Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Need Expert TIG Welder, Toronto Area
by George7941. 03/18/19 01:44 AM
Cadillac CT5 Revealed
by E365. 03/18/19 01:36 AM
Scored free 0w-20 semi synthetic
by pdxglocker9mm. 03/18/19 01:13 AM
TomRx, Ozdave, Rod1701, Arbitrader, Djdecember
67545 Registered Users
108 registered members (ABerns, 65convertible, ammolab, addyguy, 928, 8 invisible), 2,286 guests, and 60 spiders.
Topics286,013
Posts4,900,717
Members67,545
Most Online2,967
Mar 10th, 2019
Truck starts harder after being plugged in #4613495
12/25/17 12:42 AM
12/25/17 12:42 AM
El Oeste
HawkeyeScott Offline OP
El Oeste
Buddy’s 2002 Toyota Tundra 4.7. He’s using a lower radiator hose heater to help with cold starts this winter. But the truck has been very hard to start after being plugged in. He says it took 45 seconds of on/off cranking to start today. Water temp is just off the cold mark during hard starts. Truck starts fine when not plugged in.
Seems like the heater is doing something counterproductive. Any ideas what is going on? Web seems void of answers on this issue.
Here’s what he’s using: https://north40.com/kats-heaters-lower-r...AiABEgKy7vD_BwE
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4613511
12/25/17 01:07 AM
12/25/17 01:07 AM
USA
jsfalls Offline
jsfalls  Offline
USA
PCM uses the coolant temp sensor to adjust fuel mixture so may be too lean to start normally. Needs a richer mixture to start when cold
2012 Mazda 5 - Havoline 0W20, Idemitsu ATF
2002 Buick Century (beater) - Whatever is cheapest
2003 Honda Civic EX - Honda Genuine oil & ATF
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4613539
12/25/17 03:34 AM
12/25/17 03:34 AM
Bremerton, WA
DemoFly Offline
DemoFly  Offline
Bremerton, WA
Dense air with lean fuel. He's bypassing fuel enrichment. He has a warm radiator/Coolant-temp-sensor and a cold engine block.
He'd have more success with a sump heater if his goal is engine protection. Those engines reach operating temperature within a couple of miles.
Pushrods, please.
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4613543
12/25/17 03:47 AM
12/25/17 03:47 AM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
Gotta go with an oil sump heater.
Re: Truck starts harder after being plugged in [Re: jsfalls] #4613559
12/25/17 05:10 AM
12/25/17 05:10 AM
NY
demarpaint Offline
demarpaint  Offline
NY
Bingo. I'd try an oil pan heater, my bet is he will probably eliminate the problem.
God Bless Our Troops
Re: Truck starts harder after being plugged in [Re: jsfalls] #4613641
12/25/17 08:20 AM
12/25/17 08:20 AM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Yup
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4613677
12/25/17 09:19 AM
12/25/17 09:19 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
Interesting.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4613741
12/25/17 10:59 AM
12/25/17 10:59 AM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
How cold is the temp that you feel outside heat is needed to start the truck?
Thick oil is better grin2
Re: Truck starts harder after being plugged in [Re: andyd] #4613790
12/25/17 12:04 PM
12/25/17 12:04 PM
wi
dave123 Offline
dave123  Offline
wi
I like to know also -20F might be the temp I'd start looking to plug in. I have started at near -30F on a few vehicles not plugged in overnight slow but ok.
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4614083
12/25/17 06:35 PM
12/25/17 06:35 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
I'll pull a Merk and say he got his plug backwards, reversing the polarity, causing the block heater to cool things off. wink
In all seriousness, the oil pan heater might be a good suggestion. These little "problems" have started to manifest themselves here over the past number of years, too.
Plain, simple Garak.
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4614090
12/25/17 06:54 PM
12/25/17 06:54 PM
Indiana
5AcresAndAFool Offline
Indiana
I had the same problem about 20 years ago with a 1987 Ranger 2.9L EFI. I put in a 1200 or 1500 watt tank heater that hooked to the block using a fitting on the side of the engine block and one of the heater hoses, used convection to heat the block. It worked well, but when it got around zero what would happen is the ECM was reading a higher coolant temperature and using a fuel mixture for a warmer start.
It acted up and started hard.
Never did try to find away around it, but I was going to wire a switch that would bypass the coolant temperature sensor and hook to a resistor that was equal to the resistance of a coolant temperature reading at zero.
Re: Truck starts harder after being plugged in [Re: HawkeyeScott] #4614790
12/26/17 03:55 PM
12/26/17 03:55 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
It makes perfect sense to me. Plug in htr is fooling ECU into thinking the engine is warm. Wabbout a toggle switch to open lead to ECU ? Or an electric thermo time switch Set it for 10 seconds of open before normalizing. Kinda sorta what the earlier 528e s used in the cold start stuff.
