XG3614 Cut Open 13,400kms (8,375mi)
by mcwilly. 09/22/18 05:25 PM
Torn Purolators: they DO TEAR!
by 53' Stude. 09/22/18 05:07 PM
transmission fluid and filter exchange
by Dennisistheman. 09/22/18 04:53 PM
Why people should change oil+filter!
by 53' Stude. 09/22/18 04:50 PM
Household lubricants (general purpose) differences
by 92saturnsl2. 09/22/18 04:35 PM
debris in my engine oil--what to do?
by Jasper8146. 09/22/18 03:50 PM
Is this seal bad?
by parshisa. 09/22/18 03:44 PM
Leather Masters Protection Cream review....
by gregk24. 09/22/18 03:13 PM
Aisin WS
by RodneyM. 09/22/18 03:11 PM
Husqvarna trimmer questions
by BrianF. 09/22/18 02:51 PM
Uber Self-Driv Death: Disabled Pedest Avoidance!!!!
by oil_film_movies. 09/22/18 02:29 PM
Question on Backlight setting on LED tv's
by LoneRanger. 09/22/18 02:16 PM
Are all Dexos 1 Gen 2 Oils the Same?
by Gene K. 09/22/18 01:58 PM
ECOGARD X10479 CUT OPEN
by 53' Stude. 09/22/18 01:38 PM
Rust-Oleum Driveway Sealer review
by SVTCobra. 09/22/18 01:24 PM
Flush OAT/IAT mixture
by OpenClose. 09/22/18 12:20 PM
And They Say Spelling is Not Important.
by PimTac. 09/22/18 12:06 PM
Toyota Genuine oil 10W30
by gordond. 09/22/18 09:27 AM
Sarrge, Big_R, gordond, mrgreggn, JRMFt11
66040 Registered Users
86 registered members (2013ecof150, 77GrandPrix, 65convertible, 53' Stude, 92saturnsl2, A310, 8 invisible), 1,716 guests, and 39 spiders.
Topics290,837
Posts4,851,215
Members66,040
Most Online3,590
Jan 24th, 2017
300 Blackout pistol build #4609502
12/20/17 06:29 PM
12/20/17 06:29 PM
Western usa
Ammofirst Offline OP
Western usa
Iím doing my first AR pistol build. I think build isnít really the accurate term as Iím just buying the upper & lower ready to go then adding a KAK Shockwave. This is the Upper : http://palmettostatearmory.com/psa-10-5-...-516446429.html : Could someone recommended a lower that is just ready to go, plug & play for the upper listed above ? Palmettoís offering http://palmettostatearmory.com/psa-ar-15...azine-7065.html : Looks fine but I cant use the furniture. Thanks
Re: 300 Blackout pistol build [Re: Ammofirst] #4609571
12/20/17 07:44 PM
12/20/17 07:44 PM
MO
wkcars Offline
wkcars  Offline
MO
I like this lower instead of shockwave http://palmettostatearmory.com/psa-ar-15...-516446451.html palmetto also had some 10.5 complete uppers with CHF barrels with nickel boron bcg and charging handle for $349 but i don't see it listed anymore maybe they ran out
Re: 300 Blackout pistol build [Re: Ammofirst] #4609637
12/20/17 08:39 PM
12/20/17 08:39 PM
Western usa
Western usa
Yes, I saw that option. But Iím going with the KAK shockwave brace. Iím sure that SB is over $200.00 by itself. Iím looking for lower options without the brace.
Re: 300 Blackout pistol build [Re: Ammofirst] #4609713
12/20/17 10:11 PM
12/20/17 10:11 PM
MO
wkcars Offline
wkcars  Offline
MO
PSA has complete lowers with the shockwave seems out of stock right now but it usually goes for $199. or you can get a complete lower http://palmettostatearmory.com/psa-ar-15...-516445009.html and install the kak buffer tube and shockwave yourself.
Re: 300 Blackout pistol build [Re: Ammofirst] #4609737
12/20/17 10:48 PM
12/20/17 10:48 PM
Western usa
Western usa
Thanks. I must be missing something. Other than the stock tube whatís the difference between these 2 lowers http://palmettostatearmory.com/psa-ar-15...516445009.html. & https://www.sportsmansguide.com/product/...liber?a=2094521
Re: 300 Blackout pistol build [Re: Ammofirst] #4609815
12/21/17 01:50 AM
12/21/17 01:50 AM
MO
wkcars Offline
wkcars  Offline
MO
the palmetto has magpul grip vs the regular grip on the anderson. palmetto has magpul trigger guard more rounded to have extra room for gloved vs the flat bar on the anderson. palmetto has their nickel boron coated enhanced polished trigger and hammer vs the standard trigger group on the anderson. if you're looking for the least costly option right now the anderson should work fine, but if you were going to update the trigger group and grip and trigger guard to what comes on the palmetto it would add up to more than the price difference plus you'll need to do the install.
Re: 300 Blackout pistol build [Re: Ammofirst] #4609918
12/21/17 08:49 AM
12/21/17 08:49 AM
Western usa
Western usa
Iím starting to see your point about the SB Tactical PDW brace. It looks like the best option. Itís just too bad about the cost. Iíll end up paying the same extra $200.00 I would for an SBR. At least thereís no 6 month wait & NFA paperwork.
Re: 300 Blackout pistol build [Re: Ammofirst] #4609960
12/21/17 09:34 AM
12/21/17 09:34 AM
Stallings, NC
Ryan Offline
Ryan  Offline
Stallings, NC
My friend did that same upper with a Shockwave blade. He loves it. No issues with the gun. Iím thinking about doing the same upper. PSA has an MOE plus EPT lower kit that I want to use to build my lower, but itís out of stock. Itís basically the lower parts kit, minus the buffer tube, spring and stock, but it has the overmold grip, and enhanced polished trigger.
Re: 300 Blackout pistol build [Re: Ammofirst] #4609981
12/21/17 09:47 AM
12/21/17 09:47 AM
Western usa
Western usa
They both get rave reviews. The SB unit is just bigger & maybe easier to adjust. This stock vs brace issue is really a distinction without a difference. ATF should not even be in the loop. Their job is to enforce the law not write it.
Re: 300 Blackout pistol build [Re: Ammofirst] #4610691
12/21/17 10:46 PM
12/21/17 10:46 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
You need to proceed VERY carefully. If you bought the lower in your original post,you are then in possession of an unregistered short barrel rifle, looking at 10 years in federal prison.
You would be much better off buying exactly what you want, up front.
The receiver extension cannot have any holes in it (6 position) to mount a regular stock. It needs to be a specific pistol extension only, that can mount a slide on kak pistol "stabilizer".
Why .300 blk? Expensive ammo, won't get much use. Get a 5.56 unless you have a .30 cal supressor.
And dont possess that short barrel upper before you buy the pistol lower. You want to be in possession of the lower before you take possession of the upper, especially considering you already have other AR rifles.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
Re: 300 Blackout pistol build [Re: Ammofirst] #4610793
12/22/17 01:19 AM
12/22/17 01:19 AM
Western usa
Western usa
Thanks for the input. Havenít purchased anything yet. Anybody else tried the brace shown with this lower ? http://palmettostatearmory.com/psa-ar-15...-516446451.html
