How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
Longevity of Mercon LV in a 2017 Ford Escape?
by mrdctaylor. 09/18/18 01:24 PM
I'm on a Lawn Boy jag
by andyd. 09/18/18 01:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
47 registered members (carlprop, bdcardinal, Bailes1992, Buzzsaw, bbhero, 1 invisible), 1,159 guests, and 40 spiders.
Topics290,616
Posts4,847,547
Members66,011
Most Online3,590
Jan 24th, 2017
2015 Honda pilot #4616378
12/28/17 08:07 AM
12/28/17 08:07 AM
Louisiana
millerbl00 Offline OP
Louisiana
Just got a 2015 Honda pilot with 29000 miles. Been reading a lot about the cylinder deactivation and some people having problems. I can feel it when it deactivates and activates but not a big deal. There are ways to disable it.
My question is should I disable it? Like to hear from other pilot owners.
thanks
Re: 2015 Honda pilot [Re: millerbl00] #4616404
12/28/17 08:33 AM
12/28/17 08:33 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
I have a 2012 with 112k mi on it. The cylinder deactivation causes a slight vibration when it kicks in, and itís worse as the ambient temperature drops. Subtle and hardly noticeable, but annoying when you do notice it. Should you turn it off? I havenít and wonít.
The only other issue I have is fuel dilution as measured by Blackstone. This issue is consistent and drops viscosity but hasnít resulted in wear metals outside the norm.
Re: 2015 Honda pilot [Re: millerbl00] #4616413
12/28/17 08:44 AM
12/28/17 08:44 AM
New England
jdavis Offline
jdavis  Offline
New England
I installed a VCM Muzzler II on my 2017 Honda 3.5, much prefer the way the car operates now.
My 2017 GMC with the 3.6 LGZ also has cylinder deactivation but I do not notice so don't care to disable it in that vehicle.
Re: 2015 Honda pilot [Re: millerbl00] #4616414
12/28/17 08:44 AM
12/28/17 08:44 AM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
The rumor I heard is the VCM can cause excessive oil consumption. I see a lot of V6 Hondas that burn oil, but I have no way of confirming if it is from the VCM only.
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: 2015 Honda pilot [Re: millerbl00] #4616453
12/28/17 09:23 AM
12/28/17 09:23 AM
MA, Mittelfranken.de
Trav Offline
Trav  Offline
I have a little experience with these engines. should you disable it? Absolutely 100%!
For a minimal improvement in fuel economy they took one of the best V6 engines on the market and turned it into a pile of trash that is burdened with all sorts of issues, all of them expensive to repair.
Oil burning, cylinder and cylinder head/camshaft damage, sludge, worn active engine mounts that cost a small fortune, expensive spool valves that fail, an OLM that doesn't even come close as the oil is long finished before it trips and all this for a couple of MPG.
It doesn't take an engineer to figure out that if the active engine mounts are needed just to keep the engine from feeling like its going to hop out and run down the road on its own that something isn't running quite as smoothly as it should.
Re: 2015 Honda pilot [Re: millerbl00] #4616465
12/28/17 09:34 AM
12/28/17 09:34 AM
New England
jdavis Offline
jdavis  Offline
New England
Good points by Trav..
By the way, I didn't notice any drop in fuel economy disabling it so really not sure of the point of it.
Re: 2015 Honda pilot [Re: millerbl00] #4616502
12/28/17 10:09 AM
12/28/17 10:09 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
Everyone I know that has VCM Honda V6 has put on the muzzler. I'm wanting to get a 2017 Accord coupe, last year of the accord V6's, but going to have to wait a year or two and get a used one. I'll be putting one on also. That VCM is strictly for mileage to appease the EPA gods and the potential for problems down the road is not worth saving a couple of miles.
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L
Re: 2015 Honda pilot [Re: millerbl00] #4616516
12/28/17 10:24 AM
12/28/17 10:24 AM
Louisiana
Louisiana
Thanks everyone. A lot to think about
Re: 2015 Honda pilot [Re: millerbl00] #4616578
12/28/17 11:27 AM
12/28/17 11:27 AM
IL
dwgwater Offline
dwgwater  Offline
IL
Dissenting opinion. I have a 2010 Pilot EX-L coming up on 95,000 miles that I bought new. No oil use worth mentioning. Runs like a champ. That said, Pilots are hard on oil. Its a heavy vehicle and the 2nd gens have the aerodynamics of a sheet of plywood. I rarely get close to 20 mpg. 16ish is a normal tankful. The engine works hard all the time and burns lots and lots of fuel. I suspect the MM baseline is the Accord, which burns half the fuel the Pilot does. No wonder the MM gives OCIs that are too long on the Pilot. Change the oil every 4-5K and don't think about the VCM
Re: 2015 Honda pilot [Re: dwgwater] #4616761
12/28/17 02:59 PM
12/28/17 02:59 PM
Trav Offline
Trav  Offline
Your right at the mileage issues begin to crop up, all the ones I have done were between 80-140K depending on how they were driven.
From your post it seems you work this vehicle a little harder than many so it may not be spending as much time in eco mode, turning eco off may in fact improve your fuel economy in this operating scenario.
Re: 2015 Honda pilot [Re: jdavis] #4616771
12/28/17 03:08 PM
12/28/17 03:08 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
+1, I hope the OP listens to him and gets a muzzler installed.
Re: 2015 Honda pilot [Re: millerbl00] #4617449
12/29/17 08:14 AM
12/29/17 08:14 AM
Louisiana
Louisiana
If I was to buy one that disables which one? vmctuner, muzzler, etc....
thanks
Re: 2015 Honda pilot [Re: millerbl00] #4617839
12/29/17 02:53 PM
12/29/17 02:53 PM
New England
jdavis Offline
jdavis  Offline
New England
thanks
VCM Muzzler II
Re: 2015 Honda pilot [Re: millerbl00] #4618102
12/29/17 07:57 PM
12/29/17 07:57 PM
Crown Point, IN
dan_erickson Offline
Crown Point, IN
I have the VCM Muzzler on my 2015 Accord and it is the best thing I could have done for that engine. I feel like I actually gained an MPG in the city but lost a couple MPG on the highway.
15 Accord Coupe EX-L V6 Navi
Castrol Magnatec 0w20
Re: 2015 Honda pilot [Re: millerbl00] #4618334
12/29/17 11:29 PM
12/29/17 11:29 PM
The Northeast
mclasser Offline
mclasser  Offline
The Northeast
I've had a Muzzler for the past 25k miles and love it. VCM operation isn't that bad on my Pilot but the car runs much smoother with all 6 cyl firing. I hope using the Muzzler from early on will prevent VCM-related oil burning/plug fouling down-the-road.
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
