Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
40 registered members (AZjeff, Char Baby, bullwinkle, Ctreasure, 97K15004WD, 6 invisible), 988 guests, and 39 spiders.
Topics295,207
Posts4,929,906
Members66,711
Most Online2,553
Oct 27th, 2018
alternative to foam filter oil & cleaner? #4609734
12/20/17 09:44 PM
12/20/17 09:44 PM
Palmyra, PA
kmrcstintn Offline OP
Palmyra, PA
my 'new to me' v star 250 has a foam air filter element; not really interested in buying uber expensive foam filter oil & cleaner (tightening my budget due to unpaid time off work); what are good alternatives for cleaning & oiling foam filters?
'15 Jeep Patriot Sport (2.4L 4-cyl), '13 Genuine Buddy 125 (125cc air-cooled thumper), '14 Yamaha V Star 250 (250cc air cooled v-twin)
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609741
12/20/17 09:54 PM
12/20/17 09:54 PM
South Eastern, CT
AMC Offline
AMC  Offline
South Eastern, CT
Chainsaw bar oil for the oil and Kerosene to clean it.
I do like the No-toil filter treatment system and it is one of the cheaper foam filter kits, if that is in your budget. The most expensive part about No-toil is the cleaner. The cleaner is said to be very similar to oxy-clean and oxy-clean is available cheap at Wal-Mart; so that could lower the cost a bit.
18 Honda CR-V - Mobil-1 AFE 0w-20
17 Ram 1500 SLT - Napa Synthetic 5w-20
14 Yamaha Super Tenere - Mobil Delvac 15w-40
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609742
12/20/17 09:54 PM
12/20/17 09:54 PM
California
David_g Offline
David_g  Offline
California
What oil does Yamaha recommend? Last one I had the factory recommendation was 30 engine oil.
2007 BMW R1200R (Mobil 1 15W50, Red Line Shockproof Heavy, Supertech 75W90)
2016 Honda Africa Twin DCT (Motul 5100 10W40)
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609744
12/20/17 09:55 PM
12/20/17 09:55 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Never had one, but I think at least some of them were cleanable with kerosene and oilable with motor oil.
If you have an old one you could test to see if it falls apart.
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609775
12/20/17 10:40 PM
12/20/17 10:40 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Any solvent and any oil will do...but a non filter oil will be prone to dripping out the bottom. Any seam in the filter is the failure point, but they also just fall apart with age. Instructions for my Piaggio scooter are to wash in premix...which is a bit strange as it has an oil pump and doesn't run on premix, and at 50:1 there won't be much oil in the filter.
1987 BMW R65 - Aegis SAE30
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609809
12/21/17 12:05 AM
12/21/17 12:05 AM
Maryland USA
rubberchicken Offline
Maryland USA
I am assuming you are comparing a K&N air filter to the stock paper filters. I checked on Amazon and the K&N Filter Care kit (cleaner and oil) is $13. I doubt you could get a paper filter cheaper than $13.
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609852
12/21/17 05:09 AM
12/21/17 05:09 AM
Pennsylvania
Slick17601 Offline
Slick17601  Offline
Pennsylvania
Simple Green works great for cleaning.
2018 Ram Bighorn 5.7
2008 Toyota Sienna 3.5
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609863
12/21/17 06:03 AM
12/21/17 06:03 AM
Oshawa, Ont. Canada
irv Offline
irv  Offline
Oshawa, Ont. Canada
Twin-Air filters also have cleaning solutions available.
https://www.twinair.com/
2017 Chevy Impala 3.6 L.
2013 Ram 5.7 L Hemi Bighorn QC 4x4
2008 Chevy Malibu 2.4 L Ecotec
Pennzoil Platinum and/or Pennzoil Ultra Platinum in all 3.
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4609872
12/21/17 06:35 AM
12/21/17 06:35 AM
wv
krismoriah72 Online content
krismoriah72  Online Content
wv
I have ridden dirtbikes and atvs for 25 years, now into UTVs.. so i have cleaned and oiled many filters.
To clean- dawn and warm water. (simple green is good also but most people have dawn already).
To oil- Bel-Ray is one of the best and $6.99 should last you a couple of years.
https://www.rockymountainatvmc.com/p/932/4289/Bel-Ray-Foam-Air-Filter-Oil-Spray
You are lucky that you have a reusable foam filter and not a paper filter that you have to replace..
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4610214
12/21/17 01:05 PM
12/21/17 01:05 PM
New York
jeff78 Offline
jeff78  Offline
New York
Hmmm......I just did a quick price check on the filter, it's $9 at Partshark. Might be more economical simply replacing the thing rather than cleaning it, depending on how much the filter oil and cleaner cost and how much your time is worth to you.
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4610380
12/21/17 03:51 PM
12/21/17 03:51 PM
Canada
i_hate_autofraud Offline
Canada
If there's a MAF sensor on the engine, make sure the oil on the filter does not get sucked onto the MAF or
it'll malfunction or set a code. If anything, oil the filter and squeeze out extra between paper towels, etc
Re: alternative to foam filter oil & cleaner? [Re: Silk] #4614424
12/26/17 07:51 AM
12/26/17 07:51 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Thats pretty thin premix. If that's their specific recommendation I suppose it might be to avoid over-oiling, since most of the petrol will evaporate. Do they have you squeeze it, blot it or just drip/air dry?
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4616068
12/27/17 05:37 PM
12/27/17 05:37 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Squeeze. Pointless as there will be hardly any oil. I forget what I did, but wasn't that. Engine oil...or I may have used some NoToil, but I don't like the stuff, so I doubt it. I might revisit the air filter over my holiday break, see how it looks after a year.
Re: alternative to foam filter oil & cleaner? [Re: Silk] #4616190
12/27/17 08:30 PM
12/27/17 08:30 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Hardly any oil might be about right. I'd think it'd take a while to dry though and if you put it on wet it'll tend to suck most of it into the engine
Re: alternative to foam filter oil & cleaner? [Re: kmrcstintn] #4619248
12/30/17 09:51 PM
12/30/17 09:51 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
I had a look at my filter today, looks like I used engine oil...and it's pooled to the bottom of the filter. That's why I don't like to use engine oil. So I No-Toiled it.
