Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Washoe_Mark, CG_BrianM, TBF, mm2020, emepher
67563 Registered Users
69 registered members (69Torino, avi1777, 2015_PSD, 87sammy, 97K15004WD, ArrestMeRedZ, 6 invisible), 776 guests, and 53 spiders.
Topics286,105
Posts4,902,667
Members67,563
Most Online2,967
Mar 10th, 2019
4T65e sudden finnickey 4-3 downshift. #4610838
12/22/17 03:59 AM
12/22/17 03:59 AM
Virginia
Hemispheres Offline OP
Virginia
About a week ago I skidded off some ice in reverse at less than 10mph which left my front end in the ditch.
For about 45 seconds I struggled to get out. Applying the gas in R until TC kicked in while quickly steering side to side. Eventually I stopped moving after a few successful attempts to gain traction and almost made it out of the ditch and began spinning tires.
I panicked and at about 2k rpms I slammed the gear selector from R to 1 which gained me immediate traction and pulled me out of the ditch.
Trans seems to work just fine, but now Iím noticing at 80mph I canít get kick down to engage. However at 70 it engages and downshifts just fine.
Any idea what could be going on?
2009 Buick LaCrosse (3800 Series III) - 137,000 miles.
PZ Plat HM/Mobil 1 HM
Bosch/Purolator/Mobil filters
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4610864
12/22/17 05:41 AM
12/22/17 05:41 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
What vehicle , engine , miles ? What does the fluid look / smell like ? Any loose wires vacuum lines ? Sensors ?
Wyr
God bless
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4610907
12/22/17 07:26 AM
12/22/17 07:26 AM
Virginia
Virginia
2009 Buick LaCrosse. 137k miles. Vehicle has been maintained fairly well. Fluid was changed a few months ago, has been changed once before. Shifts fine. No loose lines or sensors, no CEL.
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4610939
12/22/17 08:10 AM
12/22/17 08:10 AM
dayton oh
kc8adu Offline
kc8adu  Offline
dayton oh
disconnect the battery and force it to relearn.
Re: 4T65e sudden finnickey 4-3 downshift. [Re: kc8adu] #4611230
12/22/17 01:35 PM
12/22/17 01:35 PM
Canada
i_hate_autofraud Offline
Canada
Yeah, disconnect for an hour to make sure it clears the tranny computer.
However, to disconnect the battery, be sure it's 15 minutes after the key was taken
out of the ignition. There's GMs "RAP" "retained accessory power" if you disconnect within
15 minutes, the computers kick in a one-use Lithium primary battery associated with OnStar
system and drains it flat.
disconnect the battery cleanly, keep good contact while undoing clamp, then pull off in
one clean move or computers will interpret rapid electrical make-n-break of the ground wire
as an accident and kick in the lithium battery above. Same applies when you re-connect,
do it in one clean move without multiple make-n-break moves.
GM doesn't want you to know, they'd like to fix your OnStar!!
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4611490
12/22/17 05:50 PM
12/22/17 05:50 PM
Virginia
Virginia
That may be the issue. I disconnected the battery before leaving on my trip to reset fuel trims n get better mileage.
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4613524
12/25/17 02:11 AM
12/25/17 02:11 AM
Virginia
Virginia
Ok so Iíve done a relearn and now Iím getting harsh shifting under medium throttle. Iím talking thump when shifting. If itís done under light or wot it feels normal. This part of the shift adapt process?
Re: 4T65e sudden finnickey 4-3 downshift. [Re: Hemispheres] #4613554
12/25/17 04:43 AM
12/25/17 04:43 AM
Virginia
Virginia
Well it looks like I busted my coolant temp sensor in the process of repairing more exhaust leaks. Iím reading that will cause and inoperative torque converter clutch which is most likely why Iím only having issues with upshifts.
