Zipcode error
by aquariuscsm
06/24/18 01:36 PM
NHRA drag racing Racing question??
by daddi
06/24/18 01:33 PM
Milesyn 5w30 5 gal pails $50.94 w/prime
by Samrsnow
06/24/18 01:20 PM
Removing Broken Bathtub Drain
by Warstud
06/24/18 01:15 PM
Buffer Pads
by TheLawnRanger
06/24/18 01:10 PM
Recommend an oil to me... Pennz, M1, Castrol...?
by chinee
06/24/18 12:39 PM
Filter for Hydro Gear ZT2800 - Toyota???
by Lancruza
06/24/18 12:39 PM
Motul 5W30, 3000KM/12 mo, 06 Acura RSX-S 161K KM
by lemaitrix
06/24/18 12:38 PM
DeWalt dcf887b 3spd impact driver
by JC1
06/24/18 12:34 PM
Grit guard wash board
by JC1
06/24/18 12:22 PM
Truck Lug Nut Spikes
by ET16
06/24/18 12:12 PM
Tier III fuel is on the way
by ZZman
06/24/18 11:53 AM
ACDelco Dexos 0W20 UOA
by DanMiller
06/24/18 10:44 AM
Mopar window regulator (some assy. rqd.)
by dlundblad
06/24/18 10:27 AM
5.3L Silverado Water Pump Torque Specs
by Gito
06/24/18 10:25 AM
Rhino Ramps at Canadian Tire 50% off
by Snagglefoot
06/24/18 10:18 AM
What to do when your Glock jams
by bigj_16
06/24/18 10:13 AM
Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
crrider, EdDmax, 2018matto, Lancruza, IanSampson
65312 Registered Users
92 registered (aquariuscsm, alphadog, AnthemBassMan, 330indy, BAJA_05, andyd, 7 invisible), 1562 Guests and 34 Spiders online.
65312 Members
67 Forums
285914 Topics
#4611947 - 12/23/17 08:52 AM Tire choices!
Throt Offline
Loc: Jacksonville, FL
Hi all,
This is a piggy back on my post earlier this week about wheels and tires. After reading your responses and having a talk with my wallet, we came to the decision that a good set of tires is the way to go versus new wheels and new tires. My main objective with new tires is to improve handling and road noise.
Currently have on a Kuhmo Solus in 215/55/17. Thinking about going up to a 225/50/17 for a few reasons.
1) Slightly shorter sidewall which I'm assuming will help with body roll, even if marginally.
2) FAR more choices than the 215/55/17
My final two choices are Michelin Premier A/S or Michelin Defenders.
The Premier's are stickier and I'm worried that will increase body roll more than the shorter sidewall of the 225/50/17 will be able to reduce. But the Defenders don't handle as well and are much harder (90,000 mile warranty).
So I can't decide, do I keep stock size (215/55/17) or change to 225/50/17 and which tire do I pick! Too many factors for me to get my head around to achieve desired result.
The 225/50/17's are tad wider than the stock size and the diameter will go down slightly (which yes I know will change my speedo, not worried about that, only changes it by about 1mph.)
Edited by Throt (12/23/17 08:54 AM)
'18 Cadillac ATS AWD, 2.0L T-GDI, 3500, Factory Fill/Filter, his (lease)
'17 Elantra, 2.0L, 21,000, QS Ult. 0w20 w/ FU, hers (lease)
#4611960 - 12/23/17 09:00 AM Re: Tire choices! [Re: Throt]
SatinSilver Offline
Loc: OH
Easy decision, the Premiers. You need all the grip you can get in Ohio.
#4612007 - 12/23/17 09:36 AM Re: Tire choices! [Re: SatinSilver]
Kira Online   content
Loc: Champlain/Hudson Valley
You're so right regarding the amount of "factors to get your head around".
My take is more abbreviated and sounds harsh. It isn't.
1) Stick with stock size-NO EXPLANATION NEEDED. You're no track racer. Anyone would be hard pressed to detect any difference.
2) I'd select the tire with the highest wear rating (the 3 digit number). There'll be enough traction for Ohio use. If there isn't enough traction, you're driving too fast.
Good luck with your decision
#4612042 - 12/23/17 09:58 AM Re: Tire choices! [Re: Throt]
Kev994 Offline
Loc: North Carolina
Iím happy with the Defenders on my Lancer, I got them for the road noise. Iím not a spirited driver though.
#4612054 - 12/23/17 10:13 AM Re: Tire choices! [Re: Throt]
Dorian Offline
Loc: Ohio
Why not the new Michelin CrossClimate+? They come in both 215/55R17 and 225/50R17. They are all seasons that have summer tire dry capability and near snow tire winter traction. When it comes to safety, price is a small thing to pay for.
99 Camry 5S M1 AFE 0W30 194K
14.5 Camry SE 2AR 0W20 M1 AFE 36K (Mom's)
98 Chevy Prizm 1ZZ M1 AFE 0W30 146K (Brother's)
#4612060 - 12/23/17 10:16 AM Re: Tire choices! [Re: Throt]
tomcat27 Offline
Loc: Chicago, IL
I don't see any problem with adjusting up to a 225. I have done it before in order to get more tire choices. between the premier and defender, I don't see much difference in the tread patterns. they both have similar tread groove width and similar siping. the traction rating is the same for both tires. that being said, I would get the Defenders because they have a deeper tread: 10/32 vs 9/32. this will have two benefits: better dispersion of water and snow, and longer tire life. as a bonus, they cost a little less than the Premiers.
Edited by tomcat27 (12/23/17 10:27 AM)
2015 Rogue, 2014 Sentra, 2001 Camry, 2005 Starcraft, 1998 Dodge B1500
1996 Sebring Jx, 1984 F150, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
#4612122 - 12/23/17 11:13 AM Re: Tire choices! [Re: Throt]
Nick1994 Online   content
Loc: Phoenix, AZ
Look into the Pirelli Cinturato P7, I had a set on my VW, incredible tire. Quiet and great handling.
My aunt put a set on her VW in 215/55-17 size and VW bought it back, but we had a set of junk tires put on it before the turn in and kept the Pirellis. Her Avalon has the same tire size so the Pirellis are waiting to go on when the OE Michelinís are worn out.
2015 Hyundai Sonata 2.4L 79k PU 5w30 & OEM
2000 Toyota Camry 2.2L 228k M1 AFE 0w30 & Wix
1996 Jeep Cherokee 4.0L 146k M1 HM 10w40 & Fram Ultra
#4612151 - 12/23/17 11:40 AM Re: Tire choices! [Re: Throt]
skyactiv Offline
Loc: The Midwest
What with help with body roll as you call it more than anything is having tires with 2 ply sidewalls instead of 1 ply sidewalls.
When I owned a WRX, I bought a set of Kumhos at DT to replaced the OEM Bridgestones. The Kumho tires had 1 ply sidewalls while the OEM tires had
2 ply sidewalls. The Kumho's has less steering response and body roll. I went back to DT and got BF Goodrich tires with 2 ply sidewalls that were much better.
The number of plys of the tread and sidewalls is stated on your OEM tires.
Me: 13' VW GTI 3 door 6 speed manual
#4612156 - 12/23/17 11:44 AM Re: Tire choices! [Re: Throt]
slacktide_bitog Offline
Loc: USA
There's really no reason to change the tire size, except minus-sizing for winter tires.
Both cars in your sig are 2017's and probably still have the original tires on them. This is important because OE tires are usually garbage for anything but achieving CAFE numbers. Therefore, almost any tire will give you better handling.
I second the CrossClimate+ if you're only using a single tire year-round.
But, if you can, get a second set of wheels/tires for the winter. You can probably afford them given that you have a brand new car. Also, summer tires are quieter and better handling than all-season tires smile
#4612204 - 12/23/17 12:47 PM Re: Tire choices! [Re: Throt]
oil_film_movies Offline
Loc: MN
Check fender clearance on http://www.rimsntires.com/specspro.jsp to be sure what you're getting.
#4612251 - 12/23/17 01:40 PM Re: Tire choices! [Re: Nick1994]
Eosyn Offline
Loc: Michigan
+1 on Pirelli. I'm choosing to go with the Pirelli P4 Four Seasons Plus when it comes time to get new tires for my Malibu, 225/55R17. Tread depth is 12/32 and great review ratings. Less expensive than Michelins also.
02 Toyota Celica GT: 194k, VML 5W30/Denso filter
05 Toyota Corolla LE: 151k, VML 5W30/Bosch filter
15 Chevy Malibu LT: 37k, VML 0W20/Denso filter
#4612314 - 12/23/17 03:42 PM Re: Tire choices! [Re: Throt]
eljefino Offline
Loc: ME
If you don't like body roll see if you can get a stiffer sway bar.
If you don't like tire squealing and understeering, get something grippier.
But a stickier tire will lead to more body roll.
#4618683 - 12/30/17 10:30 AM Re: Tire choices! [Re: Throt]
Throt Offline
I ended up sticking with the OEM size of 215/55/17 and purchased a set of Michelin Premier A/S. I upped the air pressure to 38 instead of 34. So far Iím very happy with them. They didnít let me down on the last 2 cars I put them on so I stuck with the Michelin Man. After rebates and selling my OEM, this $750 set of tires is gonna cost me about $420. Canít beat that!
Too help with body roll Iím going to install: https://www.progressauto.com/products/sfID1/12/sfID2/37/sfID3/165/productID/808
Edited by Throt (12/30/17 10:31 AM)
