Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Pentofrost coolant $10 Autozone
by PD001
06/19/18 07:49 PM
The things you find cleaning Garage 30+ btls slob
by digger327
06/19/18 07:20 PM
Castrol GTX Magantec 0w20 - 6 pack $21.99 - Amazon
by 04SE
06/19/18 07:07 PM
Havoline Pro DS 5w20 $3.15/quart - Amazon
by 04SE
06/19/18 07:06 PM
Needing New Dipstick
by Geauxtiger
06/19/18 05:11 PM
'98 Mercedes E300TD Rotella T5 10W-30 5k miles
by KenO
06/19/18 04:35 PM
Premium guard oil filters
by Jaha24k
06/19/18 04:09 PM
76 super motor oil- synthetic blend 5w-30
by Jaha24k
06/19/18 04:07 PM
Who makes the Mopar 5038041AA filter?
by Quattro Pete
06/19/18 03:55 PM
Ruger Mini-14, yay or nay?
by 28oz
06/19/18 03:51 PM
USPS long long delivery to BlackStone Labs
by Pajero
06/19/18 02:58 PM
House A.c. vent leaking water
by motor_oil_madman
06/19/18 02:55 PM
"synthetic" gear oil and LS additive?
by nthach
06/19/18 01:54 PM
Supertech wix ST8 5514 miles
by jakewells
06/19/18 01:38 PM
Santo, aligoodn, memyself, MichiganKid419, kaphouston
65273 Registered Users
104 registered (addyguy, 2002 Maxima SE, AITG, Aero540T, 2015_PSD, 9050lx, 15 invisible), 1582 Guests and 30 Spiders online.
65273 Members
67 Forums
285621 Topics
Page 1 of 3 1 2 3 >
#4616556 - 12/28/17 10:07 AM Want a hotter t-stat
SHOZ Offline
Loc: Illinois
My Hyundais run too cool in the winter when below 0F. Both have new t-stats and run as they are designed. But the Accent will pull more heat out of the engine than it can produce with a 180F t-stat. I have the radiator half way blocked off and that did not seem to do much at all.
I've looked and cannot find any that are in the 190F range. Is there anywhere you can pick a t-stat by dimension?
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
#4616566 - 12/28/17 10:18 AM Re: Want a hotter t-stat [Re: SHOZ]
JC1 Offline
Loc: Oshawa, Ontario Canada
Can you define by running cool? They don't produce enough heat, or is the temperature gauge not getting hot enough?
How long are you driving the cars for during this cold weather?
2015 Grand Caravan SXT Plus 5w-20 PPPP/Wix Filter
1997 Honda Civic CX 5w-30 PPPP/Mahle Filter
#4616567 - 12/28/17 10:19 AM Re: Want a hotter t-stat [Re: SHOZ]
DoubleWasp Offline
Loc: Fort Lauderdale, FL
If your engines aren't meeting the rated temp, what good will it do to raise it?
#4616572 - 12/28/17 10:24 AM Re: Want a hotter t-stat [Re: SHOZ]
SHOZ Offline
Loc: Illinois
The t-stat is rated to start to open at 180F and that is what it does. It will eventually get to 183F with the heater on and an hour of driving. But at 180F when I coast or turn the fan speed up above 1 the engine temp drops below 180F.
You can definitely feel the difference between 177F and 183F coolant with the air coming from the heater.
#4616579 - 12/28/17 10:28 AM Re: Want a hotter t-stat [Re: SHOZ]
Quest Offline
Loc: beaver land EH?
Are you sure your thermostat is not "lazy"?
a "lazy" thermostat may still be somewhat functional, at a cost of slow, very slow to warm up.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#4616582 - 12/28/17 10:31 AM Re: Want a hotter t-stat [Re: SHOZ]
SHOZ Offline
Loc: Illinois
No I replaced them both this year because they were lazy. I warms up to the 180F pretty fast, maybe a couple three miles on the highway. Last year with the lazy t-stats and 0F temps it took maybe 15 miles to get that hot.
#4616583 - 12/28/17 10:32 AM Re: Want a hotter t-stat [Re: SHOZ]
Nitronoise Offline
Loc: Chicago Suburbs
You might want to make sure that you close off the fresh air feed or its called the cabin recirculate, as it draws cold air from out side the vehicle , that way you are using recirculated air that doesn't need as much heat to maintain cabin temps I have no problems with my Hyundai today driving to work
07 Ford Freestyle 135K
04 Hyundai Sonata 280K
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
#4616587 - 12/28/17 10:35 AM Re: Want a hotter t-stat [Re: SHOZ]
SHOZ Offline
Loc: Illinois
If you put it on recirculate the windows frost up in no time or even if just on floor and vent. You almost always have to have the defroster on to keep the windows clear.
If I turn the fan speed up it will drop the coolant temp so it appears there is plenty of air flow past the heater core.
Almost all my driving is out in the country, if I'm driving around town there is no problem.
#4616593 - 12/28/17 10:42 AM Re: Want a hotter t-stat [Re: SHOZ]
fenixguy Offline
Loc: NC
I'll save you the trouble by telling you it won't help. My '01 Civic is the same way. It takes 10 minutes or so of normal driving to start making any heat if it's below 30. If you go down a long hill coasting, the guage drops and there's no heat. The engine just doesn't get very hot.
I switched from a 180 to a 190 degree t-stat and it didn't change a thing. My other cars will have heat within a couple minutes of driving.
'16 Frontier SV 4x4-PP/Nissan OEM
'08 CR-V EX AWD-Valvoline Syn MaxLife/Fram TG
'01 Civic EX-Valvoline Syn MaxLife/Fram UG
'00 Civic LX-PYB/Fram UG
#4616598 - 12/28/17 10:48 AM Re: Want a hotter t-stat [Re: SHOZ]
skyactiv Offline
Loc: The Midwest
A hotter thermostat is to be avoided. Your complaining about the heat output when it's very cold outside. How many days a year is it that cold in Illinois? Learn to live with it if all else is working properly.
Me: 13' VW GTI 3 door 6 speed manual
#4616600 - 12/28/17 10:52 AM Re: Want a hotter t-stat [Re: SHOZ]
andrewp1998 Offline
Loc: MA USA
Chicago is very cold in winter!
2001 Honda civic HX vtecE- 5 spd,230k+
#4616604 - 12/28/17 11:01 AM Re: Want a hotter t-stat [Re: SHOZ]
Linctex Offline
Loc: Waco, TX
A hotter thermostat won't help.
Try blocking more air off to the radiator. Half is not enough.
#4616605 - 12/28/17 11:01 AM Re: Want a hotter t-stat [Re: SHOZ]
eljefino Offline
Loc: ME
My saturn s-series were the same way. Cardboard in front is the way to go. Air hits the oil pan etc as well and removes heat. Even if your thermostat were perfect air would go through the (cold) radiator and hit the engine and suck heat out. A little of what would be considered "heat soak" would be a good thing. Ideally you'd have the grille so well insulated the thermostat would be at about its halfway point.
#4616608 - 12/28/17 11:06 AM Re: Want a hotter t-stat [Re: SHOZ]
SHOZ Offline
Loc: Illinois
Good grief I've lived in rural Illinois for 40 years. I know about winter.....
I'll block the whole radiator off today and see if that's better. I did this last year and it never overheated but the t-stat was 9 years old.
#4616615 - 12/28/17 11:13 AM Re: Want a hotter t-stat [Re: SHOZ]
SHOZ Offline
Loc: Illinois
I was wondering what the oil temp is on the little 4 cylinder. the Gen coupe will barely hit 180F after an hour, the Accent has a cast aluminum oil pan and I figure that is sucking a lot of heat away.
FWIW Hyundai actually list the kcal/hr 4450 +-10% rating for the heater core for the Accent. I've never seen that before.
Page 1 of 3 1 2 3 >
