M1 0W-40
by CT8. 09/20/18 07:37 PM
What controls timing on my 08 Honda?
by Roland. 09/20/18 07:23 PM
The real culprit about 18k
by Ablebody. 09/20/18 06:04 PM
How not to drain a pool.
by StevieC. 09/20/18 05:50 PM
Tranny fluid in Old Ferguson Tractor ?
by Rudy1999 250. 09/20/18 03:39 PM
New (old) car inbound
by BeerCan. 09/20/18 02:42 PM
Ford AWD PTU fluid always black
by Raven. 09/20/18 02:34 PM
PC not charging
by sleepery. 09/20/18 01:53 PM
Can alternators make noise?
by Benzadmiral. 09/20/18 01:21 PM
Pr 1970 Superbirds For sale - Barn Find
by user52165. 09/20/18 12:32 PM
Fram Ultra Air Filters
by StevieC. 09/20/18 12:20 PM
Change oil filter or not. Very low miles
by Martin10. 09/20/18 11:37 AM
Toslink optical audio cable (plastic) experience
by ffhdriver. 09/20/18 11:30 AM
A woman I work with wants an affair with me!
by Drew99GT. 09/20/18 11:08 AM
ACEA A5/B5 REQUIREMENTS
by Kjmack. 09/20/18 10:56 AM
Carolina Reaper hot peppers
by gman2304. 09/20/18 09:54 AM
New Fram air filter?
by irv. 09/20/18 09:15 AM
FarmerDude, Bman90, Alday714, Joephoto, tlelectric
66021 Registered Users
110 registered members (Ablebody, AdRock, 4WD, ABomb369, 2015_PSD, 15 invisible), 1,703 guests, and 69 spiders.
Topics290,730
Posts4,849,237
Members66,021
Most Online3,590
Jan 24th, 2017
Limitations of Battery Conductance Testing. #4613907
12/25/17 03:03 PM
12/25/17 03:03 PM
Toronto, Canada
George7941 Offline OP
Toronto, Canada
I have a Midtronics PBT-200 tester, about twelve years old. It works well on my Sierra Size 78 battery. A new battery will read around 720 CCA and will lose about 50 CCA every year. I replace the battery when the CCA drops to around 500.
However it does not detect loss of capacity in Size 31 HD truck batteries. The batteries only last about three years because of cycling caused by electric motor powered hydraulic tailgates. I tested the old batteries and they read about 950 CCA each. New they register around 1000 CCA. However, applying a 25A load reveals that the Reserve Capacity had degraded to about 80 minutes from the rated capacity of 185 mins.
I replaced the batteries. Maybe conductance testing technology has improved in the twelve years since I bought the tester.
Just checked the Midtronics site and they rate the PBT-200 for up to 850 CCA. My tester displays 1000 CCA on new batteries.
2006 GMC Sierra 4.3l, NV3500,G80 , Mobil 1 5W30, Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4613945
12/25/17 03:43 PM
12/25/17 03:43 PM
CA
spackard Offline
spackard  Offline
CA
I don't know. I've had a store's (Batteries Plus) Midtronics check of my car's battery test good, but I replaced it because it wouldn't start the car after sitting overnight. That was earlier this year.
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4613950
12/25/17 03:45 PM
12/25/17 03:45 PM
CA
The Critic Offline
The Critic  Offline
CA
There is a joke we have about battery testers. You use conductance testers to upsell batteries, but you use a load tester to test batteries.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4613988
12/25/17 04:20 PM
12/25/17 04:20 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Dunno about your tester...but if you have liftgates...I started buying the Alliance branded AGM group 31's from Freightliner a few years ago. Deka makes them. If you buy the 8A31 version your battery problems will disappear. In applications we used to get 12-18 months out of, we now get 4 years plus. Usually between 175 and 200 CAD.
HDEO in Diesel Engines. No spark plugs here.
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4614029
12/25/17 05:25 PM
12/25/17 05:25 PM
Toronto, Canada
Toronto, Canada
Alliance/Deka is what I buy, specifically AE1131XMF. The 8A31, being AGM, is expensive compared to the 1131. I just bought five of the 1131 at $116.xx each and I got $25.50 each for the old ones from my friendly metal recycler, bringing the cost down to $91 each. I get three years of dependable service out of them and replace them every three years. From the long term cost standpoint it is significantly less expensive to use the 1131.
I have tried the dual duty (starting/cycling) batteries (31S9D, I think) from Traction before and got an extra year of life but that could not make up for the extra cost.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4614065
12/25/17 06:07 PM
12/25/17 06:07 PM
Reno, NV
redbone3 Offline
redbone3  Offline
Reno, NV
A load test is the only surefire test of a battery.
2014 Passat Wolfsburg, 1995 Miata.
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4614359
12/26/17 06:45 AM
12/26/17 06:45 AM
UK
slybunda Offline
slybunda  Offline
UK
Battery internal resistance test is the best way to check batteries.
https://youtu.be/Oi8sUE9XCgA
1995 Ford Fiesta 1.6i 16v Si
2000 Toyota Celica 1.8 VVTL-i
2007 Toyota Aygo+ 1.0i
Re: Limitations of Battery Conductance Testing. [Re: slybunda] #4614603
12/26/17 12:19 PM
12/26/17 12:19 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I wonder what the results would have been had he used a carbon pile load tester at 1/2 CCA for 15 seconds. His load tester is probably 50 or 100 amp load.
2015 Ford F250 w/Powerstroke
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4614687
12/26/17 01:47 PM
12/26/17 01:47 PM
Nowhere NM
Smoky14 Offline
Smoky14  Offline
Nowhere NM
I've found carbon pile testers to be extremely accurate in determining battery condition. These newer load testers lack the ability to truly load test a battery.
YMMV
Smoky
99 Acura 2.3CL 5speed MT
12 Ford Fusion 2.5S 6speed MT
05 Suzuki Bandit 1200.
Re: Limitations of Battery Conductance Testing. [Re: Smoky14] #4614729
12/26/17 02:42 PM
12/26/17 02:42 PM
Toronto, Canada
Toronto, Canada
My issue with load testers is that it is only a pass/fail type of test. It does not tell you how close the battery is to failing.
The 100 amp hand held load testers do not help much in evaluating a car batterys health. They are adequate for checking small batteries like a motorcycle battery.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4614849
12/26/17 05:09 PM
12/26/17 05:09 PM
UK
slybunda Offline
slybunda  Offline
UK
How do these conductance testers work? How do they work out the internal resistance?
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4615077
12/26/17 08:28 PM
12/26/17 08:28 PM
Toronto, Canada
Toronto, Canada
My Midtronics loads the battery with short (milliseconds) pulses of current of about 300 ma. It measures the voltage drops across the battery arising from the load and calculates CCA from the data. The tester uses Kelvin clamps to ensure accuracy of the voltage drop readings.
1987 BMW R80 - sold
2015 Honda CBR300R
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4615108
12/26/17 08:47 PM
12/26/17 08:47 PM
Winnipeg MB CA
Number_35 Offline
Number_35  Offline
Winnipeg MB CA
My load tester is similar to the one the Mercedes specialist in the linked video used. It's got an analogue scale, and I check the battery in each vehicle before winter. Low in the green is not as good as higher, and as soon as a battery drops into high yellow I'll replace it. Both of our vehicles are '09s, each w/ the original battery, and both were still in the green as of a couple of months ago,so I imagine both will be good through the winter but that I'll be replacing them in the next year or so.
Re: Limitations of Battery Conductance Testing. [Re: George7941] #4615263
12/27/17 12:01 AM
12/27/17 12:01 AM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Ya...my first foray into the AGM world I did the dual purpose route...and got similar lousy results (the 9A31's). Once I went to the 8A31's it got good. My cost on the 8A's is $175..we use scrap money to fill the beer fridge so it stays off book whistle
Three years of liftgate work on the batteries you're buying is excellent...you guys must know the value of clean connections and good cables very well!
Re: Limitations of Battery Conductance Testing. [Re: PiperOne] #4615407
12/27/17 08:17 AM
12/27/17 08:17 AM
Toronto, Canada
Toronto, Canada
I keep the cable terminals clean. Every time I disconnect the cables I scrape off any corrosion, spray down with battery terminal cleaner, renew the felt washers and spray again with battery terminal protector after reconnecting.
Since I am the only one who works on the trucks, I would have only myself to blame for corroded terminals, stripped drain plugs, stripped lug nuts etc. These things just do not happen because I am very careful and methodical.
Here is the battery Terminal Cleaner
http://crc-canada.ca/automotive/battery/battery-cleaner-with-acid-indicator-312-grams.html
Terminal Protector
http://crc-canada.ca/automotive/battery/battery-protector-213-grams.html
I tried dielectric grease + baking soda paste, highly touted on Bitog, but found it to be ineffective.
1987 BMW R80 - sold
2015 Honda CBR300R
