Hi all,
This is a piggy back on my post earlier this week about wheels and tires. After reading your responses and having a talk with my wallet, we came to the decision that a good set of tires is the way to go versus new wheels and new tires. My main objective with new tires is to improve handling and road noise.
Currently have on a Kuhmo Solus in 215/55/17. Thinking about going up to a 225/50/17 for a few reasons.
1) Slightly shorter sidewall which I'm assuming will help with body roll, even if marginally.
2) FAR more choices than the 215/55/17
My final two choices are Michelin Premier A/S or Michelin Defenders.
The Premier's are stickier and I'm worried that will increase body roll more than the shorter sidewall of the 225/50/17 will be able to reduce. But the Defenders don't handle as well and are much harder (90,000 mile warranty).
So I can't decide, do I keep stock size (215/55/17) or change to 225/50/17 and which tire do I pick! Too many factors for me to get my head around to achieve desired result.
The 225/50/17's are tad wider than the stock size and the diameter will go down slightly (which yes I know will change my speedo, not worried about that, only changes it by about 1mph.)
