Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
Redline releases Professional Series
by Marco620. 03/20/19 11:52 PM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
106 registered members (addyguy, 2012AccentSE, arowbat, Anduril, ArrestMeRedZ, 901Memphis, 11 invisible), 1,935 guests, and 60 spiders.
Topics286,185
Posts4,903,766
Members67,574
Most Online2,967
Mar 10th, 2019
brake fluid tester. are they accurate and how to #4616929
12/28/17 05:45 PM
12/28/17 05:45 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
use
i bought one of the brake fluid testers off of AMAZON. I tested the crv and sub which has under one year fluid. tested the bmw that has not been changed for 10. on the sub and crv they show 1% . odd to me seeing the fluid in both was under a year. maybe because they live outside might be a factor in the 1%.
what was also odd is the bmw also showed 1% but its been garaged all of it life
also what is the correct way to use it. some say just need to immerse the probes in the fluid.some say it must be immersed till it touche the plastic end . doing one or the other gets diffenrt results
https://www.amazon.com/KINGBOLEN-Brake-L...#productDetails
Re: brake fluid tester. are they accurate and how to [Re: WhyMe] #4616937
12/28/17 05:51 PM
12/28/17 05:51 PM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
Mix a small amount of water with some brake fluid in a jar, shake it and test.
Re: brake fluid tester. are they accurate and how to [Re: Trav] #4616951
12/28/17 06:13 PM
12/28/17 06:13 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I you could also do the same with a multimeter. See the change in resistance while adding a certain % of water (distilled, not to increase conductivity with dissolved solids). Compare results.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: brake fluid tester. are they accurate and how to [Re: Trav] #4617080
12/28/17 08:43 PM
12/28/17 08:43 PM
Canada
i_hate_autofraud Offline
Canada
LOL, just don't shake any brake fluid you intent to use in the car! shaken fluid has air bubbles!
Re: brake fluid tester. are they accurate and how to [Re: i_hate_autofraud] #4617420
12/29/17 07:17 AM
12/29/17 07:17 AM
Trav Offline
Trav  Offline
100ml brake fluid in a jar and add 1ml at a time, test it then dispose of it.
Re: brake fluid tester. are they accurate and how to [Re: WhyMe] #4618427
12/30/17 03:20 AM
12/30/17 03:20 AM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
been checking quite a few cars and have not found a 4% yet. 1-2 % . i put the probes in straight water and it lighted up all the lights.
Re: brake fluid tester. are they accurate and how to [Re: WhyMe] #4619111
12/30/17 08:11 PM
12/30/17 08:11 PM
sw ohio
willbur Online content
willbur  Online Content
sw ohio
Interesting post. Maybe none of the tested fluids had more than minimal amts of water?
Ford, some years ago, tested brake fluid in junked cars at salvage yards and found little water in the fluid. Perhaps your instrument is trying to tell you that?
Re: brake fluid tester. are they accurate and how to [Re: Dyusik] #4620178
12/31/17 11:39 PM
12/31/17 11:39 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
I'm not sure I really understand this story.
What you say seems reasonable, if your meter is sensitive enough, but other sources found on the nyet often refer to testing the conductivity of the fluid (the inverse of the resistance, so still reasonable), but then go on to measure voltage, which isn't a directly related unit.
The procedure generally seems to involve measuring a potential difference (voltage) between the fluid in the reservoir and the vehicle earth, so perhaps its actually measuring galvanic corrosion which conductivity of the fluid allows. IIRC 0.3V is the suggested maximum.
There seem to be a lot of uncertainties in this procedure, including the metallic makeup of the car and your immersed meter electrode, and it seems it couldn't be used to test fluid in the bottle since in that situation there are no different metals involved.
Re: brake fluid tester. are they accurate and how to [Re: WhyMe] #4620210
01/01/18 01:27 AM
01/01/18 01:27 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I have tested the same fluid with both a brake fluid tester and multi meter many times - I've never seen fluid with 300mv pass on the fluid tester...and fluid that passes read low on the multi meter. It works...you can do your own tests of course. I don't test new fluid in the bottle of course, as you say we are looking at electrolisis, galvanic action, what ever you want to call it, but corrosion involves electricity.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: brake fluid tester. are they accurate and how to [Re: Silk] #4620260
01/01/18 03:55 AM
01/01/18 03:55 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
OK, if that's your experience, that's useful and relevent info, BUT that isn't the same procedure as the post I was responding to, which talks about measuring the conductivity/resistance of the fluid.
If THAT procedure works (I havn't tried either, though I have tried a voltage check for coolant) then it seems to have some advantages.
It seems to have fewer variables, it should be possible to test in a bottle/tube rather than just on the car, and it should be possible to calibrate it by adding water, which you probably wouldn't want to do on the car.
Re: brake fluid tester. are they accurate and how to [Re: WhyMe] #4620265
01/01/18 04:27 AM
01/01/18 04:27 AM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I think the resistance thing is just someone getting it wrong. I haven't tried it, but I think just adding water isn't going to give an accurate result either, like condensation in oil, just adding water to engine oil isn't going to create acids, it needs heat and some time to get working. Same with brake fluid, the damaging stuff takes time in the system to get working. You can do the same with coolant...it's time in the system that gives voltage.
Re: brake fluid tester. are they accurate and how to [Re: Silk] #4620316
01/01/18 08:33 AM
01/01/18 08:33 AM
Trav Offline
Trav  Offline
I don't know about that tester but if I test brake fluid in the bottle that has had the cap loose for a long time it shows a percentage of moisture.
The fluid was never in a brake system just the original plastic bottle. time for an experiment eh.
Re: brake fluid tester. are they accurate and how to [Re: Silk] #4620960
01/01/18 07:09 PM
01/01/18 07:09 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
That was my best guess, but it'd be good to be wrong on this one.
Re: brake fluid tester. are they accurate and how to [Re: Silk] #4621988
01/02/18 06:13 PM
01/02/18 06:13 PM
sw ohio
sw ohio
I'm a little confused what you are measuring with the multimeter. Is it measuring fluid conductivity resulting from copper leaching out of brake lines into the brake fluid (increasing its conductivity), or water content?
