How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Careers.....Boomers vs Millennias
by ZZman. 03/18/19 08:05 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
108 registered members (aquariuscsm, AandPDan, advocate, aircooled, 2003f7, 53' Stude, 13 invisible), 2,309 guests, and 55 spiders.
Topics286,017
Posts4,900,829
Members67,548
Most Online2,967
Mar 10th, 2019
Help me find out what this is called? #4610474
12/21/17 06:57 PM
12/21/17 06:57 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Hi all, I am trying to obtain a part for my side entry door. Currently, where the door handle latch clicks into the framing is fine, and then I have the deadbolt lock above it that when locked the deadbolt goes into the hole in the framing. Currently the framing is very thin and cracked, I have since fixed this, and the problem is that there is no solid wood to use long 3 inch screws to screw the latch into.. so im going to screw a stronger piece of wood into the framing to reinforce it so it cant get kicked in. ( I apologize, I believe I am not explaining this too well/ hard to explain) Essentially the deadbolt when locked exceeds the length of the framing, and therefore.. cold air is entering my house... despite the fibreglass insulation thats stuffed in there. I am trying to find the name of the following piece... the black piece in this link that is in the middle.. I cant seem to find out what its called and therefore making it hard to obtain. I have checked our large chain renovation stores but they do not seem to carry this piece... Please let me know if you can name the piece for me.. Thank you in advance!
I only am looking for the middle black piece that is shown in the middle of the other 2 parts here...
https://www.amazon.com/CRL-Deadlatch-Str...atch+Strike+Set
Also, the stud is not directly behind where the deadbolt strike set is attached.. more on an angle, so i guess not much way to reinforce it besides adding another piece of stronger wood to the framing and use longer screws?
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Help me find out what this is called? [Re: Rolla07] #4610478
12/21/17 07:02 PM
12/21/17 07:02 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
I am seeing the wording "Strike box plate" but this doesnt always refer to the enclosed piece that accepts the deadbolt...
PP 0w20 & ST 4967
Re: Help me find out what this is called? [Re: Rolla07] #4610482
12/21/17 07:04 PM
12/21/17 07:04 PM
PimTac Offline
PimTac  Offline
I think that is what they call the dustbox. It’s usually plastic. It doesn’t add any strength to the hole.
Cannot see signatures any longer so it doesn’t matter.
Re: Help me find out what this is called? [Re: PimTac] #4610486
12/21/17 07:06 PM
12/21/17 07:06 PM
MTL, CANADA
Rolla07 Offline OP
Rolla07  Offline OP
MTL, CANADA
Yeah, sounds right.. I am just looking for that piece to prevent cold air from entering in via the deadbolt, which I think this dustbox would help with... piece doesnt seem too common... I guess I find it odd that this wouldnt be used more.. normal to just have fibreglass batt pieces shoved in there, that the deadbolt would pretty much press against when door gets locked.
PP 0w20 & ST 4967
Re: Help me find out what this is called? [Re: Rolla07] #4610530
12/21/17 07:58 PM
12/21/17 07:58 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
What if you use some expanding foam in the cavity and then cut away the excess so the deadbolt clears? You won't get any air penetration this way.
Re: Help me find out what this is called? [Re: Rolla07] #4610537
12/21/17 08:01 PM
12/21/17 08:01 PM
MI
doitmyself Offline
doitmyself  Offline
MI
Google "armored security strike plate" if you just want an enclosed deadbolt cavity.
If you want your deadbolt to be kick proof, you will have to install something stronger than just going into your door casing. There are many different systems out there to achieve this. Examples are StrikeMaster II Pro, Door Armor, and EZ Armor.
