of sulphur (H2SO4 formed) in gasoline plays a big role in that, as U.S. gasoline is mostly very low-sulphur now.
In a nutshell: chemical stability under heat and stress over time makes an Extended Oil like M1 EP, M1 Ann Prot, and Amsoil SS.
Re: What makes extended oil drain oil extended. [Re: littleant] #4617618
12/29/17 10:57 AM
12/29/17 10:57 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
HTHS above 3.5 cSt?
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: What makes extended oil drain oil extended. [Re: littleant] #4617821
12/29/17 02:37 PM
12/29/17 02:37 PM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Acea a3/b4 grin
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: What makes extended oil drain oil extended. [Re: littleant] #4617862
12/29/17 03:22 PM
12/29/17 03:22 PM
burlington ,ontario, canada
ndfergy Offline
ndfergy  Offline
TBN greater than 8 would be my guess. As far as conventional vs synthetic? Probably more vehicle specific. Case in point: my Yaris' OCI is 16,000km on their conventional 5W-30 oil for normal operation. My wife has the same OCI but with 0W-20 synthetic.
2015 Toyota Yaris 5spd Manual
Summer: Mobil Super 1000 10w30
Winter: Mobil Super 1000 5w30
OEM Filter
Re: What makes extended oil drain oil extended. [Re: littleant] #4617917
12/29/17 04:51 PM
12/29/17 04:51 PM
New Zealand
Silk Online content
Silk  Online Content
New Zealand
I thought it was just ignorance or economics...or maybe the lube sticker fell off or became unreadable. I see lots of extended oil changes...they leave my workshop 20,000km over and i never see them again. How far did they go....?
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: What makes extended oil drain oil extended. [Re: littleant] #4617941
12/29/17 05:34 PM
12/29/17 05:34 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
A3/B4
http://www.acea.be/uploads/news_documents/ACEA_European_oil_sequences_2016.pdf
Shear stable VII
High TBN
Low Noack
High SAPS for strong ZDDP & Detergent add pack (the ZDDP is an antioxidant to protect the oil, anti-wear to protect the metal, and quenches LSPI - while the detergent fights acid build up)
With a HTHS reserve
All formulated around quality base oils to resist oxidation and deposit formation.
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: What makes extended oil drain oil extended. [Re: SR5] #4617957
12/29/17 05:52 PM
12/29/17 05:52 PM
Rijeka, EU
chrisri Offline
chrisri  Offline
Rijeka, EU
A3/B4
Shear stable VII
High TBN
Low Noack
With a HTHS reserve
We are getting PUG Expert 2018 (1.6 hdi) and PUG Boxer (one is 3.0 IVECO, no idea for the other). Expert's OCI is 40k km, Boxer's 50k km. On C3 (possibly C2 oils)!
I agree with your post completely, but OEMs recommendations go completely different way- low HTHS, low/mid SAPS and very long OCIs.
02 Nissan Terrano 2.7.TDi Motul 15w40
06 FIAT Stilo MW 1.9 Multijet SHU 5w40
07 Opel Vectra SW 1.9 CDTI 150 MST 5w40
Re: What makes extended oil drain oil extended. [Re: chrisri] #4618071
12/29/17 07:22 PM
12/29/17 07:22 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
Yeah I hear you mate. And I shake my head at these long OCI's on C3 oils and shocked at C2 oils. I assume this is for Europe only with it's super high quality and low sulphur fuel. Some reports here on BITOG suggest they are not doing as well as the A3/B4 oils (from memory) but maybe they just have to be "acceptable".
Some of those low-SAPS & high-HTHS Porsche C30 & VW 504 / 507 oils are very high quality and seem to require very good base oils to get the job done. They are usually a high content PAO (Group IV) based oils. The high-SAPS versions being A3/B4 and Porsche A40 etc can seem to get away with Group III Hydrocracked synthetics.
My preference is for a PAO based A3/B4 such as Castrol Edge 0W40 to get the best of both worlds.
Re: What makes extended oil drain oil extended. [Re: littleant] #4618133
12/29/17 08:20 PM
12/29/17 08:20 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
For me, it mainly depends on my driving style.
When I was driving 350 miles/week all highway, I did 10,000 mile intervals on my '04 Elantra using several different synthetic oils.
On my truck, I only drive maybe 350 miles a month, mostly short trips, so I change it every 4000 or so.
Now days is also depends on the engine. On a direct engine turbo, I would not do 10,000 miles even if all highway.
2018 Hyundai Santa Fe: Delo XLE 10w-30, OEM filter, 3k
2012 Scion xB: QSUD 0w-20, CQ Blue, 5k
2002 Ford F150: Magnatec 5w-20, Bosch D+, 1yr
1994 Honda VT1100: Peak 15w-40, PSL, 1yr
Re: What makes extended oil drain oil extended. [Re: SR5] #4618391
12/30/17 01:07 AM
12/30/17 01:07 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
[quote=chrisri]
Nice... the Castrol Edge 10W-40 oil (clearance $2.00 qt) at Autozone is ACEA A3/B4 thumbsup
Re: What makes extended oil drain oil extended. [Re: chrisri] #4618874
12/30/17 03:13 PM
12/30/17 03:13 PM
Melbourne, Florida
RichardS Offline
RichardS  Offline
Melbourne, Florida
A3/B4
Shear stable VII
High TBN
Low Noack
With a HTHS reserve
Wait, 50k km oil change interval?!
2011 Prius II
2012 GLK350
Re: What makes extended oil drain oil extended. [Re: oil_film_movies] #4619343
12/31/17 02:50 AM
12/31/17 02:50 AM
wild blue yonder
Joekar Offline
Joekar  Offline
wild blue yonder
So if I want to do 10,000 mile changes in my gently driven 2008 Tundra these oils you mention above would be a smarter choice than Penzoil Platinum Ultra for the reasons you specify? I'm learning...
