CVT Discussion
by Sierra048
06/20/18 08:28 AM
Can't get Unifi AP V2 to work on TDS...
by WhizkidTN
06/20/18 07:34 AM
Need mini grease gun
by Duffyjr
06/20/18 07:02 AM
Mazda 6 O2 sensor - CA emission
by Chester11
06/20/18 06:57 AM
Brake Bleeder
by supton
06/20/18 06:56 AM
As close to blowing out as you can get
by wwillson
06/20/18 06:04 AM
changing tranny filter
by Dennisistheman
06/20/18 06:04 AM
From small things...
by Silk
06/20/18 05:57 AM
Anyone signing up for the Space Force
by Shannow
06/20/18 03:58 AM
Pennzoil Platinum at Walmart
by TheLawnRanger
06/19/18 11:21 PM
Mopar OEM and Fram Ultra Oil filters, '18 Jeep JL
by IndyFan
06/19/18 10:45 PM
What’s the odds..
by Eric Smith
06/19/18 09:51 PM
Who can relate?
by Reddy45
06/19/18 09:43 PM
No more oil changes
by goodtimes
06/19/18 09:19 PM
Separating toddlers from their parents?
by fdcg27
06/19/18 08:50 PM
gm 8.6 truetrac
by Spitter
06/19/18 08:45 PM
New addition to my garage: 2000 Corvette FRC
by MrHorspwer
06/19/18 08:34 PM
Rockauto 5% off
by Spitter
06/19/18 08:32 PM
fumoto oil valve
by Santo
06/19/18 08:19 PM
Grand solar minimum...
by ridgerunner
06/19/18 07:57 PM
Theraven, battleman13, Shassis, Santo, aligoodn
65276 Registered Users
104 registered (Aero540T, 2004tdigls, andyd, 2009Edge, aquariuscsm, 12 invisible), 1269 Guests and 41 Spiders online.
65276 Members
67 Forums
285637 Topics
Page 1 of 2 1 2 >
#4613284 - 12/24/17 05:51 PM Can't bleed PS system.
dlundblad Online   happy
Loc: Indiana
Merry Christmas BITOG.
I can't seem to bleed the Jeep's PS system. Lock to lock and partially lock to partially lock easily 50+ times with the wheels raised and there's still air coming out of the reservoir.
I have a new high pressure hose, but the original low pressure hose. Perhaps the old constant tension clamps aren't sealing and allowing some air into the system? Each burp creates some decent air bubbles.
03 Jeep WJ 4.0 199k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 145k Rotella T5 10w30 Fram TG3980
#4613288 - 12/24/17 05:57 PM Re: Can't bleed PS system. [Re: dlundblad]
Silk Offline
Loc: New Zealand
Engine off, lock to lock with the road wheel, not the steering wheel.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
#4613299 - 12/24/17 06:11 PM Re: Can't bleed PS system. [Re: Silk]
Loc: Indiana
Maybe I am just tired, but I don't understand.
#4613308 - 12/24/17 06:22 PM Re: Can't bleed PS system. [Re: dlundblad]
Silk Offline
Loc: New Zealand
You must be tired.
#4613312 - 12/24/17 06:30 PM Re: Can't bleed PS system. [Re: Silk]
Loc: Indiana
Originally Posted By: Silk
You must be tired.
So grab a tire and move it lock to lock?
How’s this different than just using the steering wheel?
#4613315 - 12/24/17 06:34 PM Re: Can't bleed PS system. [Re: Silk]
CT8 Offline
Loc: Idaho
You must be tired.
grin
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4613322 - 12/24/17 06:54 PM Re: Can't bleed PS system. [Re: dlundblad]
eljefino Offline
Loc: ME
Why not lower onto the tires with some normal weight and try again?
#4613350 - 12/24/17 07:22 PM Re: Can't bleed PS system. [Re: dlundblad]
Ethan1 Offline
Loc: 'murica
Apply vacuum to the reservoir with a hand pump
#4613352 - 12/24/17 07:27 PM Re: Can't bleed PS system. [Re: dlundblad]
Silk Offline
Loc: New Zealand
Yes, it's more likely to cavitate if you use the steering wheel. Just slowly lock to lock a dozen times with a road wheel. And engine off, cavitation again.
Edited by Silk (12/24/17 07:28 PM)
#4613420 - 12/24/17 09:14 PM Re: Can't bleed PS system. [Re: dlundblad]
HoosierJeeper Offline
Loc: WI
What happens is the return line gets microscopic cracks in it and sucks air in through those. So that being said, it'll be kind of hard to get all the air out. I recently put a new Dorman cooler on my Liberty and it was sucking in air still, ended up double clamping it and that made a difference for sure. I'd get some 3/8" trans tubing and make some new return lines for the cooler, double clamp and be done.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
#4613538 - 12/25/17 02:33 AM Re: Can't bleed PS system. [Re: dlundblad]
OneEyeJack Offline
Loc: S California
Is there a tiny bit of moisture in your p/s fluid?
#4613553 - 12/25/17 03:42 AM Re: Can't bleed PS system. [Re: dlundblad]
Kamele0N Offline
Loc: Slovenia
One method...
https://youtu.be/A0fiZCHz5ew
2nd one slightly different...
https://youtu.be/VuPALAnHjRM
2011 Hyundai i30 1.4 CVVT Shell Helix Ultra 5w40
1997 Toyota Landcruiser KZJ95 3.0 TD various 10w40
#4613609 - 12/25/17 06:05 AM Re: Can't bleed PS system. [Re: Kamele0N]
Loc: Indiana
One method...
I am not trying to do a flush.
I replaced my high pressure hose and now there's air in the system.
#4613614 - 12/25/17 06:12 AM Re: Can't bleed PS system. [Re: Silk]
Loc: Indiana
3 posts in and I am still scratching my head. Thanks anyways.
#4613683 - 12/25/17 08:24 AM Re: Can't bleed PS system. [Re: OneEyeJack]
pcoxe Offline
Loc: South Carolina
One drop of water can create a lot of foam and looks like air. And water tends to settle at the lowest level so it's difficult to remove.
Page 1 of 2 1 2 >
