Just curious, as my truck now has around 65,000 km's, I'd like to do some fluid changes. What is recommended or can be used in my diffs and transfer case? I like Amsoil severe gear but I am unsure about compatibility and if I need a friction modifier with my posi/limited slip rear diff? I use Mobil in my sleds chain cases and have used that previously in my other vehicles diffs so that is also an option.
Also, seeing as I am overdue for a plug change (Recommended at 48,000 kms) what are some good plugs to use (I need 16!) that are going to last a lot longer than 48,000 kms?
The manual says to remove and inspect them but if I am going that far, they are going to be replaced, end of story.
Also, while I'm at it, what other recommendations does anyone suggest that I do?
Thanks.
Thanks.
