Here's my fram filter at least 18 thousand miles
by Ablebody. 09/19/18 11:31 AM
How much is my truck worth?
by wallyuwl. 09/19/18 09:56 AM
Looking for Spray Detailer Advice
by knerml. 09/19/18 09:51 AM
LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
85 registered members (Ablebody, ad244, 2013ecof150, 28oz, ABomb369, 2010Civic, 8 invisible), 1,661 guests, and 46 spiders.
Topics290,664
Posts4,847,882
Members66,011
Most Online3,590
Jan 24th, 2017
How do these spark plugs look? #4608383
12/19/17 04:00 PM
12/19/17 04:00 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
Finally got around to doing the plugs and leaking valve cover gaskets on my Infiniti. Here are a couple of the plugs. I presume they are the original ones. What does the white crust mean?
2018 Hyundai Elantra VE -- 4K
2013 Honda Pilot EX-L 4WD -- 56K
2002 Honda Accord EX-L -- 211K
Re: How do these spark plugs look? [Re: mclasser] #4608388
12/19/17 04:08 PM
12/19/17 04:08 PM
West Ma.
rollinpete Offline
rollinpete  Offline
West Ma.
looks like running hot, burning oil?...
Then again if there originals that's a lot of miles...
Pete.
97 Ford Expl.Sport 4.0 ohv 4wd 5spddrive184k miles
Last Change;
Penn. Plat. HM. 5w30
Fram xg8a, Fram CA8141
I like my oil (slippery).
Re: How do these spark plugs look? [Re: mclasser] #4608394
12/19/17 04:10 PM
12/19/17 04:10 PM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
The reason it is called "SPARK" plug is because it is sparking fire.
So, the white crust is the carbon ash created because it is essentially burning the tip.
Sort of like you light up a charcoal for bbq, the burnt surface shows white ashes.
Better replace it if you are working on it for something that cost very little in the grand scheme of a car maintenance.
Plus it will save you some gas.
  • 2017 Toyota Sienna
Re: How do these spark plugs look? [Re: mclasser] #4608403
12/19/17 04:19 PM
12/19/17 04:19 PM
SSP mn
hansj3 Offline
hansj3  Offline
SSP mn
the white ash is par for the course. nothing to worry about. in my aoa the ash can be red in color.
as far as the life of the plug, the pad on the ground strap is still intact, and although the electrode is rounded over, dimensionally its still probably in spec.
id change them as a p.m. item, but I could easily see them racking up more miles
Re: How do these spark plugs look? [Re: hansj3] #4608412
12/19/17 04:32 PM
12/19/17 04:32 PM
wv
krismoriah72 Offline
wv
I just peeked at my mothers 2008 honda accord plugs at 50K miles, they looked brand new but were Denso Iridiums. No white ash, just a light discoloration.
I would say you got your moneys worth out of yours but they probably have some life left. If you plan on keeping it I would put another set in..
Re: How do these spark plugs look? [Re: mclasser] #4608427
12/19/17 04:47 PM
12/19/17 04:47 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
It's burning oil.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: How do these spark plugs look? [Re: mclasser] #4608443
12/19/17 05:02 PM
12/19/17 05:02 PM
toronto
PeterPolyol Offline
PeterPolyol  Offline
toronto
Agreed. That looks like SAPS ash.
Re: How do these spark plugs look? [Re: hansj3] #4608446
12/19/17 05:05 PM
12/19/17 05:05 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
The red is from octane booster.
The ash on OP's plugs are from burning oil. Ash is not normal. Those plugs are WAY past due.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: How do these spark plugs look? [Re: mclasser] #4608450
12/19/17 05:12 PM
12/19/17 05:12 PM
CA
The Critic Offline
The Critic  Offline
CA
Those plugs are super duper worn out!
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: How do these spark plugs look? [Re: Silk] #4608532
12/19/17 06:34 PM
12/19/17 06:34 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Silk is spot on here. It is burning oil.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: How do these spark plugs look? [Re: mclasser] #4608547
12/19/17 06:47 PM
12/19/17 06:47 PM
VA
thastinger Offline
thastinger  Offline
VA
Those things look sad. Whatever the mileage of this change, I would 3rd it.
Re: How do these spark plugs look? [Re: mclasser] #4608637
12/19/17 08:07 PM
12/19/17 08:07 PM
Maryland USA
rubberchicken Offline
Maryland USA
They have 130k miles on them- I think they are in the condition to be expected. Given the amount of miles, I would not pronounce an oil burning condition just based on the plugs.
Re: How do these spark plugs look? [Re: rubberchicken] #4608648
12/19/17 08:15 PM
12/19/17 08:15 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Ahh yeah I would actually. Oil burning creates that type of ash around the used plug. It's obvious that it has been burning oil. I'd bet $20 against your $1 that the other Bank of spark plugs without the valve cover leak look rather good and without the white ash burned on to them.
I've seen others on here post pics of plugs with the same amount of miles with zero Ash burnt on the plugs. Those plugs were clean with zero deposits on them anywhere. In fact some of them looked good enough to run longer in addition to the 125k to 140k miles those plugs had already run.
Ohh and very good story you posted on that other thread about the car story. That was really crazy.
Re: How do these spark plugs look? [Re: mclasser] #4608652
12/19/17 08:17 PM
12/19/17 08:17 PM
The Northeast
mclasser Offline OP
mclasser  Offline OP
The Northeast
OP here. Yes, I installed new OEM plugs. So the white crust indicates running hot/burning oil? Interesting. This doesn't surprise me since early VQ35 engines are known oil burners.
Re: How do these spark plugs look? [Re: mclasser] #4608656
12/19/17 08:20 PM
12/19/17 08:20 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Hey Mclasser we're both valve cover gaskets leaking oil?? Or just one side only??
