Originally Posted By: Speak2Mountain
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/01597AB5857A941F8025814E00388823/$File/BPXE-ANWVMT.pdf11.1 Noack...meh
Not the same oil there you cited. This new stuff is VW 508/509 approved, and the "LL IV FE" name sounds and looks similar to BMW's 0w20 LL 14 FE (aka, it could be BMW "LL XIV FE"...) spec, but not the same of course in this case. Just VW specs here.
I guess some of the above posters are assuming the VW 508/509 0w20 is the same stuff as Castrol's other SN GF-5 0w20, but this is probably slightly upgraded from that.
What's interesting is VW has now followed BMW into 0w20 territory. Inevitable I guess.
Here is the correct basic spec sheet:
https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/42BECEC5087FDB8D802580DC0066C8C9/$File/BPXE-AKE6LY.pdf
Notice Pour Point dropped about 20 degC, so, yes, this LL IV FE formula probably uses more PAO in the base oil to get that.
