European Formula: Supertech and Mobil 1
by Snagglefoot. 09/25/18 02:19 AM
KFE brake pads?
by deoxy4. 09/25/18 01:16 AM
GM Marine Engine wont start
by Gito. 09/24/18 11:59 PM
New TV bad picture some channels part2
by raaizin. 09/24/18 10:46 PM
Another Bad PCM on a Buick 3.8L!
by clinebarger. 09/24/18 10:17 PM
Funny pictures thread
by JLTD. 09/24/18 08:40 PM
Redline 15w40: Low or Mid Saps?
by SavagePatch. 09/24/18 06:59 PM
What are these cables to?
by 99Eclipse. 09/24/18 06:44 PM
Help with parasitic draw?
by buck91. 09/24/18 05:57 PM
Costco Car Buying Program
by dkryan. 09/24/18 05:39 PM
Glass Scrub?
by buck91. 09/24/18 05:03 PM
Loosing coolant from somewhere
by NICAT. 09/24/18 03:47 PM
2010 or so Ford Fusion Sport thoughts?
by ZZman. 09/24/18 03:35 PM
My boss killed his jeep.
by Chris142. 09/24/18 02:40 PM
Moly question about walmart oils
by jayjr1105. 09/24/18 02:33 PM
Questions About 9011 Bulbs
by knerml. 09/24/18 02:23 PM
fortim, albert001, LG_Electronics, TCam, OzFrog
66063 Registered Users
29 registered members (bbhero, 2015Corolla, Anthony, Aero540T, Bailes1992, avi1777, 2 invisible), 512 guests, and 30 spiders.
Topics290,967
Posts4,853,505
Members66,063
Most Online3,590
Jan 24th, 2017
Oil for aging Canyon #4614356
12/26/17 06:29 AM
12/26/17 06:29 AM
dania bch, fl USA
rokwldr Offline OP
rokwldr  Offline OP
dania bch, fl USA
I have a GMC Canyon with 110,000 miles. It has the I5 engine. For the last 10,000 miles or so I hear more engine noise on startup. I have always used M1 10-30 syn and OCI's at around 10,000 mi. Have had the oil sent to Blackstone a few times with good results. I am just wondering if I should start using M1 10-40 high mileage. A mechanic friend says some engines just get a little more noise with age. What are your'e thoughts. Also I do tow a boat if that matters.
Re: Oil for aging Canyon [Re: rokwldr] #4614358
12/26/17 06:43 AM
12/26/17 06:43 AM
Georgia
MParr Offline
MParr  Offline
Georgia
Motor oil may not help in quieting the noise. First you need to establish where the noise is coming from. My guess is that it’s coming from the front of the engine. Wear on the timing chain tensioner is common with this engine.
2013 KIA Optima EX 2.4L. Now: QSUD 5W30 & STP S2808ML
2017 Ford Escape SE 2.0T Now: Pennzoil Platinum 5W30 & Motorcraft 910s
Re: Oil for aging Canyon [Re: rokwldr] #4614370
12/26/17 07:28 AM
12/26/17 07:28 AM
VA
Gebo Offline
Gebo  Offline
VA
I have noticed different oils can make my engines louder or quieter. And it had very little to do with how much i paid for the oil, if you get my drift. I would suggest, just for fun, to try the brand of oil you would use if you couldnt use Mobil but stay with the 10w30 grade. If that didn't help, I’d go with the Mobil 10w40 but not the high mileage unless my engine was consuming oil.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 58K
Amsoil in all engines, transmissions and differentials
Re: Oil for aging Canyon [Re: rokwldr] #4614377
12/26/17 07:40 AM
12/26/17 07:40 AM
Dallas,Tx USA
aquariuscsm Offline
aquariuscsm  Offline
Dallas,Tx USA
Try a high moly oil,like Pennzoil or Quaker State and a Fram Tough Guard. This is a legendary smooth combination.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 5W20
Re: Oil for aging Canyon [Re: rokwldr] #4614379
12/26/17 07:41 AM
12/26/17 07:41 AM
Pylesville, MD
bandz7 Offline
bandz7  Offline
Pylesville, MD
I would try pennzoil platinum 10w-30 if you can find the gen 2 version. Remember those engines are DI, and that gen 2 platinum has the lowered amounts of calcium.
1986 GMC Jimmy S-15 Chevron Delo 15W-40
2001 Corvette Z06 PU 5W-30 RT6 5W-40/MoS2
2003 VW Jetta TDI RT6 5W-40
2010 Nissan Murano PU 5W-30
Re: Oil for aging Canyon [Re: rokwldr] #4614382
12/26/17 07:45 AM
12/26/17 07:45 AM
Texas
4WD Offline
4WD  Offline
Texas
I’d try what you suggested … or M1 0w40 - that was the quietest when I did some dB meter tests … Several here point to the ad package it carries …
Re: Oil for aging Canyon [Re: MParr] #4614455
12/26/17 09:45 AM
12/26/17 09:45 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Yes, common - - and not very easy (or cheap) to fix
Re: Oil for aging Canyon [Re: rokwldr] #4614466
12/26/17 09:53 AM
12/26/17 09:53 AM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
What filter are you running? You may find that a decent filter with a silicone ADBV may lessen the startup rattle (unless you're running a cartridge).
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Oil for aging Canyon [Re: bandz7] #4614480
12/26/17 10:13 AM
12/26/17 10:13 AM
PV Az
AZjeff Offline
AZjeff  Offline
PV Az
Are you sure about the Atlas I5 being GDI? Seems too early.
86 Samurai 1.3 leftovers
14 RAV4 2.5 5W-20 PP
16 Silverado 1500 4.3, DI, AFM 5W-30 PP
The most important thing to do in your life is to not interfere with someone else's life. - Frank Zappa
Re: Oil for aging Canyon [Re: rokwldr] #4614490
12/26/17 10:21 AM
12/26/17 10:21 AM
texas
danez_yoda Offline
danez_yoda  Offline
texas
Yup. Filters will affect startup noise if the antidrainback valve is not 100%. Get a well reviewed filter wit good adbv performance and that might cure the startup noise.
As for oils. In my Tacoma, the Magntec is the smoothese and quietest oil ive run. Ive run pp pup, and toytoa oil. Just in an off sht i got the megntc and i immediately noticed and quieter engine. I might attribute it to being thicker than other 5w30 oils ive been using but it passes my ear test.
Re: Oil for aging Canyon [Re: AZjeff] #4614491
12/26/17 10:23 AM
12/26/17 10:23 AM
Texas
4WD Offline
4WD  Offline
Texas
I had a couple ~ MPFI … good little zinger motor ~ but me likes me 5.3L Canyon much better …
Re: Oil for aging Canyon [Re: Linctex] #4614494
12/26/17 10:26 AM
12/26/17 10:26 AM
Texas
4WD Offline
4WD  Offline
Texas
So would a 40 help … reckon non CAFE parts of the world would be on that
Re: Oil for aging Canyon [Re: rokwldr] #4614568
12/26/17 11:40 AM
12/26/17 11:40 AM
SF BAY AREA, CA
dogememe Offline
dogememe  Offline
SF BAY AREA, CA
I've had two Atlas motors. The 4.2 I6 in the Envoy sounded like a diesel at over 200K but ran great, the 2.9 I4 was noisy at startup too with about 70K. I would stick with 5w-30, 10w-30 seemed to make it louder. Yes, it's the timing chain, no I wouldn't worry so much about it. Use an OEM oil filter (ACDelco) with 5w-30 and see if it helps, it helped mine.
2007 Crown Vic P71 4.6 ~127K Miles, RP HPS 5W-30, RP 20-820, Daily Driver.
2010 Escape FWD 2.5 ~90K Miles, Castrol Edge EP 5W-30, Wix 51348, Rented on Turo.
Re: Oil for aging Canyon [Re: rokwldr] #4614623
12/26/17 12:35 PM
12/26/17 12:35 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It's out of warranty, so experiment away. Me, I'd switch it to 0W-30 and run a different filter (maybe try a Napa Gold (WIX), or a Baldwin) smile
Re: Oil for aging Canyon [Re: rokwldr] #4615034
12/26/17 07:54 PM
12/26/17 07:54 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
I vote for M1 high mileage 10w40
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
