Air Fryer....whose got'em?
by Schmoe. 01/16/19 01:59 PM
ebates - anyone a member?
by Papa Bear. 01/16/19 01:29 PM
Ordered a 2019 X5 for the Wife
by gofast182. 01/16/19 12:48 PM
Today, I ride
by SirTanon. 01/16/19 12:02 PM
2019 Nissan Rogue SL
by JTK. 01/16/19 11:19 AM
Does GM oil life monitor % go down without driving?
by Corollaman. 01/16/19 10:37 AM
Ford tire wear issues?
by Redright9. 01/16/19 10:23 AM
New Battery
by CarlGR. 01/16/19 10:21 AM
It's January and I Need My Motorcycling "Therapy" !!
by LoneRanger. 01/16/19 10:13 AM
Are New Vehicles Too Expensive?
by SubLGT. 01/16/19 10:02 AM
Manual transmission fluid in Europe for Mazda
by zsero. 01/16/19 07:31 AM
Affected by the gov't shutdown?
by xBa380. 01/16/19 07:04 AM
Opinion Needed / 1998 Olds 88
by Mark72. 01/16/19 06:24 AM
Chevron Supreme color change
by OilUzer. 01/16/19 05:14 AM
Dual exhaust benefits
by OilUzer. 01/16/19 03:02 AM
M1 0w40
by Pinoak. 01/16/19 01:55 AM
M1 0w40
by Pinoak. 01/16/19 01:51 AM
The best in personal defense (Humor)
by StevieC. 01/15/19 11:10 PM
VV03, Witchipoo, Durco1977, ConnorM, dkar26
66950 Registered Users
95 registered members (4WD, 2002 Maxima SE, 28oz, Alfred_B, 53' Stude, 7 invisible), 2,222 guests, and 35 spiders.
Topics296,643
Posts4,956,508
Members66,950
Most Online2,577
Jan 14th, 2019
In search of motor guard bypass oil filter. #4617214
12/28/17 09:22 PM
12/28/17 09:22 PM
Nebraska
JessMatthews Offline OP
Nebraska
Hello, I thought I might get my answer faster in this section. I'm looking for a Ralph wood modified motor guard bypass filter system if anyone has one for sale. Also if Ralph still makes them or any advice would be appreciated.
Thanks Jess Matthews
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4617261
12/28/17 10:04 PM
12/28/17 10:04 PM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
Hi Jess, welcome to the site. Ralph Woods is no longer making the MotorGuard filter that I'm aware of. There was a guy trying to sell a modified M30 on ebay, but don't know if it's still for sale or not. Might be easier to by an old M100 that come up from time to time on ebay.
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4617282
12/28/17 10:37 PM
12/28/17 10:37 PM
Nebraska
Nebraska
Ok thank you for the information. I've been reading up on oil bypass filters and that man has a ton of knowledge about this subject. I have been running a couple fs2500s and like them. A310 did you ever get your motor guard modified? I seen you on your YouTube channel that you had one you were trying to modify.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4617640
12/29/17 10:15 AM
12/29/17 10:15 AM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
Yes Ralph Woods sure knew his stuff that's for sure, after reading his post's I decided to try MotorGuards myself and love them. I have 3 M100's in service and one is modified with Aluminum sleeves. I did convert an M30 to an oil bypass and that works great as well. I copied Ralphs design, but instead of a 2 piece collar and sleeve I made it a one piece from 6061 aluminum. I also made some brass thrust washers as Ralph's units kept the original polypropylene thrust washers that wear out over time. Here's some pictures of the converted M30.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4617662
12/29/17 10:32 AM
12/29/17 10:32 AM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
P.S. In that last picture you can see the aluminum sleeve on the M100, both the M100 and M30 are using the Kirkland rolls. I like the converted M30 as I can run it as a transmission and fuel filter as well.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4617680
12/29/17 10:42 AM
12/29/17 10:42 AM
CO
UberArchetype Offline
CO
My Motorguards are all converted M30's with handmade internals. Ralph was kind enough to send me a pair of the nylon units he used to make before he passed on, but after that I had to make my own, as well. The last one I made had a little engineering built in by fabbing a telescopic internal sleeve. All you need is two pieces of pipe with a snug slip fit, then weld the appropriate size washers on the ends. This design eliminates any possibility of internal compromise and ensures the unit will button down tight.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4618773
12/30/17 11:49 AM
12/30/17 11:49 AM
Nebraska
Nebraska
Thank you for the information, I hope to find an old 100 and then modify a few m30s for some tractors I have and a v10 Ford also. I like the way these are designed compared to the frantz. I was wondering if anyone used the gulf coast bypass that use a paper towel roll. I would think they might be able to run longer before changes on tractors that hold 5 gallons of oil. I'm just asking because I know my fs2500 filters don't last as long in my tractors as they do in my 7.3 powerstroke.
Thanks for the info
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4618832
12/30/17 01:13 PM
12/30/17 01:13 PM
CO
CO
I run the GC-01 on my '91 Dodge Cummins. I have no idea how long they might run in your application, but one of the cool things about these type filters to me at least is I never fully loaded one. They were always still flowing good when I finally decided to change them, just because. The most miles I put a the GC filter was around 20k.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4619368
12/31/17 04:04 AM
12/31/17 04:04 AM
ohio
xtell Offline
xtell  Offline
ohio
Frantz is another bypass filter option if you cannot find a Motor Guard. I have Frantz filters on my work trucks and they have held up well over the years.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4620435
01/01/18 10:08 AM
01/01/18 10:08 AM
Kelowna, BC, Canada
A310 Offline
A310  Offline
Kelowna, BC, Canada
The closest bypass I have to a Gulf coast is a PuraDyn MTS24 unit on my sister's Cummins. It can easily be converted to use a paper towel roll, I've tried in the past to find a Gulf Coast Junior, but no luck.
Re: In search of motor guard bypass oil filter. [Re: UberArchetype] #4622076
01/02/18 06:39 PM
01/02/18 06:39 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
I've got a GCF-01 on my 2000 Dodge Cummins, and my experience has been about the same. I change it annually just because, along with the full flow filter and send off an oil sample at the same time.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4627048
01/07/18 02:56 PM
01/07/18 02:56 PM
Nebraska
Nebraska
The guys that have the gulf coast gcf-01 system, do you just use a paper towel or by the elements? I found some gulf coast on eBay and thinking bout trying one.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4628949
01/09/18 07:28 AM
01/09/18 07:28 AM
Kansas
jacobs Offline
jacobs  Offline
Kansas
Racor 1000's originally were supplied with rolls of paper towels. To use the newer filters with paper towels you would now have to modify them to seal around the center tube. The original's had a center tube similar to a Frantz.
Re: In search of motor guard bypass oil filter. [Re: JessMatthews] #4642024
01/21/18 03:09 PM
01/21/18 03:09 PM
Alaska
AlaskaMike Offline
AlaskaMike  Offline
Alaska
With my GCF O-1 I use the Kirkland brand paper towel rolls from Costco, and they work well. I've never bought elements from GCF.
