CASIO G-SHOCK
by Char Baby. 04/18/19 05:23 AM
Castrol Magnatec $19.44 5QT
by Nickdfresh. 04/18/19 05:15 AM
Semi Synth Gear Oil Seperation?
by J_ODIE. 04/18/19 04:26 AM
Acura/Honda Oil Consumption
by artbuc. 04/18/19 04:15 AM
xW-HTHS grade selection
by OilUzer. 04/18/19 03:28 AM
Oil color different cool versus hot?
by FordCapriDriver. 04/18/19 02:56 AM
Oil Choices
by tiger862. 04/18/19 01:12 AM
Honda/Acura HTO-06
by blackdiamond. 04/17/19 11:24 PM
Remote transmission filter newbie questions
by Zahndkile. 04/17/19 09:31 PM
Ford 3.0L transmission problem
by taztheman. 04/17/19 08:24 PM
PQIA Tax Day 2019 VOA's
by UG_Passat. 04/17/19 08:21 PM
bubbling paint/rust repair
by greenjp. 04/17/19 07:32 PM
2016 ford fusion lug nut size and torque spec?
by Corollaman. 04/17/19 07:32 PM
Better, Worse, or All The Same?
by 2015_PSD. 04/17/19 06:55 PM
Uber/Lyft Destroyed The Taxi Industry.
by Willclark. 04/17/19 06:39 PM
2012 Accord,Pennzoil Platinum High Mileage 10W30
by aquariuscsm. 04/17/19 06:26 PM
Kohler Command Twin 18HP - not charging
by 92saturnsl2. 04/17/19 06:26 PM
W_huisman, Arcoril, SpeedThrills, Lg9977, Slikk726
67838 Registered Users
66 registered members (4WD, antik, 87sammy, Anthony, 2015_PSD, A1O, 7 invisible), 797 guests, and 24 spiders.
Topics287,674
Posts4,932,037
Members67,838
Most Online2,967
Mar 10th, 2019
Freedom Munitions #4613760
12/25/17 11:21 AM
12/25/17 11:21 AM
Cajun Country, La.
BlueOvalFitter Offline OP
Cajun Country, La.
Anyone else buy from FREEDOM MUNITIONS? I bought (6) boxes of .40 cal. (4 boxes) 180 gr. XTP & (2 boxes) FMJ 180 gr. You can choose NEW, or RECONDITIONED type ammo. Your first order is FREE shipping. The the reason I won't buy from them any more is because they have RIDICULOUSLY HIGH shipping charges! shocked2
https://www.freedommunitions.com
2007 F150, 4.2 V6
Havoline HM 5W20, NAPA GOLD FIL-1516 MC FL-400S
Re: Freedom Munitions [Re: BlueOvalFitter] #4613764
12/25/17 11:36 AM
12/25/17 11:36 AM
Glendale, Arizona
billt460 Online content
billt460  Online Content
Glendale, Arizona
That is always the case with Internet purchased ammo. If the prices seem too good to be true, it's usually because they make it up on the back end in shipping costs. You have to research and figure the cost per round DELIVERED. Because that is often not how it's advertised.
Re: Freedom Munitions [Re: BlueOvalFitter] #4613766
12/25/17 11:37 AM
12/25/17 11:37 AM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Like you I used them one time for the free shipping. Their shipping is also painfully slow. Iíve started using Outdoor Limited since theyíre local and I can pick it up.
Re: Freedom Munitions [Re: BlueOvalFitter] #4613784
12/25/17 12:01 PM
12/25/17 12:01 PM
Cajun Country, La.
Cajun Country, La.
When I want to buy in bulk, like my 5.56/.223 ammo, my son and I go in together and order it from SGAmmo.com
When I just want a few boxes of ammo I buy from ACADEMY. They offer FREE shipping $25 and over. And, they have GREAT prices on ammo. Shipping is usually 2 days, 3 at the most.
http://www.sgammo.com
https://www.academy.com/shop/browse/shooting/ammunition
2007 F150, 4.2 V6
Re: Freedom Munitions [Re: BlueOvalFitter] #4613802
12/25/17 12:16 PM
12/25/17 12:16 PM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
The problem I have seen with their brand of 9MM ammunition and/or other brands they sell is they use "stepped" cases (not sure about other calibers). For a those who shoot and toss, it is not a big deal, but for reloading they are garbage for two reasons:
1. Many decapping rods will not pass through the internal shoulder.
2. The case can separate at the step (it is a stress point) leaving a sleeve of brass in the chamber of the weapon which can render it "dead" at the range (if one does not have tools) and it can be very difficult to remove from some chambers.
I do not shoot it, but others have had good luck with their ammunition.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Purflux filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Freedom Munitions [Re: BlueOvalFitter] #4613813
12/25/17 12:35 PM
12/25/17 12:35 PM
N.C.
gman2304 Offline
gman2304  Offline
N.C.
Re: Freedom Munitions [Re: BlueOvalFitter] #4613818
12/25/17 12:41 PM
12/25/17 12:41 PM
US
bunnspecial Offline
bunnspecial  Offline
US
I bought from them a number of years ago-a few hundred rounds of 9mm, a few hundred of 38 special, and maybe 100 357 Mags. That was before I started reloading. I will say all went bang and was as accurate as WWB, albeit probably a bit dirtier.
At the time, I was planning on starting to reload, so I bought both the 38 and 357 in new brass. Both were in Starline brass, and the 357 Mag was nickel plated. I'm still using the brass.
I don't reload 9mm and think I gave away all the brass. As I recall, it was a mix of common headstamps- F.C, Blazer, Winchester, R-P.
I'd be unhappy to get brass that looks like the above-it looks like a pain to reload plus would pretty well lock you in to only one weight of bullet.
I'll also mention that I bought bullets from them once-158gr plated .358. They were okay, but once I paid shipping they ended up being about the same price as Berry's from Cabelas locally and a bit more expensive than some other plated bullets bought locally.
2010 Lincoln MKZ-Mobil 1 5W-30
1970 MG MGB Roadster-Valvoline VR-1 20W-50
Re: Freedom Munitions [Re: BlueOvalFitter] #4613910
12/25/17 03:05 PM
12/25/17 03:05 PM
Glendale, Arizona
Glendale, Arizona
2015_PSD,
Is that a washer pressed into the case to a given depth? Or is it a stepped sleeve that contacts the bottom of the case to prevent bullets from seating deeper into the case from recoil? I'm having a hard time visualizing it. The case on the right looks as if the "washer" has come loose, and fallen out. The flash holes look a mile deep, and look like funnels. Or is that an optical illusion? What am I not seeing?
Re: Freedom Munitions [Re: BlueOvalFitter] #4613931
12/25/17 03:26 PM
12/25/17 03:26 PM
OR, USA
bsmithwins Offline
bsmithwins  Offline
OR, USA
That brass looks like no other centerfire brass Iíve ever seen in person or in a picture. Possibly from some kind of training round like Simunition?
BSW
Re: Freedom Munitions [Re: billt460] #4613991
12/25/17 04:26 PM
12/25/17 04:26 PM
Houston, TX
Houston, TX
Originally Posted By: billt460
2015_PSD,
It is stepped (but not a sleeve--it is all one piece) and the one piece of brass that does not have the step is another brand. The ID of the case is smaller below the step and the wall is much thicker. Visualize a case where the ID of the area below the step is smaller and the upper part drilled out to a larger ID.
The concept is to prevent setback of the bullet and while it does do that, it comes at a cost.
Does that help?
Re: Freedom Munitions [Re: BlueOvalFitter] #4614031
12/25/17 05:28 PM
12/25/17 05:28 PM
Elizabethtown, Pa
Al Offline
Al  Offline
Elizabethtown, Pa
https://www.targetsportsusa.com
Always free shipping on 1000 rounds.
Re: Freedom Munitions [Re: BlueOvalFitter] #4614032
12/25/17 05:28 PM
12/25/17 05:28 PM
Glendale, Arizona
Glendale, Arizona
Yes, and thanks. So just to be clear, if you sectioned the case below the step, would the case wall be considerable thicker? If so that would be useful in shooting high pressure +P+ loads in an unsupported chamber. No case bulge, or risk of a case being blown out. Assuming you would be able to get enough powder in it due to the thick case walls.
Re: Freedom Munitions [Re: BlueOvalFitter] #4614040
12/25/17 05:42 PM
12/25/17 05:42 PM
US
bunnspecial Offline
bunnspecial  Offline
US
The more I think about that case design, the more it worries me.
As I'm sure we all know, a brass case by itself is not very strong. The strength comes from it forming to the chamber and effectively acting as a gasket to keep all the combustion gases inside the chamber. Of course, the "springiness" also lets it spring back enough to be extracted.
I know setback is always a concern in bottom-feeders, but the "step" looks like it would reduce case volume by a lot more than a few millimeters of setback.
I'm sure Freedom has "recipes" to load them safely, but with the case volume reduced that much I'd be afraid to even try loading the case myself. You'd need to either use a very slow powder or reduce the amount significantly to keep from getting crazy pressures. The former(using a slow powder) often doesn't work that well in "normal" bottom feeder cartridges as it may not reach peak pressure fast enough to cycle the action reliably.
Re: Freedom Munitions [Re: billt460] #4614048
12/25/17 05:52 PM
12/25/17 05:52 PM
Houston, TX
Houston, TX
Here you go:
Re: Freedom Munitions [Re: BlueOvalFitter] #4614076
12/25/17 06:17 PM
12/25/17 06:17 PM
US
bunnspecial Offline
bunnspecial  Offline
US
Wow-that's a SERIOUS reduction in case volume-not only does it have the step but the case head is a lot thicker.
I'd be interested in knowing what the actual volume is.
