Walmart and Valvoline
by Bullwinkle007. 01/22/19 09:10 PM
Getting Our Kicks On Route 66
by 2015_PSD. 01/22/19 08:40 PM
Uploading a short film clip from an IPhone.
by Snagglefoot. 01/22/19 07:52 PM
Purolator L34631 (torn media)
by LDM. 01/22/19 07:51 PM
THIS close to getting a VDB today at TPA
by 14Accent. 01/22/19 07:48 PM
Supco Appliance Parts.
by George7941. 01/22/19 07:36 PM
Unusual Jury summons.
by Chris142. 01/22/19 06:31 PM
Vibration feeling after new tires installed?
by MONKEYMAN. 01/22/19 05:51 PM
Sudden Shake - ‘18 Accord
by Throt. 01/22/19 05:43 PM
05 Ford 500 Intake hole - melted
by Geauxtiger. 01/22/19 05:41 PM
How's K&N 1004 on Kia/Hyundai GDI
by SlavaB. 01/22/19 05:18 PM
more PSD woes with cold weather
by Donald. 01/22/19 05:10 PM
Can someone do a UOA on AmazonBasics oil?
by ThunderOne. 01/22/19 04:03 PM
Any analysis on the Mobil 1 0W-40 ESP Dexos 2?
by fnbrowning. 01/22/19 04:02 PM
Cat sick
by Eddie. 01/22/19 03:49 PM
Lubeguard
by hardheaded. 01/22/19 02:10 PM
OEM Cap & Rotor when changing spark plugs?
by paulri. 01/22/19 01:50 PM
A young boy...
by JLTD. 01/22/19 01:34 PM
73guna, Tedee, JayF, Sam002, Binco
67013 Registered Users
92 registered members (2015_PSD, Aero540T, AdditiveOCD, 77GrandPrix, 928, 2004tdigls, 9 invisible), 1,352 guests, and 42 spiders.
Topics297,006
Posts4,963,319
Members67,013
Most Online2,821
Jan 21st, 2019
Do good add. packs fight oil contamination? #4617241
12/28/17 09:43 PM
12/28/17 09:43 PM
Idaho
RonRonnster Offline OP
Idaho
First let me preface my question by stating that no oil can completely prevent engine damage if engine oil is heavily contaminated by antifreeze, fuel, etc. Understandably, large amounts of contamination can and will prove deadly to an engine. However, I'm curious if there are oils with certain additive packs (conventional or synthetic) that would help curb damage caused by these contaminants, especially if the contamination starts out undetected, in small amounts.
I'll give an example - my '98 chev. has the Vortec 350 that was infamous for intake gaskets that degraded prematurely, often causing antifreeze leaks. I replaced mine a while back at 118,000 miles, due to some external seeping. Luckily, I caught it before it started dumping any coolant into the crankcase, but judging by the condition of the original IM gasket, I didn't change it a moment too soon.
Let's pretend I didn't have knowledge of this issue and had let it continue seeping, possibly leaking into the crankcase. Or, for the sake of this hypothetical, let's consider fuel dilution, or dust / dirt from a dirty air filter. Are there any oils out there that would hold up better to trace amounts of contamination than others, in turn preventing wear despite the contamination? Maybe a high mileage formulation, designed for use in older vehicles more prone to oil contamination with age? Maybe any good oil would be just as effective? Maybe none of them would be effective? Been thinking about this one lately. Thoughts?
- 2007 GMC Yukon XL Denali - 6.2L / 81k mi.
- 1998 Chev K1500 4x4 - 5.7L / 155k mi.
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4617291
12/28/17 10:46 PM
12/28/17 10:46 PM
[email protected] CZ firearm factory
Marco620 Offline
Marco620  Offline
confused
You have my attention....
15' Civic 1.8 i-vtec 207,000 mi 0w20 Redline/Redline CVT/Archoil9200/TEIN/Eibach/Tanabe Sustec/Borla Exhaust/Redline Si-1/87 E0 fuel
Son of a Navy Corpsman. Support vets!
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4617295
12/28/17 10:53 PM
12/28/17 10:53 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
"TRACE AMOUNTS" is the key, SO YES - THEY DO.
Huge leaks are more than can be asked of ANY oil, though.
Now....
Having said that, I have drained a LOT of "chocolate milk" in my life...
like, probably 100 gallons. So, I have been absolutely,
UTTERLY amazed at how much filth oil can handle, and after repairs....
(and of course, fresh oil!)
.......the car drove away just fine. Amazing.
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4617333
12/28/17 11:45 PM
12/28/17 11:45 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
No. Your best safeguard is to frequently check the oil. If you're aware the vehicle has more rapid oil contamination, use a shorter OCI.
Same thing different day really, maintain the vehicle if you want it to last. There's no magic oil that changes this.
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4617345
12/29/17 12:02 AM
12/29/17 12:02 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
My guesstimate is that a good add package will help
handle contamination better than el cheapo oil or add
pack.
Gasoline will thin the oil but water/coolant can do
serious damage. But can do damage but good oil and good
additives will help.
My 2
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4617407
12/29/17 05:53 AM
12/29/17 05:53 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
High viscosity seems likely to resist all the contaminants you mention (except maybe glycol) better than low viscosity, and if the viscosity is due to VII's, then those could be counted as additives.
Oil oxidation by glycol can cause a rise in viscosity.
Glycol oxidises to form organic acids. A higher base number will tend to resist acidification of the oil.
However, glycol also precipitates out oil additives leading to filter-plugging, so more additives in that case MIGHT not be a good thing.
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4621097
01/01/18 07:51 PM
01/01/18 07:51 PM
Idaho
Idaho
While in principle I'm intrigued by extended OCI's, my biggest reservation is the contaminants put off from a combustion engine. How does Mobil 1 Annual Protection or Amsoil SSO fight that? I'm sure the stout add pack helps. I guess this is where UOA comes in, because each engine will be different in terms of fuel dilution, or whatever else. I could probably run a synthetic oil in my furnace blower motor bearings forever, but a combustion engine is a different story. Sorry - furnace blowers are on my mind lately. Lost our heat this past week in negative degree F temperatures due to a locked up blower bearing!
Re: Do good add. packs fight oil contamination? [Re: RonRonnster] #4621338
01/02/18 05:40 AM
01/02/18 05:40 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
A very strong and effective dispersancy capability is probably most critical, not saying other oil properties are of lesser value.
Synthetics would have better luck than cheapo conventional in having stronger dispersancy capability , generally.... and possibly include extended-drain quality PCMO oils like Castrol/Mobil EP's; ACEA A3B4/C3 with high TBN's, HDEO's with E9/CK4 etc.
JMHO.
