64829 Members
68 Forums
282235 Topics
#4613164 - 12/24/17 02:45 PM
Re: AC Delco filters. Any good?
[Re: irv]
Loc: Wet side WA
Equipped with 98% multi-pass filtering efficiency at 25-30 microns.
They already fail my 20 micron requirement.
2004 Toyota Corolla 119727 Out: QSUD 5W-30 Purolator One 5030 In: Valvoline ML 5w-30 TG4967 117530 2-8-18 2006 Duramax 73752 Out: T6 5W-40 M1-303 In: T6 5W-40 XG9100 73752 4-22-18
#4613178 - 12/24/17 03:10 PM
[Re: JohnnyJohnson]
Loc: North Carolina
They already fail my 20 micron requirement. Yup, that 0.000393701 Inch delta is clearly the difference between a long and happy service life and a premature destiny as a rebuilder's core. #rolleyes #mechanicalhypochondria My opinion: High confidence that the filters in question are suitable and fit for purpose.
"Sportbikes have evolved from an axe into a scalpel. Problem is, the average sportbike buyer is more lumberjack than surgeon." -Richard Pollock
#4613184 - 12/24/17 03:19 PM
[Re: WANG]
Loc: Wet side WA
They already fail my 20 micron requirement. Yup, that 0.000393701 Inch delta is clearly the difference between a long and happy service life and a premature destiny as a rebuilder's core. #rolleyes #mechanicalhypochondria My opinion: High confidence that the filters in question are suitable and fit for purpose. Actually I'm waiting for the next filter Manufacturer to drop to 10 or 15 microns. Your oil is only as good as your filter keeps it. All debris causes wear.
#4613187 - 12/24/17 03:21 PM
[Re: irv]
Loc: Spring,Texas
Where I work have a fleet of GM vans/trucks with 4.8 V8s all running between 120K - 250K miles on them. That's all they've run with AC Delco filters and dealer oil since 2009. IMHO I'd say they work . Use them with confidence.
16 Civic-M1 EP 0W-20, TG7317 14 Civic-M1 EP 0W-20, XG7317 05 Chevy 2500HD-QSUD 10W-30, XG3675 97 Accord Wagon-Havoline Conv 5W-30, PH3593A
#4613196 - 12/24/17 03:32 PM
[Re: irv]
Loc: Outer Banks, NC
Personally I'd shy away from any AC Delco oil filter that ends with an "e." Ecore is not for me. The others are fine for regular change intervals, not extended ones.
"What is it, the first hole I dug?" 2017 Honda Odyssey SE 2013 Honda Accord LX 2007 Honda Ridgeline RTS 2007 Infiniti M35
#4613240 - 12/24/17 04:25 PM
[Re: irv]
Loc: A Highway Near You
I've used them...in extended service too...no issues and nothing of note on any sample reports. Good filters.
HDEO in Diesel Engines. No spark plugs here.
#4613248 - 12/24/17 04:49 PM
[Re: NormanBuntz]
Loc: Campbellsville, KY
Personally I'd shy away from any AC Delco oil filter that ends with an "e." Ecore is not for me. The others are fine for regular change intervals, not extended ones. This.
I like Chevy and Valvoline.
'13 Cruze, 1.4T, 110K '85 GMC C3500, 454, 130K '82 Mercedes 300CD, OM617 turbo, 165K '67 Suburban, 350, 331K
#4613277 - 12/24/17 05:41 PM
[Re: irv]
Loc: High Country of Western NC
I've been a member of BITOG long enough to shun any ecore filter. With that said, my new truck had the standard GM provided first two dealer services on the house. Plus, of course, it came with a Delco filter from the factory. It hasn't blown up yet. Going forward I'll probably do the Wix 57045 or Fram Ultra XG10575. The Wix is actually less expensive than the Delco, and the Fram only a $1 or so more. I don't necessarily think Delco's are bad, just better filters for less or slightly more. If I could find the traditional non ecore PF63's I'd be totally fine with them. Those are more scarce than hen's teeth, though.
2017 Subaru Impreza 2.0 QSUD 0W-20/Wix 57055 2017 GMC Sierra Denali 5.3 AC Delco 0W-20/AC PF63E 2017 Subaru Forester 2.5 Idemitsu 0W20/Subaru filter
#4613326 - 12/24/17 06:57 PM
[Re: irv]
Loc: Port Orange, Florida
I don't like the E cores. Other than that I would say they are as good as any, better than many.
2006 Dodge Ram 2500 Hemi 4x4 2016 Dodge Challenger Scat Pack
#4613351 - 12/24/17 07:22 PM
[Re: JohnnyJohnson]
Loc: MN
Actually I'm waiting for the next filter Manufacturer to drop to 10 or 15 microns. Your oil is only as good as your filter keeps it. All debris causes wear. The only oil filter that has a chance at scrubbing out significant amounts of sub-10micron junk is the MicroGreen oil filter. http://www.microgreenfilter.com/ MicroGreen uses a small disc-filter inside to slowly clean out extra small particles over time, and the other parts of their oil filter are like an M1 syn-blend or Fram ToughGaurd. Although, the Fram Ultra is 80% efficient at 5 microns according to a bitog post I read from a Fram engineer posted a long time ago.
#4613451 - 12/24/17 09:45 PM
[Re: oil_film_movies]
Loc: Waco, TX
Although, the Fram Ultra is 80% efficient at 5 microns according to a bitog post I read from a Fram engineer posted a long time ago. I haven't seen any research data that supports the Microgreen actually does what it claims.
"The evidence demands a verdict". (Re:VOA)"it's nearly impossible to actually know the particular additives that are in there at what concentrations."
#4613568 - 12/25/17 04:33 AM
[Re: Linctex]
Loc: MN
I haven't seen any research data that supports the Microgreen actually does what it claims. If you don't believe MicroGreen claims or don't understand parallel path filtration, and you can't see for yourself the internal micro-filter disc inside the MicroGreen, then you should use a Fram Ultra. The Ultra does arguably as well using a double thick synthetic glass fiber media. ...unless.... If you don't believe Fram's claims or can't see the dual-layer media of the Fram Ultra, then any oil filter you see is the same to you.
#4613658 - 12/25/17 07:56 AM
[Re: irv]
Loc: Houston, Texas
IRV,
There are many GM vehicles with high mileage running AC Delco filters.
The applications using an eCore with the nitrile combo valve would be of more concern because they may lose ADBV function before the oil is ready to be changed. A separate bypass is better.
The cage is more robust than when first introduced.
2004 Ford Ranger 4.0L V6 NAPA Full Synthetic 5W30 + Fram Tough Guard
#4613840 - 12/25/17 12:06 PM
[Re: WANG]
Loc: North Carolina
They already fail my 20 micron requirement. Yup, that 0.000393701 Inch delta is clearly the difference between a long and happy service life and a premature destiny as a rebuilder's core. #rolleyes #mechanicalhypochondria My opinion: High confidence that the filters in question are suitable and fit for purpose. I second this statement!
04 Chevy Colorado 3.5 I5 5w-30 OEF 07 Honda Element 2.4 I4 5w-20 OEM 10 Nissan Rogue AWD 2.5 I4 5w-30 OEF Amsoil Products & Fram Filters
