Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
ariefnrst, tcoffin014, Schm1d, EagleC, Dinka
66655 Registered Users
89 registered members (Blkstanger, BigShug681, badtlc, aquariuscsm, bfleeman, 10 invisible), 1,587 guests, and 37 spiders.
Topics294,970
Posts4,925,091
Members66,655
Most Online2,553
Oct 27th, 2018
2003 Suburban Ride Height and tires #4609347
12/20/17 01:40 PM
12/20/17 01:40 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
Not sure if this is the right topic forum location.
I have a 2003 Suburban 1500 with 16" rims. I have the ZW7 suspension package.
I am looking to increase ride height to increase my clearance between the bottom of my tow hitch and the ground.
Options I am looking at:
1) Bigger tires on 16" rims
2) Bigger rims and tires
3) 2"-4" coil spring and torsion bar lift kit with bigger 16" tires.
Any input that would not sacrifice ride quality and allow me to use my existing Nivomat rear shocks? Shocks are self adjusting load leveling (but not air ride>
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609467
12/20/17 04:22 PM
12/20/17 04:22 PM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
According to Tire Guides, A 2003 Suburban came with P265/70R16's on 7" wheels. Assuming there is enough room (I know of no one who publishes a guide as to how big the fenders are, but there is likely room for at least 2 steps in size), then you can go as large as P265/75R16 or P275/70R16 - that's a single step. There are more options in LT's but those are going to hurt the ride.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609485
12/20/17 05:02 PM
12/20/17 05:02 PM
Maryland USA
rubberchicken Offline
Maryland USA
Anything changing the tires outer diameter to get more clearance will alter the effective gear ratio, which is something you may not want. What about a different hitch, draw bar etc ? etrailers.com is a good site for info.
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609496
12/20/17 05:18 PM
12/20/17 05:18 PM
iowa
Traction Offline
Traction  Offline
iowa
The brakes are already marginal on those vehicles, and a taller, heavier tire is not going to help, including acceleration among other things, like handling. A 265/75-16 would be the best option. 285's would be max, but should on an 8 inch wide wheel.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609497
12/20/17 05:22 PM
12/20/17 05:22 PM
Cincinnati, USA
Dave9 Offline
Dave9  Offline
Cincinnati, USA
What height increase do you "need"? What height increase do you "want"?
AFAIK, you can't keep using the Nivomat rear shocks with a spring lift, would have to increase height with larger tires or both tires and wheels which as rubberchicken mentioned will alter gear ratio, which unless geared lower than needed already, will not be optimal for towing.
Any option will sacrifice ride quality, though this depends on what ride qualities you prefer. The least impactful for handling would be larger wheel diameter instead of taller tire sidewalls on the existing 16" rims, but of course the highest cost both for buying the rims and the larger diameter tires, specifically in a size for larger diameter rims. You also can't go much larger in tire size without wider than 7" rims. Well maybe someone makes an oddball size like that.
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609521
12/20/17 05:48 PM
12/20/17 05:48 PM
wv
krismoriah72 Offline
wv
I have the same vehicle..mine is a Z71. A useful forum if you should need it is at http://z71tahoe-suburban.com/iboard/
I dont want to oversimplify things but why dont u get an adjustable hitch? pic below is from amazon.
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609536
12/20/17 06:03 PM
12/20/17 06:03 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
I appreciate all the input,
I am a little confused, since I have seen the same vehicle as mine with 17" rims and larger tires. I am not sure about the Z-71, but I thought those were also on 17" rims.
Are the Z-71 and other similar suburbans possibly a different drive train package to accommodate bigger rims and tires?
So with regards to the towing performance and gear ratios, I appreciate that and do not want to change if it will have an adverse effect on the vehicle and would probably just use an offset hitch, but to get the clearance I need for pulling my boat out at ramps, I will need about an 8"-10 rise...seems like a lot.
I am due for new tires and wanted to consider options before just replacing with stock size. They also look under-scaled for such a big vehicle.
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609586
12/20/17 06:59 PM
12/20/17 06:59 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I'm not understanding 8-10" of rise, that's crazy talk. Is that to make it pull level or? What are the conditions here?
It'll probably clear 285/75-16 tires with a suspension lift, take some measurements first to make sure there's room from lock-to-lock. Power will go down slightly with larger tires and the speedometer will be slightly off, but likely not enough to be drastically different.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609806
12/20/17 11:59 PM
12/20/17 11:59 PM
Maryland USA
Maryland USA
I have a 1997 Suburban, 2500, 454 4x4. A couple of points: There were a crazy number of gear ratios available in that Suburban platform. At least 2 on the 1500, and 2 others in the 2500 with 454- 3.73 and 4.10. Not sure on your model which I think is the next generation Sub, but I expect the same availability of gear ratios. You would have to do some calculations to see the end result due to tire diameter changes. I have a Hyperchip programmer for mine (no longer use it though) that had an option to change the effective gear ratio due to tire and wheel changes, so that you could correct for speedometer errors. Thats really just a cosmetic change, but I would assume newer reprogrammers could easily do this.
On the boat trailer problem: perhaps if you could describe why you need the clearance in more detail, a different solution might become apparent. One example already cited was an adjustable drawbar for hight. Another might be a different drawbar but with higher ball mount. If you take the drawbar and rotate it 180 degrees, you can get a lot more height. Also, a longer drawbar might gain effective height while pulling up the ramp, but not a radical change while in normal trailering.
I call them drawbars, but perhaps ball mount is the correct term.
https://www.etrailer.com/Ball-Mount
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4609917
12/21/17 07:42 AM
12/21/17 07:42 AM
wv
wv
Mine had 17 inch rims when i got it but they were pitted and looked horrible and the tires were worn out. I already had a set of new 16" tires so i went with 16 inch rims (soft8) to match the government look. 245/75/16 on mine.
As for your need for 8 to 10 inch lift..no clue what to tell u there..
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4610074
12/21/17 10:24 AM
12/21/17 10:24 AM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
Regarding lift height:
My expedition is 17" ground to bottom of tow bar with a 7" more rise on hitch. That is about the least height I can have to tow my boat out of most ramps without the trailer cross member bottoming out at the apex of the ram.
The Suburban is 13" ground to bottom of hitch and the hitch is below the bumper (chrome bumper with license plate mounted in recess of bumper). It seems like the newer models have tow bar incorporated into the plastic bumper giving more ground clearance.
Regarding purpose:
80% to increase hitch height and ground clearance, 20% to improve the look, tires look too small on vehicle.
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4610317
12/21/17 02:26 PM
12/21/17 02:26 PM
Southeast
meep Offline
meep  Offline
Southeast
8"-10" rise will require a seriously-fabricated lift kit, and you will inherit the issues common with lifts - driveline vibes from shaft angles, limited suspension support from mechanics, vulnerability with stressed components, and loss of handling. That, and the vehicle will take on an image you may or may not want.
If the rear is sagging with the load, you can change tires, which compromise handling, add a lift, which will vary based on the kind of lift, add a helper spring, different spring, or air spring, which either stiffens the ride or requires at least a little care (air springs, or you may be able to reduce the tongue weight of the trailer if it's not proper. You need 10-15% of the trailer weight on the tongue.
In other words, unless something is just set up wrong, you're not going to get 8" of lift without significant investment and work. You might want to find a better-built boat ramp.
2018 F150
2015 crv (wifey!)
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4610326
12/21/17 02:39 PM
12/21/17 02:39 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
The problem is probably the loading dock at the lake. Is there another loading dock on the other side of the lake that doesn’t have as much dip?
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4610329
12/21/17 02:43 PM
12/21/17 02:43 PM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Get an adjustable hitch and add some sacrificial metal on the tongue of the trailer if it still grinds.
07 Focus ZXW, 5spd manual, 218km M1 5W30
18 Outback 2.5 CVT 15km 0W20
Re: 2003 Suburban Ride Height and tires [Re: Fitz98] #4610457
12/21/17 05:39 PM
12/21/17 05:39 PM
Florida
Fitz98 Offline OP
Fitz98  Offline OP
Florida
All I really want is 2-3" more lift to bring it to the same hitch height as my Expedition.
I can use an offset hitch ball to get the rest.
Larger tires and or rims might make them look a little more to scale with the vehicle size.
With all the potential problems and compromises, I may just stay with stock tires and rims and use a bigger offset/rise on hitch ball.
Thanks for all the feedback, I was hoping to hear that 17" rims with larger tires and/or a 2" lift would be a good solution to get another 3" ground clearance, but doesn't appear that way, without compromising the ride and or handling.
