supercapacitor jump starter
CA
I first heard about these a few weeks ago. Since, I've been looking into the pros and cons.
The principle is a vendor chains together 6 2.7V multi-hundred farad supercapacitors, a DC-DC boost circuit, and some battery cables, to make a jump starter pack.
The supercapacitors have very low internal resistance so they can discharge at very high current, enough to easily turn a starter motor.
The more cleaver thing is if you have a "dead" battery you use some of what is still in the dead battery to charge the supercapacitors. Seems they'll charge up at a 10A rate for a couple of minutes, get up to about 15V, then you switch from charge to jump mode and start the car.
A simple one, claiming 300A: ($99 refurbished)
A more advanced one, claiming 700A, having a meter that tells you the internal impedance of your car battery (which should be of interest to JHZR2): ($120 new)
A variation of this style, having an internal Li-Ion battery, for the case where the car battery is really dead as a doornail, the capacitors can charge from the internal battery: ($157.29 new)
Schumacher markets a DSR-108 and a DSR-109, still within the consumer budget.
Here's an OzCharge, 500A, on Amazon, for $245.99
Then, for heavy/fleet use, Chicago Pneumatic markets two models, starting at $1500 (guess)
Once you know about these you can search for videos of people using them.
Seems the pros are:
- Not carrying around Li-Ion batteries in the trunk (no vent with flame issues)
- A better idea, for the frequent user. Very high discharge rates are hard on Li-Ion batteries.
Seems the cons are:
- Higher cost
- I see shelf life of capacitors are 10 years, so I don't know how long the jump pack will really last.
- Linear voltage discharge of caps vs. flat voltage discharge of Li-Ion batteries mean you have to buy bigger capacitors, so enough voltage will be there to continue to turn over engine.
- If you only need a few jumps in 5 years, the Li-Ion jump packs are probably good enough, as long as you don't cheap-out too much
- Heavier and much lower energy density than Li-Ion batteries.
An unknown is you're supposed to balance-charge the capacitors, same as Li-Ion batteries, when they're hooked in series. Maybe that doesn't matter much to a very occasional-use jump pack. It seems to matter to a frequent-use supercapacitor bank that's used for other things, like for a stop-start circuit, or regenerative braking.
The units claim low temp is what they are good at. -40(C or F, they're the same) is the low working range.
I've looked at some data sheets and the caps are better at low temps than Li-Ion batteries.
Shelf life is voltage dependent. Keep it below may and life may go up. Keep it nearly discharged and it could be a very long time.
I do prefer this to the liability of a fly by night Li-ion battery kept in a hot car for years. But the total energy and discharge character may be an issue.
As a EE, I'm HIGHLY skeptical of all claims of the little "jump starters" whose real effectiveness is related to the car battery's actual condition. Starting a car takes hundreds of amperes. A badly discharged battery or a completely dead battery I just don't believe will allow a car to start with one of these toys hooked up to it. BUT, I've not spend much time looking into them so YMMV.
Another reason I have AAA for the me and the wife!
If you wanted to get one of these, the RFD1000 is $129.99 at EBay (item 192418293661), then today only is 15% off code PRIMOSALE.
Makes it $110.
I use the Lithium battery "jump starters" with regularity. Working at the airport, it's common for pilots to leave the master switch on and completely drain a battery AND/OR to leave a dome light on in a car. These little units provide impressive starting current, and will start a very, very dead vehicle. They will even start a vehicle that has no battery installed.
I understand your skepticism. Be aware these things are designed and engineered to provide the necessary current.
A good friend has a difficult to start, high compression, Lycoming AEIO 540 powered stunt plane. He uses a Ballistic lithium battery, as the main battery, it weighs just 3.3 pounds. It cranks that engine over like magic.
come on man. you are being a terrible engineer if the thing you're skeptical about is so easily testable and demonstrable. So I dont know why you threw that tidbit in there.
The very basic premise of being a scientist or engineer is having an open mind and that one puts thing to the test rather than deciding based on your gut.
I refer you back to elementary school scientific method.
fyi (i am a fellow ee)
Yes, I was sceptical also...Until I bought one.
It has got the job done multiple times where the cars (including a 3L turbodiesel) wouldn't even crank...the L67 Caprice twice when totally dead wouldn't light a blinker.
