B164 Bypass dissection.
by Purpfox. 01/20/19 12:02 PM
Pics - 2005 Highlander 3.3L 158k miles
by dkryan. 01/20/19 11:21 AM
Chinese nuclear momentum
by OVERKILL. 01/20/19 10:35 AM
Winter finally arrived
by StevieC. 01/20/19 10:27 AM
Octane rating of UL94 avgas
by Altydoc. 01/20/19 09:55 AM
Any bowlers out there?
by 53' Stude. 01/20/19 08:10 AM
Future of subcompact cars?
by Char Baby. 01/20/19 07:15 AM
Are u a roller coaster fan?
by ZZman. 01/20/19 07:03 AM
DUST - a couple of short Sci Fi films
by Shannow. 01/20/19 05:46 AM
5W30 Synthetic Oils With HTHS of 3.5 ?
by ChrisD46. 01/20/19 04:02 AM
White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
Rob_from_Madison, SubieSTI, ebersvc, junk1020, fairparts99
66987 Registered Users
111 registered members (02z, 53' Stude, 77GrandPrix, 240_Ed, 14 invisible), 2,396 guests, and 37 spiders.
Topics296,878
Posts4,960,726
Members66,987
Most Online2,688
Jan 19th, 2019
99 GMC Sierra UOA #4610523
12/21/17 06:48 PM
12/21/17 06:48 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Truck has been using coolant these past 5-6 months with no obvious exterior leaks. A gallon of coolant will last me 3 months. I just top it off every couple weeks. Truck does not overheat & does not burn oil, but leaks from rear main seal. The oil did not look milky on the dipstick & neither did the oil when I drained it. Intake gasket or head gasket? Truck is a 99 Sierra with the 4.8
Re: 99 GMC Sierra UOA [Re: tech230] #4610527
12/21/17 06:53 PM
12/21/17 06:53 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Some gunk on the oil cap & filler neck.
Re: 99 GMC Sierra UOA [Re: tech230] #4610529
12/21/17 06:56 PM
12/21/17 06:56 PM
Fort Lauderdale, FL
DoubleWasp Online content
DoubleWasp  Online Content
Fort Lauderdale, FL
Time for a cooling system pressure test. See if the coolant ends up pooling in your crankcase, or in a cylinder.
Leave all the plugs out while you test. The offending cylinder (if there is one) will begin dumping coolant out of the hole. That will be a head gasket.
If it's only in the crankcase, then try just intake manifold.
Re: 99 GMC Sierra UOA [Re: tech230] #4610534
12/21/17 07:00 PM
12/21/17 07:00 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Every once in awhile Iíll get a check engine light. When I scanned it, it said it was running lean on bank one.
Re: 99 GMC Sierra UOA [Re: tech230] #4610549
12/21/17 07:15 PM
12/21/17 07:15 PM
ohio
caravanmike Offline
caravanmike  Offline
ohio
Could be the castec head failure?
Oils I use: Any 5w-30,5w-20 conventional
Re: 99 GMC Sierra UOA [Re: tech230] #4610583
12/21/17 07:46 PM
12/21/17 07:46 PM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Were the intake gasket issues still around in 99? My 97's 5.7 were replaced under a recall/warranty but that might not have been for a couple/few years after 97, I can't remember?
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: 99 GMC Sierra UOA [Re: tech230] #4610656
12/21/17 08:57 PM
12/21/17 08:57 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Wouldn't the oil be milky if the head gasket was bad? The oil I drained, which was the same oil I sent to Blackstone, was not milky at all. Was black like it always is after 5,000 miles. I've already put 400 miles on the new oil & pulled the dipstick, & it's not milky at all. Just condensation on the oil cap & filler neck. I'm gonna do what Blackstone says though, & change the oil every 2,000 miles or less till I figure it out. Still runs great & doesn't misfire, overheat, or anything. Just the high lead, sodium, & potassium levels worry me.
Re: 99 GMC Sierra UOA [Re: caravanmike] #4610679
12/21/17 09:31 PM
12/21/17 09:31 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
1999 was not affected by Castech head casting failures.....But the heads could have been swapped out I guess, If it has "706" casting numbers, They have been swapped as that casting number didn't exist in 1999.
2001 Chevy Camaro L92/4L80E
Re: 99 GMC Sierra UOA [Re: tech230] #4610689
12/21/17 09:44 PM
12/21/17 09:44 PM
Fort Worth, Texas
clinebarger Offline
clinebarger  Offline
Fort Worth, Texas
Not necessarily If the leak is small enough! The intake is "dry" on LS engines so it's not the intake gaskets. No oil cooler on a 4.8L.
That leaves a head gasket leak or a Busted/Cracked cylinder head.
Re: 99 GMC Sierra UOA [Re: tech230] #4610740
12/21/17 10:49 PM
12/21/17 10:49 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
The 4.8 has a dry intake. A common problem was the heads cracking on the valve spring side
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 99 GMC Sierra UOA [Re: clinebarger] #4610754
12/21/17 11:09 PM
12/21/17 11:09 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Worth it to replace head gaskets, or should I just replace the whole engine? Engine runs great but has 223,000 miles on it. Has brand new fuel pump, new a/c compressor, rear end work done, & suspension work. So this is a truck I intended to drive for another 4-5 years as I got a lot of time & money invested in it. Didn't expect the head gaskets to start going, as this truck has never been overheated or abused in the 6 years I've owned it. I've owned older Chevy & GMC trucks they never had engine problems. Only had to replace normal stuff like fuel pumps, u joints, alternators, starters & a/c compressors due to high mileage.
Re: 99 GMC Sierra UOA [Re: tech230] #4610761
12/21/17 11:23 PM
12/21/17 11:23 PM
Maryland USA
rubberchicken Offline
Maryland USA
You might consider GM Cooling tabs to slow down the coolant loss. The pictures to me clearly indicate coolant- sort of a reddish hue.
Re: 99 GMC Sierra UOA [Re: tech230] #4610787
12/22/17 12:01 AM
12/22/17 12:01 AM
california
slowrench Offline
slowrench  Offline
california
I have a 1986 k-20 GM 6.2L Diesel 4x4,that has similar problem.Ive been driving it that way for 25yrs.Its a great truck. (270,000 mi.)
Re: 99 GMC Sierra UOA [Re: tech230] #4610845
12/22/17 03:24 AM
12/22/17 03:24 AM
Fort Lauderdale, FL
Fort Lauderdale, FL
Replace the engine. 4.8 motors are cheap as rocks.
Re: 99 GMC Sierra UOA [Re: tech230] #4611442
12/22/17 03:52 PM
12/22/17 03:52 PM
FL, US
tech230 Offline OP
tech230  Offline OP
FL, US
Once the truck warms up it starts putting out a slight white fog/smoke at idle. Lots of moisture in the exhaust too, & this is after driving it home from work 15 minutes away. My trusted shop Iíve been going to for almost 15 years is gonna do a leak test on it. He said if it is the head gasket, it will be a little over $1,000 but that includes sending the heads to a machine shop. Seems reasonable.
