2008 Chevy Malibu 3.6L V6
by lordcheeto. 12/13/18 07:36 PM
power company merged and I got the shaft
by motor_oil_madman. 12/13/18 07:19 PM
Space heater burnt smell
by BossMoss. 12/13/18 07:13 PM
Shell Helix Ultra Maserati 10W-60
by wemay. 12/13/18 06:53 PM
Cox Modem Info???
by Gebo. 12/13/18 06:39 PM
How are these Road Force values?
by mclasser. 12/13/18 05:19 PM
Finally broke down a bought a trailer
by BeerCan. 12/13/18 04:25 PM
What oil for '19 Subaru WRX?
by TKNY. 12/13/18 04:12 PM
Splitting wedges
by buck91. 12/13/18 04:00 PM
Avoiding rust in the rust belt states?
by Chris B.. 12/13/18 03:00 PM
Joey Logano and the 2019 Mustang
by Malo83. 12/13/18 02:40 PM
BMW LL01FE Spec
by The Critic. 12/13/18 02:03 PM
I Tried and Failed to Not Buy a New Car
by badtlc. 12/13/18 01:49 PM
lordcheeto, WondrousBread, slickoo9, turntable_life, Poles19
66670 Registered Users
100 registered members (92saturnsl2, andyd, Audios, 53' Stude, 69GTX, alcyon, 11 invisible), 1,788 guests, and 33 spiders.
Topics295,043
Posts4,926,561
Members66,670
Most Online2,553
Oct 27th, 2018
New wheels/tires, bigger #4610584
12/21/17 07:46 PM
12/21/17 07:46 PM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
Hi all,
Thinking about putting some new wheels on my Sonata, currently has 17's. Going to go up to 18's. I have the Limited trim and it came with 17's and the Sport trim has 18's. I'm wondering what the overall difference might be by doing so? I know it won't ride quite as well but I don't think it'll be a huge degradation. I am hoping however that it'll help the handling because right now it's not that great. I'm a pretty spirited driver most of the time and the handling just isn't made for that. Biggest problem is body roll in corners (really needs stiffer springs) and I'm hoping the less cushy tires will reduce that. Just wondering how other's cars have changed by putting on larger wheels.
Thanks!
And if you're wondering which wheels: https://cdn.discounttire.com/sys-master/...kes_5_20_dp.png
And yes I know that the larger wheels will reduce the life of my shocks, struts, and other suspension components.
'18 Honda Accord Touring, 1.5T, Factory Fill/Filter
'17 Elantra, 2.0L, 22,500, QS Ult. 0w20 w/ FU, hers (lease)
Re: New wheels/tires, bigger [Re: Throt] #4610600
12/21/17 07:56 PM
12/21/17 07:56 PM
new jersey
hemitruck Offline
hemitruck  Offline
new jersey
Your correct, will degrade the ride, but the shorter sidewall might improve handling a little.
Re: New wheels/tires, bigger [Re: Throt] #4610612
12/21/17 08:05 PM
12/21/17 08:05 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
The only reason is look or to fit big brakes.
Otherwise new tires can improve anything you find deficient with the current ones.
be it handling, traction etc.
Re: New wheels/tires, bigger [Re: Rand] #4610621
12/21/17 08:12 PM
12/21/17 08:12 PM
Canton, Ohio
Throt Offline OP
Throt  Offline OP
Canton, Ohio
For sure, the OEM Kumho's are eh. I'm not enthralled with them to say the least. Main reason is looks but a super close second is truly to try and improve the handling even marginally. I thought about lowering springs but that's just not my style. Never really understood the desire for lowered look (nor the practicality) myself but to each his own.
Re: New wheels/tires, bigger [Re: Throt] #4610628
12/21/17 08:24 PM
12/21/17 08:24 PM
South Carolina
eyeofthetiger Offline
South Carolina
18" wheels and lower profile tires will make the ride rougher, and make turn-in feel a bit sharper (depending on the tires). However, the amount of body roll will not change much, and the 18" wheel/tire combo is likely to be heavier (but very dependent on wheel and tire choice), more expensive, and more fragile. I see you are in Ohio, and I know the roads there are not glassy smooth. The trend towards bigger and bigger rimz on normal cars is almost completely to maintain the styling proportions with rising belt-lines.
I would stick with the 17" wheel size and consider switching to some high quality, high performance tires. You could try going an inch or so wider on the wheel, and slightly wider on the tire.
Does the Sport trim have different (stiffer) suspension such as coil springs, dampers and/or anti-roll bars? If so, consider looking up the parts in a Hyundai catalog and comparing the part numbers. It may be worth it to install the Sport suspension for your driving style.
I am in a similar quandry with my Fiesta, but Ford has made it easy by offering a Ford Racing handling pack for just over $200. I am sticking with the 15" wheel size all day long. They are extremely lightweight, and the tires are dirt cheap.
2017 Ford Fiesta 1.0T - Valvoline SynPower 5W-20, Motorcraft FL910S
1988 GMC K1500 4.3/700R4 - Supertech 15W-40, Fram TG3980
1986 Ford Ranger 2.0 - uhh
Re: New wheels/tires, bigger [Re: Throt] #4610631
12/21/17 08:27 PM
12/21/17 08:27 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Swaybar(s) would help. What tires do you have, and what pressure do you run? I just put on some good tires on my Focus and it certainly corners faster, with slightly more bodyroll due to more grip. Probably just upping your tire pressure 5 psi would be a good simulation of what 1" larger rims will feel like, handling and ride wise.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: New wheels/tires, bigger [Re: Throt] #4610643
12/21/17 08:39 PM
12/21/17 08:39 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Ive got 16 wheels on mine, and I dont think handling is bad at all.
Ive got the Kumho Solus TA11s too, hate them. They were new when I bought the car, but 18k miles later theyre really loud. Handling is ok I guess.
Id love 17 wheels!
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: New wheels/tires, bigger [Re: Throt] #4610668
12/21/17 09:10 PM
12/21/17 09:10 PM
Great Lakes
Quattro Pete Offline
Great Lakes
Bigger wheels are not going to do anything for you as far as body roll. The only thing you might gain is quicker steering response due to shorter sidewall. However, you could also improve steering response just by putting on more sporty/stiffer tires on your current 17" rims.
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: New wheels/tires, bigger [Re: Throt] #4610714
12/21/17 10:15 PM
12/21/17 10:15 PM
Northern Ontario, Canada
Danno Offline
Danno  Offline
I had a 2013 Sonata until it got totalled. Its a family sedan, meant to be safe reliable transportation. You can spend a lot of money on a plus 1 setup and see miniscule gains. I think Quattro Pete has the right idea.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
Re: New wheels/tires, bigger [Re: Throt] #4610861
12/22/17 04:23 AM
12/22/17 04:23 AM
ROCHESTER, NY
Char Baby Offline
Char Baby  Offline
ROCHESTER, NY
Unless you really want to spend money on new wheels too, you can just change the speed rating and performance rating of the 17" tires that you have now and increase your handling, steering feel, less body roll.
I just did this(inadvertently) with my 2015 Altima 2.5SV, which has 215-55-17 Michelin MXV4 "V" speed rated. I have changed to a set of Cooper CS4's "T" speed rated that I had on hand from my other/previous 2004 Altima 2.5S. Not because I wanted the CS4's, I did this mainly due to just needing a better tire for the winter without investing in winter tires.
The "T's" actually out handle the "V's" in normal type of driving. IDK if higher performance driving would be different as I only drive normally.
But, what a difference(SOTP) it made in less body roll around the corners and the steering feel is more direct as well. I don't particularly like the extra firmness and more audible sounds of the CS4's but, I'll accept this tradeoff for the winter and put the Michelin's back on in the Spring. Both tires are on their own set of wheels.
IDK exactly you're looking to increase with your Sonata, if it's just a little or a lot however, you can do this with a different tires and still stay with 17" tire(if money is an issue) without spending the extra money on wheel/tire pkg...unless as I stated, you want new wheels too!
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic LX
Re: New wheels/tires, bigger [Re: Throt] #4610901
12/22/17 06:18 AM
12/22/17 06:18 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Ohio?
Pick up some nice 18's with a decent set of summer tires. If you do it right they'll be lighter, look better, have sharper response, and they'll be quieter with better handling in the dry AND wet. Impacts like expansion joints a potholes may be a little sharper but the overall ride quality won't change much like the sensitive butts here would have you believe.
Don't buy junk wheels or tires; the goal is light and strong, not heavy and weak.
Slap some good winter rubber on the 17's.
"Zed's dead baby, Zed's dead."
Re: New wheels/tires, bigger [Re: Throt] #4610947
12/22/17 07:29 AM
12/22/17 07:29 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
Body roll? You're not going to fix that much with tires - unless you're going from a 70 series down to a 45 series.
If that's your goal: Springs, sway bars, and shocks. Kind of expensive!
Unless you are like spending money, my advice would be to wait until those tires wear out and replace them with something more sporty.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: New wheels/tires, bigger [Re: CapriRacer] #4610964
12/22/17 07:53 AM
12/22/17 07:53 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
You made so much money breaking your landlord's washing machine you can afford 18" wheels? .......not bad.
Just bustin'
Re: New wheels/tires, bigger [Re: Throt] #4610988
12/22/17 08:43 AM
12/22/17 08:43 AM
Imperial Valley, California
Jeffs2006EvoIX Offline
I will chime in since I had a Sonata with 18's.
I had a 2011 Sonata Sport that had the 18 inch factory rims. I thought they looked beautiful and filled the wheel wells well. My wife has a 2012 Sonata GLS that came with 16's.
The 2011 Sport or SE at the time, did handle better, but I dont think it was because of the rims and tires. The Sport model has different shocks, spring rates, different sway bar diameters plus I noticed my car had aluminium lower control arms front and rear where as the GLS and others have stamped steel.
So if your wanting to go up to 18's from 17's? I dont think you will notice much of a difference other than having to watch for pot holes now since you would be riding on 40 series tires. There are so many other bits that are involved model to model than you realize.
If you want a better handling Sonata I would check out a site called SharkRacing.com These folks are the performance arm of Hyundai and sell performance oriented parts for your car. Look into a different Strut/Spring set up and anti roll bars set up. You could even order the parts off the Sport model and install them on your Limited.
This I believe will net you the best "handling" without having the drawbacks of a 40 series tire. Aesthetically I think 18's or larger look fantastic, but first pot hole you hit and bend a rim? Just not worth it for what little added benefit there really will be.
Just my thoughts..
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
Re: New wheels/tires, bigger [Re: rooflessVW] #4611133
12/22/17 11:07 AM
12/22/17 11:07 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Cheap, strong, light. Pick two.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
