99 GMC Sierra UOA
FL, US
Truck has been using coolant these past 5-6 months with no obvious exterior leaks. A gallon of coolant will last me 3 months. I just top it off every couple weeks. Truck does not overheat & does not burn oil, but leaks from rear main seal. The oil did not look milky on the dipstick & neither did the oil when I drained it. Intake gasket or head gasket? Truck is a 99 Sierra with the 4.8
Time for a cooling system pressure test. See if the coolant ends up pooling in your crankcase, or in a cylinder.
Leave all the plugs out while you test. The offending cylinder (if there is one) will begin dumping coolant out of the hole. That will be a head gasket.
If it's only in the crankcase, then try just intake manifold.
Every once in awhile I’ll get a check engine light. When I scanned it, it said it was running lean on bank one.
Were the intake gasket issues still around in 99? My 97's 5.7 were replaced under a recall/warranty but that might not have been for a couple/few years after 97, I can't remember?
Wouldn't the oil be milky if the head gasket was bad? The oil I drained, which was the same oil I sent to Blackstone, was not milky at all. Was black like it always is after 5,000 miles. I've already put 400 miles on the new oil & pulled the dipstick, & it's not milky at all. Just condensation on the oil cap & filler neck. I'm gonna do what Blackstone says though, & change the oil every 2,000 miles or less till I figure it out. Still runs great & doesn't misfire, overheat, or anything. Just the high lead, sodium, & potassium levels worry me.
Originally Posted By: caravanmike
Could be the castec head failure?
1999 was not affected by Castech head casting failures.....But the heads could have been swapped out I guess, If it has "706" casting numbers, They have been swapped as that casting number didn't exist in 1999.
Not necessarily If the leak is small enough! The intake is "dry" on LS engines so it's not the intake gaskets. No oil cooler on a 4.8L.
That leaves a head gasket leak or a Busted/Cracked cylinder head.
Worth it to replace head gaskets, or should I just replace the whole engine? Engine runs great but has 223,000 miles on it. Has brand new fuel pump, new a/c compressor, rear end work done, & suspension work. So this is a truck I intended to drive for another 4-5 years as I got a lot of time & money invested in it. Didn't expect the head gaskets to start going, as this truck has never been overheated or abused in the 6 years I've owned it. I've owned older Chevy & GMC trucks they never had engine problems. Only had to replace normal stuff like fuel pumps, u joints, alternators, starters & a/c compressors due to high mileage.
I have a 1986 k-20 GM 6.2L Diesel 4x4,that has similar problem.Ive been driving it that way for 25yrs.Its a great truck. (270,000 mi.)
Once the truck warms up it starts putting out a slight white fog/smoke at idle. Lots of moisture in the exhaust too, & this is after driving it home from work 15 minutes away. My trusted shop I’ve been going to for almost 15 years is gonna do a leak test on it. He said if it is the head gasket, it will be a little over $1,000 but that includes sending the heads to a machine shop. Seems reasonable.
I would drop a good used LQ4 or LQ9 6.0L in it, I bought a wreaked 2006 3500 Express Van with 86,000 miles last month for $800 with a sweet running LQ4.
A LQ4/LQ9 will bolt right in place of a LR4 4.8L (You will have to use the LR4 flexplate on a LQ4)
The PCM will need to be tuned for the increase in cylinder air-mass....Which is only super critical at WOT/Open Loop operation. I can do the tuning for $200 if needed.
A LM7 5.3L is also a good in-between option that does not require PCM tuning (I have verified it with a wide-band), In reality.....The LR4 is tuned a little rich from the factory.
