Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
21 registered members (billt460, Donald1953, barryh, 53' Stude, Char Baby, bbhero, 3 invisible), 847 guests, and 41 spiders.
Topics295,007
Posts4,925,899
Members66,664
Most Online2,553
Oct 27th, 2018
1965 Allis Chalmers OEM Bypass Filter #4609790
12/20/17 11:11 PM
12/20/17 11:11 PM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
Thought I'd show you guys my 1965 Allis Chalmers Buda 4BD153 diesel bypass filter system. I'm restoring this old forklift and went to change the filter and realized it was a bypass filter. There is no full flow oil filter, but instead a Napa 10 um bypass filter. I've got no idea how many years or hours are on the filter, but I cut it open to see if there was any nasty stuff in the filter. I found no metal or any debris and took an oil sample to have analysed. Here's some pictures:)
2009 Ford F-350 (Detroit 4-53T)
2000 Ford Excursion (Triton V10)
1993 Dodge D250 (Cummins 6BT)
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4609801
12/20/17 11:50 PM
12/20/17 11:50 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
My 1957 case 300 uses the same filter.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4609802
12/20/17 11:51 PM
12/20/17 11:51 PM
Spocant WA
silverbar Offline
silverbar  Offline
Spocant WA
Probably been on there since last annual oil change.
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4609869
12/21/17 06:25 AM
12/21/17 06:25 AM
Kansas
Kruse Offline
Kruse  Offline
Kansas
I've got a Cockshutt 30 tractor with the Buda 4B153 gasoline engine. When you look at the conditions these engines operated in, and saw the primitive filtration system these engines had, it's amazing that they still run after decades of hard use.
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4610193
12/21/17 12:46 PM
12/21/17 12:46 PM
Spocant WA
silverbar Offline
silverbar  Offline
Spocant WA
Yes, splash and drip lube can work quite well on agricultural engines. Throw in a modern oil filter if you got an oil pump and the thing will last more forever.
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4611182
12/22/17 11:50 AM
12/22/17 11:50 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
How gritty is this stuff?
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4611238
12/22/17 12:43 PM
12/22/17 12:43 PM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
Biggest help to a lot of these old engines, magnetic drain plug smile
They don't spin fast enough to aerate the oil. The bearings are big and teh steel is usually good smile
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: Linctex] #4615643
12/27/17 10:59 AM
12/27/17 10:59 AM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
It's mostely carbon and a bit of sludge. The engine has had a history of no oil changes as the head and oil pan have a layer of hard carbon on them. I cleaned most of it off and will run Rotella T 15W40 in it from now on, so that will clean it up nicely. Overall I'm very happy with the condition of the engine all things considered. I finished rebuilding the injector pump and got the engine running again and it runs really well with no blowby, so very happy indeed.
Re: 1965 Allis Chalmers OEM Bypass Filter [Re: A310] #4615645
12/27/17 11:01 AM
12/27/17 11:01 AM
Kelowna, BC, Canada
A310 Offline OP
A310  Offline OP
Kelowna, BC, Canada
P.S. I did take an oil sample and will ship that off to BlackStone labs in the coming days, be interested to see what that says.
