Back to Basics II
by MolaKule. 12/14/18 04:31 PM
"SG(+)" 15w40 or better oil 1987 BBC 454
by F239141. 12/14/18 03:52 PM
All Mazda 3’s have bad OCV’s?
by buster. 12/14/18 03:44 PM
Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
92 registered members (69Torino, 65cuda, 92saturnsl2, 2oldtommy, 53' Stude, 94astro, 15 invisible), 1,880 guests, and 40 spiders.
Topics295,071
Posts4,927,271
Members66,682
Most Online2,553
Oct 27th, 2018
*Subaru Warranty extension:High Oil Consumption* #4611396
12/22/17 02:58 PM
12/22/17 02:58 PM
Toronto, Canada
LaszloToth Offline OP
Toronto, Canada
Subaru Canada has extended the warranty for engines that experience excessive oil consumption to 8 years/160,000 km from the date the vehicle was put in service. Subaru vehicles equipped with either a 2L or 2.5L NON-TURBO engine are covered. (Models covered are listed in the column on the left of this entry)
2011-2015 Forester
2012-2015 Impreza
2013-2015 Crosstrek
2013-2014 Legacy and Outback
Automobile Protection Association | Recalls & Tech Tips - Template
Warranty extension:High Oil Consumption Subaru Canada has extended the warranty for engines that experience excessive oil consumption to 8 years/160,000 km from the date the vehicle was put
APA.CA
Subaru Warranty extension: High Oil Consumption
My wife has a '13 Crosstrek, it takes 0W20 synthetic and has a 10,000 km OCI. Didn't notice oil consumption when we ran 5W-30 Castrol EDGE in it in the summer, but the low oil light came on after 5 or 6,000 km Pennzoil Ultra 0W-20. Dealer salesman says they consume the spec stuff (0W-20) and to put in 5W-30 instead.
I'm curious about this test. It's likely a dealer oil change with a seal on the oil filler cap and dip stick tube, since it has an electronic oil level sensor. Does anyone know what the Subaru dealer test procedure is?
White '11 STi
Buckle up. The new Subaru WRX STi is here.
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611411
12/22/17 03:11 PM
12/22/17 03:11 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
What exactly is failing? It seems real vague, that link says to replace the engine block and parts, which is basically an engine swap to fix the oil consumption.. I can't believe thats the only way to fix it..
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611416
12/22/17 03:18 PM
12/22/17 03:18 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
The TSB says what the test involves.
"This test begins with a free oil and filter change and sealing the motor oil drain plug to measure oil consumption over the next few thousand kilometers. If oil consumption is determined to be excessive, Subaru will replace the engine block assembly or install upgraded piston rings."
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LeakySeals] #4611418
12/22/17 03:20 PM
12/22/17 03:20 PM
Danno Offline
Danno  Offline
If Subaru could do it for cheaper, they would. Seems like the rings are allowing excessive oil by, and I suspect if that leaking has scored the cylinder bores, the block has to be changed out.
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611422
12/22/17 03:24 PM
12/22/17 03:24 PM
Cincinnati, OH, USA
bullwinkle Offline
bullwinkle  Offline
Cincinnati, OH, USA
My guess would be weak oil control rings, allowing it to be burned in the cylinders. Blowby would be pretty obvious at the dipstick, oil fill, etc. Poor machining tolerances would also be a possibility.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611424
12/22/17 03:25 PM
12/22/17 03:25 PM
New York Queens
Ram02 Offline
Ram02  Offline
New York Queens
Pennzoil 0w20 does burn off easily then some others
2013 Malibu 2LT M1 5w30
2013 Accord Sport M1 AP 0w20
Re: *Subaru Warranty extension:High Oil Consumption* [Re: Danno] #4611427
12/22/17 03:33 PM
12/22/17 03:33 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I know with other Japanese Manufacturers I4's its the oil control return holes plugging that are the primary cause of oil consumption. A combination of oil with a "weak" flash point and a small, hot running aluminum block can overheat the oil, flashing to hardened carbon in the arteries of the piston. With nowhere to scrape oil off to, oil builds up in the cylinder the faster you go. Jamming up the rings with burned up oil. In that case going thicker only helps after the clogging has occurred. restricting flow with thicker oil. The fix is not rings. Its a piston removal to clear the holes with a drill, or replace pistons entirely.
I read everywhere Subaru owners go for the T6 5w40? Or is that strictly a turbo thing?
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LeakySeals] #4611437
12/22/17 03:47 PM
12/22/17 03:47 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
That was mainly for the older EJ series engines.
These are the FB20 and FB25 engines.
It has to do with the low tension rings(for fuel economy) and burning oil. These engines are horizontally opposed 4 cylinders so you cant just slap in generic "knowledge" about Asian I4 engines and call it a day.
Its been widely documented that they have been through at least 3 different ring part numbers.. but often replacing the rings doesnt fix the issue so you get a new short block.
I had 3 different fb25 powered subarus.. all in the problem list.
Its an issue caused by the search for better MPG. It in no way shortens engine life.
The issue was also further caused by lengthened oil change intervals.
The oil burning accelerates as the oil ages in service.
The procedure varies somewhat.. foresters from 2011-2013 did not have any kind of low oil level light. 2014+ have the Low engine oil level light.
Outbacks from 2013+ did (all fb25 outbacks)
unsure about crosstrek/impreza
Yes they change the oil and seal the system then instruct you to drive for about 1000miles or until the light comes on (depending on model and year)
they then measure the level. 1/3quart usage in 1000 miles is failing.
Many dealers will overfill the oil when changing it. for example on the 2013 outback oil burner they put almost 12 extra ounces in.
That car has seen new rings, a new shortblock, and the new shortblock is now consuming oil after 15000 miles...
Consumption in an oil change accelerates as you get more miles on the oil.
1qt in first 3000miles 2nd quart around 5000miles(2000miles) additional .5qt before the oil change.
Consumption is best in around town driving. Worst on extended high speed trips.. example: 80mph on Interstate route 80 in PA(hilly)
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611449
12/22/17 04:03 PM
12/22/17 04:03 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
Hey thanks for the education Rand!
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611478
12/22/17 04:34 PM
12/22/17 04:34 PM
Toronto, Canada
Toronto, Canada
Yes I agree with LeakySeals, great information Rand. Thank you,
White '11 STi
Re: *Subaru Warranty extension:High Oil Consumption* [Re: Rand] #4611480
12/22/17 04:35 PM
12/22/17 04:35 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Good job Rand. thumbsup
Re: *Subaru Warranty extension:High Oil Consumption* [Re: Rand] #4611535
12/22/17 05:54 PM
12/22/17 05:54 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
On a normal oil change... or for this test?
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611537
12/22/17 05:57 PM
12/22/17 05:57 PM
SW of Chicago, IL
Variant_S Offline
Variant_S  Offline
SW of Chicago, IL
My experience pretty much mirrors Rand's. Good explanation.
I keep an eye on oil level. The low oil light comes on at about 5K miles after an oil change with in-town driving. If I'm crossing the continent, it will drink a quart in 3K miles. This is on a '13 Outback with about 86K otherwise trouble-free miles.
Re: *Subaru Warranty extension:High Oil Consumption* [Re: LaszloToth] #4611541
12/22/17 06:00 PM
12/22/17 06:00 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
This will bring PTSD to my local Toyota/Subaru/Mazda joint service center
My parts guy hasn't been the same since the ZE7 2AZ-FE consumption deal
Good to hear Subaru's owning up to it, with a much looser criteria for the rebuild then Toyota
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: *Subaru Warranty extension:High Oil Consumption* [Re: michaelluscher] #4611552
12/22/17 06:12 PM
12/22/17 06:12 PM
MI
doitmyself Offline
doitmyself  Offline
MI
The class action lawsuit may have persuaded them just a bit.
