Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
24 registered members (Aero540T, Bailes1992, anndel, DirtyOilGuy, bbhero, 3 invisible), 894 guests, and 36 spiders.
Topics295,007
Posts4,925,886
Members66,664
Most Online2,553
Oct 27th, 2018
Safe to drive on unplugged coolant temp sensor? #4613911
12/25/17 02:07 PM
12/25/17 02:07 PM
Virginia
Hemispheres Offline OP
Virginia
So I finally got all my exhaust leaks fixed, however Iím the process of pulling the rear manifold with the crossover pipe connected I managed to whack my coolant temp sensor and bust the female connector. Iíll be replacing it tomorrow but first I need to drive about 60-70 miles (mostly interstate).
Iím already having related issues such as both radiator fans running constantly, abrupt TCC engagement aside from running rich. I can literally smell raw fuel on startup. Other than that the temp gauge sits at 0 but Iím not having any driveability issues. My main concern is hydro/vaporlock or engine flooding/oil contamination. Are any of these a serious possibility in such a short timeframe?
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4613927
12/25/17 02:20 PM
12/25/17 02:20 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
I wonder what temp the ECM thinks the engine is at. A scan tool will reveal that. The fact that the rad fans are on indicates the ECM thinks the engine is hot but then the engine will not be running rich. Maybe the fans are not controlled by the ECM and is an unrelated problem.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4613934
12/25/17 02:29 PM
12/25/17 02:29 PM
Virginia
Virginia
Had no issue before busting the sensor, and the heater seems to feel a bit cool at 80 degrees but almost uncomfortable on my hands at 90 degrees.
It may be running lean, I do remember after warming up the engine would stumble upon startup followed by the gas smell. However Iím running 93 octane on light mods and a stock tune. 87 nets me better mileage as long as I stay out of the mid to upper RPM range. Raw fuel smell would lead me to believe itís a rich mixture.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4613942
12/25/17 02:41 PM
12/25/17 02:41 PM
Toronto, Canada
George7941 Offline
George7941  Offline
Toronto, Canada
Perhaps it is running lean and the raw fuel smell is from unburned fuel caused by misfiring.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4613983
12/25/17 03:14 PM
12/25/17 03:14 PM
Virginia
Virginia
Hmm. Could be. Not noticing any black smoke from the exhaust thatís characteristic of a rich condition but not noticing any sluggishness/timing pulled either.
However the only code was p0118. No misfire or lean/rich codes. Just checked, p0118 is high resistance. High resistance occurs in the sensor on a cold engine so Iím running rich due to the pcm thinking my engine isnít warming up.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4613992
12/25/17 03:27 PM
12/25/17 03:27 PM
ME
eljefino Offline
eljefino  Offline
ME
Scantool might not tell you the default temp... it'll probably be 68 or 180, LOL.
Is there no way to rig what's left of the wiring to the pins from the sensor? Even without the plastic you might be able to get the pins in there.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614002
12/25/17 03:43 PM
12/25/17 03:43 PM
Virginia
Virginia
Unfortunately my BAFX Bluetooth OBDII tool bit the dust. Somehow a couple resistors are loose. Still attached to the MB but wiggles a bit and wonít connect to the PCM or link via Bluetooth.
I know the thermostat opens at 185Ė190. The pigtail is fine however the sensor prongs are busted and a chunk is busted off.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614014
12/25/17 03:59 PM
12/25/17 03:59 PM
MN
TmanP Offline
TmanP  Offline
MN
(I think) The fans running nonstop is a failsafe mode where if it doesn't know what the temp is, it assumes that it is too high; it's what I would expect to happen in that case. What's the car?
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614017
12/25/17 04:06 PM
12/25/17 04:06 PM
Virginia
Virginia
2009 LaCrosse 3800
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614060
12/25/17 05:01 PM
12/25/17 05:01 PM
Virginia
Virginia
Well Iíve only gone about 35 miles and Iíve got gas in my oil. Wiped the dipstick 3 times on a paper towel and itís noticeable if you Inhale deeply
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614079
12/25/17 05:25 PM
12/25/17 05:25 PM
Virginia
Virginia
Needless to say the Buick is grounded. Tomorrow it gets a new Coolant temp sensor, CRC 5 minute engine flush along with 5 qt synthetic and a new filter.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614085
12/25/17 05:42 PM
12/25/17 05:42 PM
Virginia
Virginia
Good news is the oil isnít flammable.... yet.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614109
12/25/17 06:24 PM
12/25/17 06:24 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
Running really rich washes the oil off of the cylinder wall and significantly increases engine wear. You could wear out an engine in one or two years if you do it all the time.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Safe to drive on unplugged coolant temp sensor? [Re: JimPghPA] #4614114
12/25/17 06:30 PM
12/25/17 06:30 PM
Virginia
Virginia
Exactly why itís all getting flushed n replaced tomorrow along with the new sensor. Iím more worried about bearing failure and trans damage due to the slam shifts.
Re: Safe to drive on unplugged coolant temp sensor? [Re: Hemispheres] #4614380
12/26/17 06:43 AM
12/26/17 06:43 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
it will read -40 and run very rich.
hard on a lot of things esp the cat.
park it.
