Brake Caliper Dampers?
by HangFire. 01/18/19 11:32 AM
Fully Formulated Coolant and old radiator
by Wheel. 01/18/19 11:27 AM
'15 6.7 Powerstroke UOA
by roadrunner1. 01/18/19 10:18 AM
Automotive Battery Voltage -What is ur reading?
by Patrick0525. 01/18/19 10:10 AM
Amsoil 0w-40 vs 5w-40
by Buddyp. 01/18/19 10:07 AM
M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
101 registered members (andyd, badtlc, Best F100, Astro14, 53' Stude, 14 invisible), 2,207 guests, and 52 spiders.
Topics296,781
Posts4,958,806
Members66,969
Most Online2,577
Jan 14th, 2019
supercapacitor jump starter #4611679
12/22/17 09:01 PM
12/22/17 09:01 PM
CA
spackard Offline OP
spackard  Offline OP
CA
I first heard about these a few weeks ago. Since, I've been looking into the pros and cons.
The principle is a vendor chains together 6 2.7V multi-hundred farad supercapacitors, a DC-DC boost circuit, and some battery cables, to make a jump starter pack.
The supercapacitors have very low internal resistance so they can discharge at very high current, enough to easily turn a starter motor.
The more cleaver thing is if you have a "dead" battery you use some of what is still in the dead battery to charge the supercapacitors. Seems they'll charge up at a 10A rate for a couple of minutes, get up to about 15V, then you switch from charge to jump mode and start the car.
A simple one, claiming 300A: ($99 refurbished)
A more advanced one, claiming 700A, having a meter that tells you the internal impedance of your car battery (which should be of interest to JHZR2): ($120 new)
A variation of this style, having an internal Li-Ion battery, for the case where the car battery is really dead as a doornail, the capacitors can charge from the internal battery: ($157.29 new)
Schumacher markets a DSR-108 and a DSR-109, still within the consumer budget.
Here's an OzCharge, 500A, on Amazon, for $245.99
Then, for heavy/fleet use, Chicago Pneumatic markets two models, starting at $1500 (guess)
Once you know about these you can search for videos of people using them.
Seems the pros are:
- Not carrying around Li-Ion batteries in the trunk (no vent with flame issues)
- A better idea, for the frequent user. Very high discharge rates are hard on Li-Ion batteries.
Seems the cons are:
- Higher cost
- I see shelf life of capacitors are 10 years, so I don't know how long the jump pack will really last.
- Linear voltage discharge of caps vs. flat voltage discharge of Li-Ion batteries mean you have to buy bigger capacitors, so enough voltage will be there to continue to turn over engine.
- If you only need a few jumps in 5 years, the Li-Ion jump packs are probably good enough, as long as you don't cheap-out too much
- Heavier and much lower energy density than Li-Ion batteries.
An unknown is you're supposed to balance-charge the capacitors, same as Li-Ion batteries, when they're hooked in series. Maybe that doesn't matter much to a very occasional-use jump pack. It seems to matter to a frequent-use supercapacitor bank that's used for other things, like for a stop-start circuit, or regenerative braking.
Re: supercapacitor jump starter [Re: spackard] #4611719
12/22/17 10:14 PM
12/22/17 10:14 PM
Pittsburgh,PA U.S.A.
JimPghPA Offline
JimPghPA  Offline
I wonder what the freezing temperature is for the super-capacitors. In other words how cold is too cold for this type of jump-starter.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: supercapacitor jump starter [Re: spackard] #4611728
12/22/17 10:26 PM
12/22/17 10:26 PM
CA
spackard Offline OP
spackard  Offline OP
CA
The units claim low temp is what they are good at. -40(C or F, they're the same) is the low working range.
I've looked at some data sheets and the caps are better at low temps than Li-Ion batteries.
Re: supercapacitor jump starter [Re: spackard] #4611901
12/23/17 07:29 AM
12/23/17 07:29 AM
New Jersey
JHZR2 Offline
JHZR2  Offline
New Jersey
Shelf life is voltage dependent. Keep it below may and life may go up. Keep it nearly discharged and it could be a very long time.
I do prefer this to the liability of a fly by night Li-ion battery kept in a hot car for years. But the total energy and discharge character may be an issue.
Re: supercapacitor jump starter [Re: spackard] #4611967
12/23/17 09:04 AM
12/23/17 09:04 AM
WV
jonnied1 Offline
jonnied1  Offline
WV
This is the wave of the future!
Re: supercapacitor jump starter [Re: spackard] #4611978
12/23/17 09:14 AM
12/23/17 09:14 AM
E. Tennessee
WhizkidTN Offline
WhizkidTN  Offline
E. Tennessee
As a EE, I'm HIGHLY skeptical of all claims of the little "jump starters" whose real effectiveness is related to the car battery's actual condition. Starting a car takes hundreds of amperes. A badly discharged battery or a completely dead battery I just don't believe will allow a car to start with one of these toys hooked up to it. BUT, I've not spend much time looking into them so YMMV.
Another reason I have AAA for the me and the wife!
His: '12 Kia Optima SX - 2.0L GDI Twin-Scroll Turbo [Tuned] (77K)
>EDGE 0W-40, Fram XG9688
Her's: '14 Nissan Rogue SL AWD - 2.5L NA (77K)
>EDGE 0W-20, Fram XG6607
Re: supercapacitor jump starter [Re: spackard] #4811082
07/11/18 08:12 AM
07/11/18 08:12 AM
CA
spackard Offline OP
spackard  Offline OP
CA
If you wanted to get one of these, the RFD1000 is $129.99 at EBay (item 192418293661), then today only is 15% off code PRIMOSALE.
Makes it $110.
Re: supercapacitor jump starter [Re: WhizkidTN] #4814861
07/15/18 02:03 PM
07/15/18 02:03 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
I use the Lithium battery "jump starters" with regularity. Working at the airport, it's common for pilots to leave the master switch on and completely drain a battery AND/OR to leave a dome light on in a car. These little units provide impressive starting current, and will start a very, very dead vehicle. They will even start a vehicle that has no battery installed.
I understand your skepticism. Be aware these things are designed and engineered to provide the necessary current.
A good friend has a difficult to start, high compression, Lycoming AEIO 540 powered stunt plane. He uses a Ballistic lithium battery, as the main battery, it weighs just 3.3 pounds. It cranks that engine over like magic.
Re: supercapacitor jump starter [Re: WhizkidTN] #4816923
07/17/18 10:45 PM
07/17/18 10:45 PM
CA
raytseng Offline
raytseng  Offline
CA
come on man. you are being a terrible engineer if the thing you're skeptical about is so easily testable and demonstrable. So I dont know why you threw that tidbit in there.
The very basic premise of being a scientist or engineer is having an open mind and that one puts thing to the test rather than deciding based on your gut.
I refer you back to elementary school scientific method.
fyi (i am a fellow ee)
Re: supercapacitor jump starter [Re: Cujet] #4816954
07/18/18 02:15 AM
07/18/18 02:15 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Yes, I was sceptical also...Until I bought one.
It has got the job done multiple times where the cars (including a 3L turbodiesel) wouldn't even crank...the L67 Caprice twice when totally dead wouldn't light a blinker.
