Mater Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
100 registered members (555, anndel, A1O, 2015_PSD, addyguy, 13 invisible), 2,127 guests, and 65 spiders.
Topics286,156
Posts4,903,166
Members67,565
Most Online2,967
Mar 10th, 2019
Oil consumption #4612121
12/23/17 12:11 PM
12/23/17 12:11 PM
South Africa
Matt97 Offline OP
Matt97  Offline OP
South Africa
I have a motor repair shop and find that straight SAE 40 oil works wonders for minimising leaks and reducing engine noise on older vehicles. Bear in mind that i am in South Africa so low temperatures are not an issue .On one of my personal vehicles ,Mazda 323, B3 engine i found that using 20W50 and `15w40 oils would have the dipstick showing on the min level every two weeks ,this started happening when the car reached 200 000km .Started using Magnatec 10w40 and this has stopped ,oil consumption over 5000km is now minimal, not even showing on the dipstick .
How is this possible ?
The Mazda B3 engine was designed in the eighties and only calls for a basic 20w50 multigrade oil .Magnatec is Champagne to that motor! Any views as to why the sudden improvement in oil consumption ?
Re: Oil consumption [Re: Matt97] #4612129
12/23/17 12:19 PM
12/23/17 12:19 PM
South Carolina
bmwtechguy Offline
bmwtechguy  Offline
South Carolina
Some oils just work better than others in a particular engine. You found one that works! Stick with that one if it is cost effective.
Re: Oil consumption [Re: Matt97] #4612130
12/23/17 12:21 PM
12/23/17 12:21 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Some of the oils you used may be low quailty group I oil with very high noack volatility and/or the better oil cleaned up the piston rings if they were sticky.
Me: 13' VW GTI 3 door 6 speed manual
Re: Oil consumption [Re: Matt97] #4612161
12/23/17 12:52 PM
12/23/17 12:52 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
It is a process called "Aging". I know it is a machine but they do age, the metal wears out, tolerance is going out, etc.
  • 2017 Toyota Sienna
Re: Oil consumption [Re: skyactiv] #4612168
12/23/17 01:04 PM
12/23/17 01:04 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted By: skyactiv
Some of the oils you used may be low quality group I oil with very high NOACK volatility and/or the better oil cleaned up the piston rings if they were sticky.
This is my thought.
Sometimes, a high quality oil can fix several problems.
Re: Oil consumption [Re: Linctex] #4612192
12/23/17 01:29 PM
12/23/17 01:29 PM
South Africa
Matt97 Offline OP
Matt97  Offline OP
South Africa
Previous oils were Total and Shell multigrades .Must add that the car never visibily smoked yet you could see the evidence in the tailpipe of oil burning
