The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
33 registered members (berniedd, Chesterr, dishdude, Agnosto, 4 invisible), 621 guests, and 63 spiders.
Topics286,097
Posts4,902,476
Members67,560
Most Online2,967
Mar 10th, 2019
Radiator Heat #4616899
12/28/17 05:15 PM
12/28/17 05:15 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Quick question: My son and a buddy are moving into a rental house this weekend and he did a walk-thru this evening
Landlady is a recent widow and not 100% familiar with everything... she was explaining to my son about the heat and a glass water tube that indicates whether or not water needs to added ...?
I may be way off base on this and I wasnít there, but doesnít anyone have any familiarity with radiator heat and what this glass tube is all about?
Thank you
God Bless America
Re: Radiator Heat [Re: Finz] #4616911
12/28/17 05:24 PM
12/28/17 05:24 PM
USA
mk378 Offline
mk378  Offline
USA
That would be a steam boiler. It is probably very old since they are seldom installed any more. The tube is a sight glass that shows the level of water in the boiler. Usually there is an automatic control to add water, and another control that will shut down the burner if the water level is too low. It should need water only very occasionally unless there is a leak.
Re: Radiator Heat [Re: Finz] #4616915
12/28/17 05:29 PM
12/28/17 05:29 PM
MA
Wolf359 Online content
Wolf359  Online Content
MA
That sounds like a steam boiler which has a sight glass for water. I still have several of those. The newer ones have automatic water feeders like the Hydrolevel VXT. You can retrofit them to older boilers but it typically requires an electronic low water cutoff and some of those older boilers just have an older Mcdonnell Miller 67 which won't work with the newer water feeders. Probably costs a minimum of $500-$1000 to retrofit an old boiler.
Anyway, yes, you fill the water up close to the top of the sight glass. Don't go over because the pipes will bang if there's too much water and you're paying to heat that water. The low water cut off shuts off the water once it gets too low so then you'll have no heat. Normally you want to add water slowly so you don't crack the boiler by adding cold water to a hot boiler. Steam shouldn't be coming out of the steam vents, if they do, you need to get them replaced as that will cause you to have to add water more frequently. Normally you have to add water every 2-3 weeks.
Re: Radiator Heat [Re: Finz] #4616940
12/28/17 05:59 PM
12/28/17 05:59 PM
USA
mk378 Offline
mk378  Offline
USA
Also with any gas or oil heating system make sure to keep a working CO detector in the house.
Re: Radiator Heat [Re: Finz] #4617134
12/28/17 09:22 PM
12/28/17 09:22 PM
New Jersey
JHZR2 Offline
Global Moderator
JHZR2  Offline
Global Moderator
New Jersey
Yes that's a steam boiler. The best kind of heat there is, imo!
Re: Radiator Heat [Re: Finz] #4617198
12/28/17 10:12 PM
12/28/17 10:12 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Thanks all,,, Iíve always heard thatís the best heat there is but never saw the guts of one before.
Ran over there and itís a nice place... site glas is right there in plain view but dirty. Flushed out some water and refilled but still dirty and I didn t want to mess with it. Heats the place up well. I imagine once we get a cold snap where the boiler will be running for a stretch, that will be one very toasty basement
Again, thanks for the input
God Bless America
Re: Radiator Heat [Re: Finz] #4617230
12/28/17 10:33 PM
12/28/17 10:33 PM
MA
MA
Steam is an old system. AFUE isn't really that high, maybe about 82%. A hot water direct vent boiler can go up to 96% efficient. Basically steam boilers have to heat water up to 240 degrees to get steam, hot water is more in the 160-180 range so you spend less energy heating up water. They can also bang if the radiators aren't pitched right. Single pipe systems mean that you can't easily convert it to hot water. Some like them because you get some humidity with it from the steam, but the steam vents are supposed to close when the steam hits and just let out air.
Anyway, for the boiler, there's a blow down valve on the Mcdonnell millers low water cutoff, you let out the dirty water every time you add water. You want to do that on a regular basis otherwise if the low water cut off gets filled up with silt, the float will stop working and your boiler will basically overheat and crack the boiler. One of the dangers of a steam boiler, they don't last as long as hot water boilers. You can actually disassemble the hardware around the sight glass and clean the glass inside. Blowing it down won't clean it once it's dirty like that.
Re: Radiator Heat [Re: Wolf359] #4617944
12/29/17 05:39 PM
12/29/17 05:39 PM
Northeast
Finz Offline OP
Finz  Offline OP
Northeast
Very informative Wolf...! Thank you. Iíll take a look at some point this weekend
Thanks again
God Bless America
