1NZ-FE Under Valve Cover - 280,000 Miles
by kschachn. 03/25/19 12:44 PM
Coolant Leak '06 300C
by Redright9. 03/25/19 12:40 PM
New truck
by double vanos. 03/25/19 12:26 PM
What pressure washer should I buy?
by wallyuwl. 03/25/19 11:27 AM
Natural Gas from Ohio Valley
by SubLGT. 03/25/19 11:18 AM
CVT Reliability and Durability
by raffy. 03/25/19 11:00 AM
comfortable seats
by redhat. 03/25/19 10:29 AM
walmart evinrude tcw-3 clearance score
by 1978elcamino. 03/25/19 10:15 AM
Mixing SN/d1G1 with SN+/d1G2?
by doyall. 03/25/19 10:14 AM
Best 2nd Phone Number App ?
by LoneRanger. 03/25/19 09:56 AM
Crud! Wix jacking up prices again! :(
by SubieRubyRoo. 03/25/19 09:53 AM
Interior "quick detailer"
by Redright9. 03/25/19 08:21 AM
Seafoam For Last 100 Miles Before Oil Change ?
by ChrisD46. 03/25/19 07:56 AM
WIX 57151XP factory filled with synthetic oil
by Donald. 03/25/19 06:58 AM
BMW Buying Guide: Every Model, Explained
by wemay. 03/25/19 05:43 AM
Double Din Android Auto Advice
by JeffKeryk. 03/24/19 11:25 PM
VW mk5 a/c intermittently works
by ram_man. 03/24/19 11:01 PM
sonusfaber, Rollo, Drifted, Jcar516, gregjr7
67614 Registered Users
125 registered members (ARB1977, 2015_PSD, 2009Edge, Altima2, aquariuscsm, Alfred_B, 8 invisible), 2,241 guests, and 64 spiders.
Topics286,399
Posts4,907,593
Members67,614
Most Online2,967
Mar 10th, 2019
static vs dynamic balancing #4614880
12/26/17 05:28 PM
12/26/17 05:28 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
i noticed that DT only put weights on the inside. on the old tires there was a tape weight in the middle as i can see the resdiue. i have a little shimmy at 68 to 70 mph.
So should i have them do a dynamic balance ?
Re: static vs dynamic balancing [Re: WhyMe] #4615008
12/26/17 07:23 PM
12/26/17 07:23 PM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
Yes
Re: static vs dynamic balancing [Re: WhyMe] #4615029
12/26/17 07:51 PM
12/26/17 07:51 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
What makes you think they did a static balance ? I don't think any shop that fits tyres would have a static balancer in the 21st Century. You can set most modern machines to fit weights to differnt parts of the rim depending on rim design.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - 5W-40 Castrol Magnatec diesel.
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: static vs dynamic balancing [Re: WhyMe] #4615043
12/26/17 08:04 PM
12/26/17 08:04 PM
Prospect, KY
spk2000 Offline
spk2000  Offline
Prospect, KY
Not sure why but Treadwright from Texas recommends static balancing on their remolded tires. I asked the guy that installed them and he said he knew what to do. He tried dynamic balancing on one just to see and it would not balance that way.
96 Grand Marquis
01 Sable LS
02 Montero
Re: static vs dynamic balancing [Re: Silk] #4615055
12/26/17 08:11 PM
12/26/17 08:11 PM
ME
eljefino Offline
eljefino  Offline
ME
Maybe he has fancy rims and you can see the "outer" weights clumped in the middle. The middle isn't a particularly great place-- to close to the center to be effective unless you use a bunch of weight.
But yes the answer is yes, go for a dynamic rebalance. They "can" do it and just ASSumed you preferred the clean look of inside weights.
Re: static vs dynamic balancing [Re: spk2000] #4615065
12/26/17 08:17 PM
12/26/17 08:17 PM
Kira Offline
Kira  Offline
Years ago a shop I knew used a spin balancer where the operator had to measure the width of the mounted tire. They used calipers on the outside of the wheel (bead to bead). Then they turned a knob. Perfect EVERY time.
So much has to do with the operator's competence....and CARE FACTOR.
Re: static vs dynamic balancing [Re: Kira] #4615187
12/26/17 10:05 PM
12/26/17 10:05 PM
ME
eljefino Offline
eljefino  Offline
ME
That's the dynamic balance. You can also find the width stamped in the rim, or just guess seven inches. If you get it wrong, you chase a little weight. But zero is zero.
BTW, a dollar bill is six inches wide.
Re: static vs dynamic balancing [Re: Silk] #4615239
12/26/17 11:23 PM
12/26/17 11:23 PM
KS
FordBroncoVWJeta Offline
KS
What makes you think they did a static balance ? I don't think any shop that fits tires would have a static balancer in the 21st Century. You can set most modern machines to fit weights to different parts of the rim depending on rim design.
Ummm nearly every Walmart TLE. We can switch static and dynamic with a touch of a button. We dynamic most of the time, but some of the "Fancy" rims dont have any place to put weights on the outside, so we static balance them. So we just clamp weight the inside, even then some of the rims wont accept that. So its just sticky waited on the outside lip of the rim. Honda rims are like that, possibly some of the hardest OEM rims to date I can think of. Thats why I like steel rims so much. They might not look the best but they are the best riding rims.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2001 Pontiac Sunfire 2.2
Re: static vs dynamic balancing [Re: WhyMe] #4615250
12/26/17 11:34 PM
12/26/17 11:34 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
static is balancing just up and down . dynamic is up/down side to side .
Re: static vs dynamic balancing [Re: spk2000] #4615424
12/27/17 08:37 AM
12/27/17 08:37 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
This makes no sense.
Could you point me to where Treadwright makes this recommendation? I don't see it on their web site. What I do see is that they pre-static balance the tires, but I'm not sure what they mean by that.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: static vs dynamic balancing [Re: WhyMe] #4615960
12/27/17 04:58 PM
12/27/17 04:58 PM
The Motor City
Kestas Online content
Global Moderator
Kestas  Online Content
Global Moderator
The Motor City
I have a 1952 Snap-On static balancer that uses a beam to determine how much weight to put on the 120 deg positions. The thinking back then was that having two balance points opposite the heavy point makes for a better balance.
Re: static vs dynamic balancing [Re: WhyMe] #4616013
12/27/17 05:48 PM
12/27/17 05:48 PM
iowa
Traction Offline
Traction  Offline
iowa
A tire could have for example, be zero statically balanced, but could have like several ounces of residual dynamic imbalance with the 2 points 180 degrees apart. Although the tire wouldn't hop, it would shimmy like crazy. The only way to truly understand it is to balance about 8000 tires by yourself, like I have in the last 16 years. You can also have a dynamically balanced tire with residual static imbalance too, causing a hop, with no shimmy. A hop happens once per revolution, and a shimmy is usually twice per revolution of the tire/wheel. As to the OP's original question, yes they definitely need to be dynamically balanced with tape weights.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: static vs dynamic balancing [Re: WhyMe] #4616774
12/28/17 03:10 PM
12/28/17 03:10 PM
Washington for now
WhyMe Offline OP
WhyMe  Offline OP
Washington for now
so i called them and ask them about the balancing. the guy just said sometime they need one sometimes two. dynamic always has 2 weights correct?
Re: static vs dynamic balancing [Re: WhyMe] #4616925
12/28/17 05:39 PM
12/28/17 05:39 PM
iowa
Traction Offline
Traction  Offline
iowa
No, it's possible to dynamic balance with one weight, but I think your shop is just another
"Flintstone tire shop" and you need to go somewhere else, and show the results to them.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: static vs dynamic balancing [Re: WhyMe] #4617155
12/28/17 09:37 PM
12/28/17 09:37 PM
ME
eljefino Offline
eljefino  Offline
ME
Calling isn't going to fix it. Going in there will.
Zero is a number, so there's a shot that one side of one tire won't need a weight.
