Roller Bearing Setup For Dillon Shellplate
by billt460
06/23/18 05:59 AM
Omnia - the band
by Shannow
06/23/18 02:58 AM
Guest's devices cannot connect to my WiFi
by boulderdentist
06/23/18 12:54 AM
Battery stuck in flashlight.
by Chris142
06/22/18 11:53 PM
Must read for everyone watching their diet
by JLTD
06/22/18 11:28 PM
2014 Mazda5 Valvoline Synpower 0W-20 7500 miles
by PWMDMD
06/22/18 10:54 PM
VOA Ravenol ECS 0W-20
by PWMDMD
06/22/18 10:47 PM
2020 mid-engine Corvette spy vid?!
by AZjeff
06/22/18 10:45 PM
'05 base impala. NO turn signals.FAST blinking.
by Lee4212
06/22/18 10:34 PM
Motul 15w-50, 5 Liter 4 Pack $19.42
by hatt
06/22/18 10:10 PM
High Lead Redline 5W40 thoughts? Ty
by Pajero
06/22/18 09:40 PM
Source of the Mighty Columbia River
by Snagglefoot
06/22/18 09:32 PM
Another thick/thin article to discuss
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Single Data Point: CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
55 registered (4WD, Alex_V, ArrestMeRedZ, 2002 Maxima SE, alarmguy, 11 invisible), 970 Guests and 69 Spiders online.
65299 Members
67 Forums
285817 Topics
#4615099 - 12/26/17 07:41 PM Motorcraft Syn blend
mobilaltima Offline
Loc: Golden Meadow, LA
particularly the 5W30, would it be ok to run this oil in an engine that calls for Dexos 5W30 that is out of warranty? I'm assuming that since its recommended for many Ford engines with DI and turbos, that it should be fine, but of course I need to get the bitog opinion. Besides meeting Ford specs and SN, what other specs does it meet that yall are aware of?
2006 2500 Dodge 5.9 Cummins Mobil Delvac 15W40, Fleetguard Stratapore 90k miles
Early '99 F250 ECLB 7.3 Stroker, 223k miles
#4615118 - 12/26/17 07:56 PM Re: Motorcraft Syn blend [Re: mobilaltima]
gabriel9766 Offline
Loc: Missouri
I just started working at the local Ford dealer as a line tech. I do my friends oil changes on there cars. Last month i did my friends 12 silverado 5.3L's oil change and used our bulk motorcraft 5w30. Truck burns a lil oil at 167K but is doing fine on the motorcraft 5w30.
2015 Chevy Malibu 1LT DI 2.5L I4- PPPP 0w20 and a napa gold 7060 39,829K
2007 Ford Escape XLT FWD 3.0 V6 motorcraft 5w30 bulk and a motorcraft FL500s 109,944K
#4615129 - 12/26/17 08:04 PM Re: Motorcraft Syn blend [Re: mobilaltima]
Linctex Offline
Loc: Waco, TX
It would probably meet Dexos1, but would never get the license due to being "the enemy" of GM.
#4615238 - 12/26/17 10:20 PM Re: Motorcraft Syn blend [Re: mobilaltima]
daves87rs Offline
Loc: Michigan
Know a few folks that use it that way....
Coming together is a beginning; keeping together is progress; working together is success.
Henry Ford
#4615246 - 12/26/17 10:29 PM Re: Motorcraft Syn blend [Re: Linctex]
bbhero Offline
Loc: Virginia
Not quite sure it would meet Dexos.. The average NOACK I have seen with Motorcraft 5w30 is 14.4%. And Dexos is less than 13%. Plus how would Motorcraft measure up in the other parts of testing would be interesting to see. I will say that I believe WSS-MSC-946a is actually fairly close to Dexos in a number of performance measures. Having said that if I had a GM car or truck out of warranty I would run Motorcraft synthetic blend 5w30 in them if I wanted to.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4615285 - 12/26/17 11:49 PM Re: Motorcraft Syn blend [Re: mobilaltima]
csandste Offline
Loc: St. Peters, Missouri
Two years ago I bought a '14 Buick Encore from a Ford dealer. Motorcraft 5w30 worked great for the first oil change, seems like it burned off a bit more (but not much) and stayed cleaner than the MaxLife I now use (out of warranty, now pushing 100K). When I owned a Kia Rio I used Kendall semi-syn 5w30 from Firestone and probably would still be using that if they hadn't switched to QS for their basic $20 oil change. Generally any Conoco-Phillips oil is good in my opinion.
2017 Kia Soul Plus-- Valvoline MaxLife Blend 5-20
#4615483 - 12/27/17 08:22 AM Re: Motorcraft Syn blend [Re: csandste]
littleant Offline
Loc: Vermont
My 2010 Mountaineer with the 4.0 purchased used with 55,000 miles with all service records. The oil used was Motorcraft 5W-30 SB and motor craft filter changed every 4-5,000. The inside of the valve cover (cylinder head) Was SPOTLESS.
I can't prevent getting old but I REFUSE to grow up.
2010 Mountaineer 4.0
2002 Jeep Wrangler TJ 4.0
#4615488 - 12/27/17 08:28 AM Re: Motorcraft Syn blend [Re: mobilaltima]
JohnnyJohnson Offline
Loc: Wet side WA
Well seems lots of people on here tout Motorcraft oil. Where do you buy it. Can you get full synthetic? How much is this great oil on sale?
2004 Toyota Corolla 121758
Out: QSUD 5W-30 Purolator One 5030
In: Valvoline ML 5w-30 TG4967 117530 2-8-18
2006 Duramax 74047
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73752 4-22-18
#4615553 - 12/27/17 09:20 AM Re: Motorcraft Syn blend [Re: JohnnyJohnson]
Linctex Offline
Loc: Waco, TX
Usually walmart, but it's been a long time.
Not sure on full syn.... It seems it's never on sale anymore.
#4615686 - 12/27/17 11:39 AM Re: Motorcraft Syn blend [Re: mobilaltima]
wemay Offline
Loc: Southeast Florida
5w20 and 5w30, each as synthetic blends, are sold at my local WMarts for $18.47/5qt jug.
2017 Hyundai Sonata Sport 2.4L
2013 Hyundai Santa Fe Sport 2.0T
Valvoline
#4615729 - 12/27/17 12:32 PM Re: Motorcraft Syn blend [Re: wemay]
SatinSilver Offline
Loc: OH
I usually get it at the Ford Quicklane for the $25 oil change. Which includes the oil, filter, inspection, labor, free coffee, little to no upselling. Not just with me but the other customers as well. No appointment needed so I avoid the peak times. Usually mid-afternoon, mid week works well. They service all makes and do a good job. Had tires installed there as well and they have a Hunter Balancer with a guy that knows how to use it properly. Which includes the Straight Trak and Roadforce Touch options. Which is what the local MB dealer has.
#4615767 - 12/27/17 01:03 PM Re: Motorcraft Syn blend [Re: JohnnyJohnson]
littleant Offline
Loc: Vermont
The local ford dealer here will sell it for $5.00 a quart just have to bring own jugs. I switch over to GSUD 5W-30 with a fram ultra. QSUD is the same price so went with it. Super quiet but so was the MC
