.05 Cent haynes manual
by Jman26063. 03/26/19 09:02 PM
Pennzoil Canada Rebate
by Snagglefoot. 03/26/19 09:01 PM
Burned out blinker
by Chris142. 03/26/19 09:00 PM
Best Moly add for timing chain health?
by RichR. 03/26/19 08:53 PM
Kenmore dishwasher quit.
by Trotter. 03/26/19 08:49 PM
Urethane with integrated clear coat cure time?
by FixItDad28. 03/26/19 08:39 PM
Chevron rykon premium mv alternative?
by Framer. 03/26/19 08:12 PM
Got a bunch of new old stock oil and filters...
by dogememe. 03/26/19 07:04 PM
Right turn signal blinking super fast
by das_peikko. 03/26/19 06:55 PM
Another fun car to work on.
by Chris142. 03/26/19 06:48 PM
Equivalent LED T8/T12 tubes?
by y_p_w. 03/26/19 06:37 PM
Do you use chemicals on your lawn?
by ZZman. 03/26/19 05:21 PM
Baked Cabbage Steaks
by StevieC. 03/26/19 02:57 PM
Best Store Bought BBQ Sauce?
by Redright9. 03/26/19 02:26 PM
Hankook tire rebate
by FordBroncoVWJeta. 03/26/19 01:14 PM
Dave Graham repair manual?
by HangFire. 03/26/19 01:02 PM
Framer, Joe_Gibbs, PerryPerrister, brak132, mike001100
67635 Registered Users
136 registered members (4WD, 2002 Maxima SE, 2004tdigls, 01rangerxl, 13 invisible), 2,112 guests, and 93 spiders.
Topics286,474
Posts4,909,095
Members67,635
Most Online2,967
Mar 10th, 2019
Antifreeze how low do you go #4616684
12/28/17 01:59 PM
12/28/17 01:59 PM
Northeastern Vermont
littleant Offline OP
Hi. How low do you have your antifreeze and do you allow for wind chill. Last night the temperature up here in Northeastern Vermont was -25 with a wind chill of -38. Do you count in driving on an interstate at 60. I have my coolant at -45. I fully warm up engine before driving. Thanks
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
Re: Antifreeze how low do you go [Re: littleant] #4616688
12/28/17 02:02 PM
12/28/17 02:02 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
Cars aren't affected by wind chill, only real temperature.
2012 Chevy Cruze LT 1.4T - 59k - Edge 0w30 SL + Mahle OX401D
2002 Buick Century 144k - Built 4T65e(Maxlife) - GTX 5w30 + Fram XG3980
Re: Antifreeze how low do you go [Re: littleant] #4616698
12/28/17 02:11 PM
12/28/17 02:11 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Yep, wind chill is about you. Temperature is what your coolant/car cares about.
yup
Re: Antifreeze how low do you go [Re: littleant] #4616703
12/28/17 02:16 PM
12/28/17 02:16 PM
Northern Kentucky
901Memphis Offline
901Memphis  Offline
Northern Kentucky
I aimed for 50% with my G05 which is good until -34F. It doesn't get below negative single digits here rarely. Supposed to be that cold next week.
Re: Antifreeze how low do you go [Re: littleant] #4616719
12/28/17 02:30 PM
12/28/17 02:30 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
Wind chill removes heat from the engine bay at a faster rate than if there were no wind. Then again, when driving at 60 mph you have more wind across your radiator too. As long as your coolant temp reaches set point, you're probably fine.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Antifreeze how low do you go [Re: littleant] #4616748
12/28/17 02:53 PM
12/28/17 02:53 PM
USA
mk378 Online content
mk378  Online Content
USA
Wind chill does not affect whether or not a liquid will eventually freeze. If the freezing point is above the real temperature, adding wind will make it freeze faster, but ultimately whether it is going to freeze or not is decided by the real temperature.
Re: Antifreeze how low do you go [Re: littleant] #4616794
12/28/17 03:28 PM
12/28/17 03:28 PM
New York City
ThankYouma Offline
ThankYouma  Offline
New York City
50-50 works fine, as far as I know.
Re: Antifreeze how low do you go [Re: littleant] #4616815
12/28/17 03:48 PM
12/28/17 03:48 PM
Chicago Suburbs
Nitronoise Offline
Nitronoise  Offline
Chicago Suburbs
Great Lakes Lubricants in Franklin Park IL has an anti freeze that works to -64 F
I use it in my sons Santa Fe up at college in MN
tonite and tomorrow -20 + for lows this weekend
they do web sales
07 Ford Freestyle 135K
06 Honda Acord EX 115K
04 Hyundai Sonata 290K sold
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
Re: Antifreeze how low do you go [Re: littleant] #4616835
12/28/17 04:04 PM
12/28/17 04:04 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Never seen temps less than -25F 50/50 is how I've been mixing it forever.
Thick oil is better grin2
Re: Antifreeze how low do you go [Re: littleant] #4616849
12/28/17 04:15 PM
12/28/17 04:15 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
55/45 up here is the mix ratio.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Antifreeze how low do you go [Re: littleant] #4616853
12/28/17 04:18 PM
12/28/17 04:18 PM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
When I do a flush and refill I use a gallon of 70/30 as there will still be some water in the block. Then top off with 50/50 and it comes out around 60/40..... more or less.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Antifreeze how low do you go [Re: littleant] #4616895
12/28/17 05:09 PM
12/28/17 05:09 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
60/40 for me.
A 10 degree margin for error during our polar vortex a few years ago wasn't worth it for me.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Antifreeze how low do you go [Re: 69GTX] #4617012
12/28/17 07:23 PM
12/28/17 07:23 PM
Ruidoso, NM USA
ammolab Offline
ammolab  Offline
Ruidoso, NM USA
Yes, but wind chill is about evaporation of moisture on exposed skin making it "feel colder". Wind chill or ram air over your engine and radiator will never lower the temp below ambient.
Why the news often ONLY shows "wind chill" temps makes me mad. I want actual temp to plan for pipes, plants and of course VISCOSITY! They just like the spectacular numbers I guess.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
Re: Antifreeze how low do you go [Re: ammolab] #4617020
12/28/17 07:33 PM
12/28/17 07:33 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
I worked with an old fashioned New Yorker (City, not State) and only he could say, "They can take that wind chill and shove it up their....".
I agree.
In the Winter of '80-'81 I lived where we had 3 consecutive nights of -38 degrees Fahrenheit.
That's below the freezing point of 50/50 mixes of the day.
My car had no problem. I was driving a........Corvair!
The "degree Fahrenheit" symbol came through as a jumble of characters so I spelled it out.
Re: Antifreeze how low do you go [Re: littleant] #4617048
12/28/17 08:07 PM
12/28/17 08:07 PM
Thanks for the replies guys. Good information.
