Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
MC FL-500S CUT OPEN
by 53' Stude. 09/18/18 05:15 PM
FORD FACTORY FILTER CUT OPEN
by 53' Stude. 09/18/18 05:06 PM
2019 Harley Davidson FXDR 114
by DuckRyder. 09/18/18 04:59 PM
USS Forrestal question
by cjcride. 09/18/18 03:52 PM
Breaker Box
by Throt. 09/18/18 03:00 PM
Honda metal fuel tank seam leak
by wing0. 09/18/18 02:49 PM
Cracked single stage paint
by JHZR2. 09/18/18 01:45 PM
Options versus dealer oil changes
by Schmoe. 09/18/18 01:34 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
44 registered members (askani79705, alarmguy, 77GrandPrix, Bailes1992, bbhero, 7 invisible), 819 guests, and 36 spiders.
Topics290,618
Posts4,847,597
Members66,011
Most Online3,590
Jan 24th, 2017
Rotella 15w40 for Allison trans #4612404
12/23/17 06:48 PM
12/23/17 06:48 PM
New Jersey
Ursatdx Offline OP
Ursatdx  Offline OP
New Jersey
New to me 1993 AMG M35A3
Allison trans currently has Rotella 15w40 for ATF.
Any thoughts on this or changing to another ATF would be appreciated.
Merry Xmas.
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4612407
12/23/17 06:53 PM
12/23/17 06:53 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
A lot of hd transmissions use motor oil. Leave it.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4612422
12/23/17 07:14 PM
12/23/17 07:14 PM
MO
FirstNissan Offline
FirstNissan  Offline
MO
That thing is awesome! Whats you plan of use for it? farm work or just for car shows?
2017 Toyota Sienna (Hers)
2017 Toyota Sienna (His)
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4612430
12/23/17 07:21 PM
12/23/17 07:21 PM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4612434
12/23/17 07:29 PM
12/23/17 07:29 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
I'm a semi mechanic at UPS. The spotter trucks that all have an Allison automatic called for a 15W40 engine oil
up until about 12 years ago. Those transmissions hold up fine on it pulling semi trailers around the lot.
Me: 13' VW GTI 3 door 6 speed manual
Re: Rotella 15w40 for Allison trans [Re: 2004tdigls] #4612481
12/23/17 08:31 PM
12/23/17 08:31 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
This is for manuals....not an Allison...ever.
HDEO in Diesel Engines. No spark plugs here.
Re: Rotella 15w40 for Allison trans [Re: PiperOne] #4612496
12/23/17 08:51 PM
12/23/17 08:51 PM
Onondaga County
Miller88 Online content
Miller88  Online Content
Onondaga County
I don't know about the newer transmissions, but a lot of the older allisons could run hydraulic fluid , dex III ATF or 10w-30/15w-40 engine oil
18 Forester 2.5I 6M
00 Jeep Cherokee
01 Ford F-350 XL 4x4 5M
Re: Rotella 15w40 for Allison trans [Re: PiperOne] #4612524
12/23/17 09:34 PM
12/23/17 09:34 PM
maple ridge, bc
2004tdigls Offline
2004tdigls  Offline
maple ridge, bc
yes, but if you check the OP he has rotella 15w40 in the allison right now??
most sae 50W oils are allison approved including this one:
https://www.fleetrite.com/parts/chemicals/transmission-fluid/fltl50wp
About Fleetrite Transmission Fluid
Navistar is excited to offer Fleetrite® synthetic automatic transmission fluid (ATF), a premium synthetic universal power shift and automatic transmission fluid that is TES-295approved for use in Allison transmissions. Fleetrite synthetic ATF is approved for Allison’s Extended Transmission Coverage Programs.
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4612530
12/23/17 09:42 PM
12/23/17 09:42 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Current fill will likely last the entire time you own the truck.
Does it use a spin on filter?
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4613010
12/24/17 12:50 PM
12/24/17 12:50 PM
New Jersey
Ursatdx Offline OP
Ursatdx  Offline OP
New Jersey
Thanks for the replies.
I'll look for the spin on filter.
The internal filter is identical to a TH400.
Thoughts on T6 in the engine?
Merry Christmas to all.
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4625298
01/05/18 08:02 PM
01/05/18 08:02 PM
New Jersey
Ursatdx Offline OP
Ursatdx  Offline OP
New Jersey
It does have the spin on filter.
It's very slow to shift when cold.
Then, again, everything is slow on this truck. Really like it. Rough ride, tough to steer, and brakes work great but you really have to stand on them.
It's a stinking blast to drive.
52-54 MPH tops.
Re: Rotella 15w40 for Allison trans [Re: Ursatdx] #4626346
01/06/18 09:05 PM
01/06/18 09:05 PM
Indiana
nascarnation Offline
Indiana
For logistics purposes the US Army wanted to have a common engine and trans oil. The 15W40 was the diesel engine oil specified under MIL-L-2104D. So the trans was validated on both Dexron and engine oil. If you want better low temp performance, you could use a Dexron III spec oil or a 0W20 engine oil. 0W20 synthetic engine oil was the Army spec for engine and trans in arctic climate usage.
