How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
96 registered members (1978elcamino, ArrestMeRedZ, aquariuscsm, 69Torino, 4WD, 94astro, 9 invisible), 2,281 guests, and 63 spiders.
Topics286,017
Posts4,900,853
Members67,548
Most Online2,967
Mar 10th, 2019
Diesel oils - high detergent? #4611474
12/22/17 05:27 PM
12/22/17 05:27 PM
Sacramento, Ca.
928 Offline OP
928  Offline OP
Sacramento, Ca.
I need to clean out the results of running castrol gtx 20/50 for 150k miles ( gummed up lifters) in a gas engine. Car is a Porsche requiring heavy oil
Not really a fan of dumping atf etc in the oil.
Does delo , valvoline or rotella have more detergents than conventional oils? Planning on oil & filt changes every 3000 until it hopefully clears up.
Re: Diesel oils - high detergent? [Re: 928] #4611494
12/22/17 05:59 PM
12/22/17 05:59 PM
S. Ont. Canada
neil57 Offline
neil57  Offline
S. Ont. Canada
Dump a can of seafoam and some cheap supertech Walmart oil in. Repeat as necessary.
09 GMC 2500HD Duramax/Allison EFI live
2018 Chevy Cruz
11 Ford Escape
Be realistic,don't be fooled by delusions of adequacy
Re: Diesel oils - high detergent? [Re: 928] #4611506
12/22/17 06:16 PM
12/22/17 06:16 PM
Colorado
Bronco1 Offline
Bronco1  Offline
Colorado
this would be a good question for Molakule to chime in on.
07 F150 Lariat 4x2
07 Honda Fit
96 Ford Bronco 4x4
"If you always do what you always did, you will always get what you always got" Albert Einstein
Re: Diesel oils - high detergent? [Re: 928] #4611561
12/22/17 07:20 PM
12/22/17 07:20 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
GTX gummed up your lifters? It's high in detergents itself.
How did that happen?
Re: Diesel oils - high detergent? [Re: 928] #4611618
12/22/17 08:30 PM
12/22/17 08:30 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
I do occasional summer runs of Rotella T5 10w30 or Delo LE 10w30 and 20% MMO to keep things clean. I would try a 3k OCI and see if that helps.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: Diesel oils - high detergent? [Re: DoubleWasp] #4611673
12/22/17 09:53 PM
12/22/17 09:53 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Must have overextended the oil change interval or had a stuck thermostat.
I would run LCD's LC20 in with the oil until they clear up.
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: Diesel oils - high detergent? [Re: 928] #4611677
12/22/17 09:59 PM
12/22/17 09:59 PM
California
SavagePatch Offline
SavagePatch  Offline
California
Try this:
It's only available at WalMart.
Re: Diesel oils - high detergent? [Re: 928] #4611681
12/22/17 10:03 PM
12/22/17 10:03 PM
New Jersey
Rock_Hudstone Offline
New Jersey
Rotella T5 syn-blends and the T4 still have decent levels of calcium detergent.
http://rotella.shell.com/products.html
The Delo and Valvoline Ca levels are down quite a bit since the change over to CK-4 SN grade.
Re: Diesel oils - high detergent? [Re: 928] #4611758
12/23/17 12:58 AM
12/23/17 12:58 AM
california
slowrench Offline
slowrench  Offline
california
Ive had success with sticky lifter ,in my turbo diesel.I slowly added a QT. of diesel fuel to a hot idling engine.Let it idle or high idle for 15-30min.,then drain.I believe its good to do once in a while,in my old diesels.
Re: Diesel oils - high detergent? [Re: 928] #4612101
12/23/17 11:47 AM
12/23/17 11:47 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
KREEN will do it nicely smile MMO may help... BG109 might do it ...
If it were me, I'd just run Valvoline Maxlife as shown above and monitor. But any oil off the Porsche A40 list will do. You just need to change chemistries to start the process smile
Re: Diesel oils - high detergent? [Re: 928] #4612166
12/23/17 01:02 PM
12/23/17 01:02 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I'd run 0W-40 Mobil 1 and change every 5,000
Re: Diesel oils - high detergent? [Re: Linctex] #4612288
12/23/17 03:43 PM
12/23/17 03:43 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
+10,000
Re: Diesel oils - high detergent? [Re: BrocLuno] #4612289
12/23/17 03:44 PM
12/23/17 03:44 PM
New Jersey
New Jersey
Originally Posted By: BrocLuno
...If it were me, I'd just run Valvoline Maxlife as shown above and monitor.
Not sure what the big deal s about Maxlife? it just a semi-syn, as is the Rotella T5, and this VOA shows calcium levels are nothing to write home about for an HDEO.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4068904/Re:_VOA_Valvoline_Heavy_Duty_D
BTW pouring solvents such as diesel fuel in the crankcase is crzy
Re: Diesel oils - high detergent? [Re: slowrench] #4612297
12/23/17 04:05 PM
12/23/17 04:05 PM
Seattle-ish, WA
Oro_O Offline
Oro_O  Offline
Seattle-ish, WA
This works well. Used to be a Mercedes factory approved method for oil issues. Itís not crazy; just effective.
M1 10w-40 HM and a drive the lenght of WA alos fixed noisy lifters in an SUV of mine several years ago.
Re: Diesel oils - high detergent? [Re: Oro_O] #4612322
12/23/17 04:58 PM
12/23/17 04:58 PM
New Jersey
New Jersey
Approved for gas engines or diesel?
