Fram SureGrip coating
by mobilaltima
2 minutes 8 seconds ago
Manual transmissioned electric car
by mjoekingz28
Today at 06:45 PM
1991 Toyota Previa New JDM engine Redline
by Kurtatron
Today at 06:26 PM
8 yr old channeling John Bonham
by Toy4x4
Today at 06:02 PM
Traveller nlgi 2
by Spitter
Today at 05:33 PM
Upgrading the Kohler 7000 series air cleaner
by Patrick0525
Today at 05:08 PM
Any nano reefers here?
by RichardS
Today at 05:04 PM
ARC remanufactured Power Steering Pump
by Pajero
Today at 04:58 PM
John Deere "Easy Change" System gimmick
by SnowmanCO
Today at 04:55 PM
Oz Planstic Bag Bans - not so green.
by Shannow
Today at 04:31 PM
help me choose...
by chaindrive
Today at 04:07 PM
France F1 Grand Prix
by DeepFriar
Today at 03:16 PM
Valvoline High Mileage with maxlife tech semi-syn
by bradtech
Today at 03:16 PM
Best additive in oil to clean sludge?
by ffgb
Today at 02:19 PM
Who is a Dirt Track regular?
by thooks
Today at 01:39 PM
eco plug oil plug video is restricted
by edwardh1
Today at 01:27 PM
Political comments
by ridgerunner
Today at 01:23 PM
My Ford orange turned pink
by BeerCan
Today at 12:45 PM
Any plants/garden experts?
by maverickfhs
Today at 12:43 PM
Internet Sales Tax O.K.ed by Supreme Court
by doitmyself
Today at 12:23 PM
wil892, Spddm0n, ronw1309, Suth31, yamahaboy125
65286 Registered Users
105 registered (2015_PSD, andyd, AP9, 2strokeNorthstar, 2004tdigls, ammolab, 12 invisible), 1500 Guests and 42 Spiders online.
65286 Members
67 Forums
285731 Topics
#4615821 - 12/27/17 01:59 PM Old Volvo - oil light at startup idle...then goes
ryan2022 Offline
Loc: Peterborough
Hi guys,
I picked up the old Volvo 940 non turbo and the oil light stays on at idle.
If I give it a quick shot of gas it goes out and stays out.....until I shut the car off and start it again.
Hot or cold....the light stays on at idle....and will eventually go out on its own, but usually only after I've hit the gas.
***I changed the oil and filter from a Fram and 5w30 high mileage, to a Mann and 10w30 Dino and it didn't do it for two days.....now after some driving it's doing it again.
What are your thoughts? Oil pressure sender? Oil pump crud? Bearings?
Either way, this car has so many issues I'm thinking about buying something newer.
It's too bloody cold to work on it right now.
Thoughts?
2003 Mazda B2300 - Kendall Syn Blend 5w20
#4615832 - 12/27/17 02:07 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
rollinpete Offline
Loc: West Ma.
I'd start with the oil pressure sender...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive183k miles
Last Change;
Penn. Plat. HM 5w30
Fram xg8a, Fram CA8141
(Oil) Where would we be with out it.
#4615848 - 12/27/17 02:20 PM Re: Old Volvo - oil light at startup idle...then goes [Re: rollinpete]
ryan2022 Offline
Loc: Peterborough
Thanks. I have one on order and it's easy to get to. Fingers crossed!
To me...it wouldn't make sense that it was the bearings, as it didn't do it for a while after the oil was changed and is intermittent.
I figured if it's the engine, it should do it at idle regardless, and not go out and be fine one minutes and not the next.
#4615858 - 12/27/17 02:31 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
Johnny2Bad Offline
Loc: Saskatchewan, Canada
Oil pressure sender, Oil pump gear wear, or main bearing wear. An oil passage obstruction would increase oil pressure, so it's not that.
All normal for a high mileage engine. Some people would drop the pan and replace the pump and bearings, but as long as your oil light is going out after initially lighting, you can probably just run the thing and it will last probably as long as it was going to last in the first place. Loose main bearing clearance makes for easier winter starts, as you are in southern Ontario that might matter to you.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
#4615891 - 12/27/17 02:57 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
Sam_Julier Offline
Loc: Connecticut
Oil pressure sender.
Sam
2005 Highlander 3.3L PC Duron 0W30, 47k
1993 Volvo 245 Delo 10W30, 140k
1993 Volvo 244 Delo 10W30, 152k
#4615903 - 12/27/17 03:02 PM Re: Old Volvo - oil light at startup idle...then goes [Re: Johnny2Bad]
Linctex Offline
Loc: Waco, TX
I think the sender is working fine.
They usually fail "hard" (either 100% or 0%, nothing in between)
Originally Posted By: Johnny2Bad
Oil pump wear, or main bearing wear.
It wouldn't be the first bad oil pump I have ever changed.
#4615906 - 12/27/17 03:03 PM Re: Old Volvo - oil light at startup idle...then goes [Re: Sam_Julier]
ryan2022 Offline
Loc: Peterborough
Thanks a ton guys. Fingers crossed.
The motor has roughly 120k miles so not terribly high for these.
I'm feeling more optimistic though!
#4615962 - 12/27/17 04:04 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
Rick in PA Offline
Loc: Southeastern, PA
Oil pressure switches have hysteresis, i.e. they switch off at a slightly higher pressure than they switch on. My car switches off at ~7psi, and switches on at between 2 and 4 psi.
I had a discussion about oil pressures recently with my brother, a long time mechanic. He said it's not unusual for oil pressure to drop very low at idle, and it's generally not a problem. In fact one car manufacturer was having a problem with the oil light coming on, the factory fix was to install a pressure switch with a lower setting.
I'd say your car is operating in the dead band during idle. Once you get over the "switch off" pressure, the light stays out because it doesn't drop below the "switch on" pressure.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#4616018 - 12/27/17 04:51 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
Ethan1 Offline
Loc: 'murica
This is all just WAGs until you get a pressure gauge on it shrug
#4616029 - 12/27/17 05:03 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
ecotourist Offline
Loc: British Columbia, Canada
120,000 miles is not high at all.
I assume it's not making any funny noises? Unless the new oil pressure sending unit "fixes" the problem, I'd get a pressure gauge on it.
2000 BMW 528i 5MT
2007 Honda Accord EX-L 4Door V6 6MT
#4616044 - 12/27/17 05:19 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
OneEyeJack Offline
Loc: S California
Try a mechanical gauge?
#4616292 - 12/28/17 12:32 AM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
Brad_C Offline
Loc: Perth, Western Australia
Similar symptoms to popping an o-ring out of the oil delivery tube that runs from the pump to the block. 120k is only just run in for a b230, so it's most likely to be the o-rings, a duff oil pump (very rare on a b230) or a duff oil pressure switch. A gauge will make quick work of the diagnostics.
Because of the baffle in the sump, unfortunately you need to drop the sump to check the delivery tube as you can't get a bore scope up there.
#4628741 - 01/08/18 09:21 PM Re: Old Volvo - oil light at startup idle...then goes [Re: ryan2022]
ryan2022 Offline
Loc: Peterborough
thanks guys for all that responded. Just to follow up, it was the oil pressure switch.
i finally got it installed tonight after 2 weeks of -20 and below!!
now on to the e brake cable....brake pads.. tie rod... stereo.....locking system....ahh..I think thats it lol
Happy New year!
Ryan
