White or milky cloud in engine oil when cold
by OilUzer. 01/20/19 02:08 AM
Karma Kruiser!
by ekpolk. 01/20/19 01:36 AM
2018 Mazda 3 SkyActive 2.0
by wolf_06. 01/20/19 12:41 AM
Kendall nitro 70
by Bullwinkle007. 01/19/19 11:11 PM
Dexron HP
by Snagglefoot. 01/19/19 11:11 PM
Ruger American 22 Mag
by TiredTrucker. 01/19/19 11:06 PM
Prestone Dex Cool vs Carquest Dexcool
by A_User55555. 01/19/19 11:05 PM
FRAM end cap differences EG and TG vs XG
by wemay. 01/19/19 09:25 PM
Valvoline modern Engine
by Pinoak. 01/19/19 09:02 PM
30 Vintage Photos
by StevieC. 01/19/19 08:23 PM
Low mileage, when to change oil?
by Metfanant. 01/19/19 08:05 PM
Filter with bypass when OEM has built-in bypass
by rubberchicken. 01/19/19 07:43 PM
Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
dougway, Jetsfan421, Fordman420, 72sbc, ejmiller
66982 Registered Users
31 registered members (billt460, claluja, c502cid, Cornershop, carlprop, 4 invisible), 840 guests, and 30 spiders.
Topics296,866
Posts4,960,379
Members66,982
Most Online2,688
Jan 19th, 2019
AGM Batteries 12.8 or 12.9v instead of 12.7 ?? #4608804
12/19/17 09:10 PM
12/19/17 09:10 PM
Midwest USA
LoneRanger Offline OP
Midwest USA
"The sealed AGM and gel cell battery voltage (fully charged) will be slightly higher in the 12.8 to 12.9 range"
https://www.batterystuff.com/kb/articles/battery-articles/battery-basics.html#3
I thought there was no diff between flooded wet cells and absorbed glass mat (AGM) on parked engine and parasitics off, charge shown on the multimeter.
'09 Subaru Forester ...................(QS HM 5W30)
'16 Moto Guzzi Stelvio 1200 .....(ENI i-Ride PG 10W60)
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4608819
12/19/17 09:21 PM
12/19/17 09:21 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Nah the AGM batteries will having a higher open voltage than a comparable flooded battery being both are truly 100% state of charge.
Nissan Altima 3.5 Coupe
Mobil Super 5w30 Wix 57356
"Treat your family like your friends and treat your friends like your family."
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4608822
12/19/17 09:22 PM
12/19/17 09:22 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Yes, this is true, they have a higher OCV. They also prefer a higher charging voltage.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4608957
12/20/17 05:07 AM
12/20/17 05:07 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
A fully charged lead-acid battery will show 2.2V per cell (6.6V on a "6 Volt" battery and 13.2V on a "12 Volt" battery).
The 12.7~9 V/AGM reading they refer to in the OP's article is after a load has drained part of the charge.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4608995
12/20/17 06:07 AM
12/20/17 06:07 AM
Midwest USA
Midwest USA
Wouldn't 13.2v be the initial surface charge which bleeds off few minutes after removing a charger/maintainer, and the AGM battery then settles at 12.9?
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4609179
12/20/17 09:50 AM
12/20/17 09:50 AM
MURICA
maverickfhs Offline
maverickfhs  Offline
MURICA
Usually I have seen AGM stays between 12.75-13V. My current Yuasa AGM, stays at 13V even after a few days tender is removed, measuring from cheap HF multimeter though.
While lead acid ones I have seen between 12.4-12.6 after it has been fully charged, and tender is removed. These voltage varies based on the age of battery too.
All for motorcycles.
2006 Civic EX 205K/AT
2006 Acura TSX 187K/AT
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4609187
12/20/17 09:57 AM
12/20/17 09:57 AM
Illinois
SHOZ Offline
SHOZ  Offline
Illinois
The specific gravity of the electrolyte is higher in AGMs than a flooded battery. That is most of the gain in voltage.
Usually in the 1.315 range when finished and fully charged.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: AGM Batteries 12.8 or 12.9v instead of 12.7 ?? [Re: LoneRanger] #4609233
12/20/17 11:05 AM
12/20/17 11:05 AM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
The AGM banks in our trucks when properly charged settle out at 12.8 to 12.9. We basically charge at 14.7 and float at 13.8 on the charger, alternators temp compensate and will run between 13.5 and 14.9.
HDEO in Diesel Engines. No spark plugs here.
