Rust Belt vs Sun Belt cars
by ZZman. 09/25/18 11:33 AM
Enginer rebuilder's view of GDI intake issues
by Brigadier. 09/25/18 11:09 AM
Oil for '84 Caddy w/HT-4100
by StillLearning. 09/25/18 10:41 AM
Interesting video of diff with clear cover
by mrdctaylor. 09/25/18 10:15 AM
The death of American footbal
by Brigadier. 09/25/18 10:01 AM
Tire leaking from bead/rim
by Brybo86. 09/25/18 09:39 AM
2000 4Runner 3.4L
by ka9mnx. 09/25/18 08:59 AM
VW 508 Spec 0w20 Updates?
by Zee09. 09/25/18 08:36 AM
Laptop Recommendations
by buster. 09/25/18 08:24 AM
Mac OSX Mojave - vid card requirements
by OVERKILL. 09/25/18 08:05 AM
Age of first drive
by madRiver. 09/25/18 08:02 AM
Please, maintain your tires properly
by 53' Stude. 09/25/18 06:58 AM
Cycling health
by CourierDriver. 09/25/18 06:08 AM
Stupidest thing you've ever done (or not done)
by Speak2Mountain. 09/25/18 06:01 AM
First Time Hyundai Owner - Coolant Confusion
by tony1679. 09/25/18 05:16 AM
European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
113 registered members (ARCOgraphite, Aichiguy, 69Torino, 1JCB, 28oz, 11 invisible), 1,704 guests, and 38 spiders.
Topics290,988
Posts4,853,832
Members66,063
Most Online3,590
Jan 24th, 2017
Switch wheel bearing right to left side? #4616105
12/27/17 07:23 PM
12/27/17 07:23 PM
usa
GerGa Offline OP
GerGa  Offline OP
usa
I have an extra front wheel bearing from the right side of my car that I replaced in error. It turned out the "grinding" sound I was hearing when taking left turns was just low steering fluid. So the bearing is fine but I have another car that might have a bad left wheel speed sensor, which would mean replacing the whole bearing/hub.
Does anyone know if it will be ok to use a bearing in the opposite direction? I'm not sure what to think of it.
Thanks
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616117
12/27/17 07:42 PM
12/27/17 07:42 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Look up the part on an auto parts retailers website and check if there is a different part for left and right.
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616119
12/27/17 07:46 PM
12/27/17 07:46 PM
Toronna
maxdustington Offline
Toronna
If it is a press in bearing there is no way you will remove it intact.
03 Jetta AWP/09A 200k kms
Edge 0W40 + Mann 719/30
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616146
12/27/17 08:26 PM
12/27/17 08:26 PM
usa
GerGa Offline OP
GerGa  Offline OP
usa
It comes as a wheel bearing and hub assembley; non servicable. The left and right are the same part number. I just wonder if its alright to switch rotation after it spent 80k miles spinning in one direction.
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616158
12/27/17 08:42 PM
12/27/17 08:42 PM
USA
mk378 Offline
mk378  Offline
USA
That should be OK. Worst that happens is there is only a short life left and you eventually have to buy a new one anyway.
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616290
12/28/17 01:29 AM
12/28/17 01:29 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
It should work fine. Precision bearings don't "take a set" to one rotation.
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616322
12/28/17 05:13 AM
12/28/17 05:13 AM
Wisconsin
Black_Thunder Offline
Wisconsin
as long as the part numbers match side to side it'll be fine. I don't know of any vehicles that use a different wheel bearing from left to right.
I'd buy Callahan autoparts if I could.
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616329
12/28/17 05:31 AM
12/28/17 05:31 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
You should be fine, but do you remember how you removed it?
If you beat the heck out of it with a hammer to get it off the first time, I would buy a new one. smile
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616356
12/28/17 06:54 AM
12/28/17 06:54 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Hmmm, that is a good question!
However, since you believe that you're in need of a wheel bearing on the other side and are willing to do the work, give it a shot, what the hey! smile Good luck!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616479
12/28/17 09:45 AM
12/28/17 09:45 AM
WV
jonnied1 Offline
jonnied1  Offline
WV
The bearing does not care which way it is rotating. Heck, you do put the car in reverse sometimes. laugh
Re: Switch wheel bearing right to left side? [Re: GerGa] #4616752
12/28/17 02:56 PM
12/28/17 02:56 PM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
I believe the main question is, can the bearings spin in the other direction after many thousands of miles of spinning in one direction, mainly at hiwy speeds and without premature wear now, due to spinning the other way?
Reverse is only used for several mph and for short durations. I believe that bearings in good condition/good lubrication won't care, one way or the other(no pun intended).
"Retired"
'15 Honda Civic LX
