I have done outlets before but not this one.
Tried to simply change outdated outlet. It is connected/powered by a wall switch...but I can't figure out how.
I have two black to brass, two white to silver. Didn't work. So I broke the tab and that didn't work either.
No power to outlet or the light switch. Previously switch worked outside light and I think it just powered the bottom outlet,
not top. I never used it but wife mentioned that.
Does the order of the wires matter (which white or black on top?) and do I just break the hot side or both? I tried on hot side.
Any advice (besides calling an electrician).
Outlet
Outlet 1
Outlet
Outlet 1
