Post your cars high mileage
by Serge. 09/23/18 09:01 AM
Post your latest mileage achievement
by Snagglefoot. 09/23/18 08:23 AM
Field repair by the Mississippi!
by Number_35. 09/23/18 08:18 AM
F150 5.0 Lost power
by hatt. 09/23/18 08:15 AM
Mobil @ Bomgaars sale
by Duffyjr. 09/23/18 04:45 AM
More California BS!
by dogememe. 09/23/18 04:04 AM
Optimum No Rinse Wash and Wax or Shine?
by anndel. 09/23/18 03:44 AM
Michelin jack won't lift a load
by 10WSmuckers. 09/23/18 01:32 AM
Synthetic for a 30 year old engine?
by geissjr. 09/23/18 01:02 AM
Phone Books
by csandste. 09/23/18 12:11 AM
Inside the Fuel Tank / EVAP system
by StevieC. 09/22/18 10:31 PM
Toyota Pink + RMI-25 10 years
by burla. 09/22/18 10:27 PM
Cartridge filter?
by Camprunner. 09/22/18 10:23 PM
Should have changed it?
by parshisa. 09/22/18 10:14 PM
Meijer QSUD Full Syn 10w30 $8.11 5qt jug
by Spartanfool. 09/22/18 08:40 PM
Whats in your beef burger
by CourierDriver. 09/22/18 08:28 PM
Headlight brightness fluctuates on 1987 Golf
by vavavroom. 09/22/18 07:56 PM
"New" Beater
by SilverGt. 09/22/18 07:22 PM
Eschewing computer controls
by buck91. 09/22/18 06:41 PM
The_Money_Light, DALTRON0659, skippermatt, HondaTech250, SandCruzer
66047 Registered Users
84 registered members (92saturnsl2, Aero540T, alex_at, arthuro, AnthemBassMan, 53' Stude, 8 invisible), 1,514 guests, and 34 spiders.
Topics290,876
Posts4,851,703
Members66,047
Most Online3,590
Jan 24th, 2017
Stainless steel drain plugs in aluminum? #4610817
12/22/17 02:19 AM
12/22/17 02:19 AM
indiana
dakota99 Offline OP
dakota99  Offline OP
indiana
Okay so I guess the ocd is kicking back in but I recently replaced the drain plugs on two champion generators with stainless steel ones (304) and now Iím wondering if this will cause a corrosion issue? The blocks are aluminum and I know the two metals can cause galvanic corrosion in certain cases but is this one of them? Iíd hate to have the threads or something corrode and leak. That or have the plug seize in place.
The generators had from the factory some rubber hose setup where you could lower it into a pan to drain the oil but it was extremely slow. I decided to just unscrew the hose assembly and thatís when I had to purchase some plugs to go in their place like a typical engine would have. I have a feeling this is fine but I wanted a second opinion.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4610830
12/22/17 03:05 AM
12/22/17 03:05 AM
left cose, USA
resist Offline
resist  Offline
left cose, USA
Tha t's not OCD son/
Maybe talk to this guy and you two can go on a date or something?
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4610757/Have_a_1/2"_hole,_wha
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4610841
12/22/17 04:14 AM
12/22/17 04:14 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Stainless plugs and bolts, in aluminum, and immersed in salt water is common in the marine industry and stuff manages to survive.
I would not worry, but if it does bother you, just swap on next oil change.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4610896
12/22/17 07:11 AM
12/22/17 07:11 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
The threads are quite likely to be oiled.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611090
12/22/17 11:24 AM
12/22/17 11:24 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
What kind of plugs were in there originally? SS is very stable.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611107
12/22/17 11:43 AM
12/22/17 11:43 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
Assuming you change the oil on occasion, there
won't be a problem.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611153
12/22/17 12:24 PM
12/22/17 12:24 PM
Canada
boraticus Offline
boraticus  Offline
Canada
If that concerned put some grease on the threads of the plugs.
Considering that there will be virtually no water getting between the plugs and the block, and there will be residual oil there, I wouldn't be worried in the least.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611160
12/22/17 12:27 PM
12/22/17 12:27 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Millions and million and millions of aluminum oil pans and transmissions use steel drain plugs. No issues ever.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611206
12/22/17 01:10 PM
12/22/17 01:10 PM
indiana
dakota99 Offline OP
dakota99  Offline OP
indiana
Thanks for the input guys. The other half of me thought it would be fine as well, just wanted to make sure. I do believe the original fitting material was zinc plated steel or something to that effect. The oil gets changed every two years or 100 hours.
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4611505
12/22/17 06:16 PM
12/22/17 06:16 PM
Illinois
tig1 Offline
tig1  Offline
Illinois
Most assuredly OCD in this application.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Stainless steel drain plugs in aluminum? [Re: dakota99] #4612435
12/23/17 07:33 PM
12/23/17 07:33 PM
Watertown, New York
cronk Offline
cronk  Offline
Watertown, New York
Mild steel, stainless steel, both are fine.
Stainless fasteners can sometimes be victim of thread galling when threading into a harder steel, but an aluminum small engine case is softer than the stainless, so no worries.
2008 Ford F350
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
Amsoil lubes and filters!
