G GGorman04 Joined Nov 27, 2011 Messages 430 Location pennsylvania Dec 19, 2017 #1 Boring subject but necessary for the home. What do you guys recommend for the home? Thanks in advance
P pda1122 Joined Sep 22, 2005 Messages 363 Location New England Dec 19, 2017 #2 Well I furnished my boat and home with the recalled kidde brand with the plastic handle...so not those.....
G GGorman04 Thread starter Joined Nov 27, 2011 Messages 430 Location pennsylvania Dec 19, 2017 #3 I was surprised by how much Home Depot wanted for the ones they sell.
P pda1122 Joined Sep 22, 2005 Messages 363 Location New England Dec 19, 2017 #4 Try Walmart. The recalled ones SHOULD be off the shelf.
4 440Magnum Joined Feb 1, 2009 Messages 8,856 Location Texas Dec 19, 2017 #5 The modern "clean agent" extinguishers if you can afford them. Highly effective, and far less corrosive if you can't immediately clean it up.
B brslds Joined Oct 13, 2014 Messages 114 Location US Dec 19, 2017 #6 Do you have special circumstances? Call it a day and get a 10lb ABC rated extinguisher from wally world. One for the kitchen and garage. Do you have an upstairs? One up there in a good location too.
E E150GT Joined Mar 11, 2012 Messages 1,983 Location San Antonio, TX Dec 19, 2017 #7 I would stay away from the cheapies. I like the all metal Amerex ones. Never had to use one but I bet it will work if I need it.
G GGorman04 Thread starter Joined Nov 27, 2011 Messages 430 Location pennsylvania Dec 19, 2017 #8 No special needs other than protection for the what-ifs in this world?
M mattwithcats Joined Jun 13, 2013 Messages 3,084 Dec 19, 2017 #9 A 4A, 60BC, or larger, is what I prefer... 1A 10BC put out a toaster sized fire, a 4A 60BC, a microwave size... https://www.homedepot.com/p/Kidde-PRO-460-4A-60B-C-Fire-Extinguisher-21005785/100566451 Last edited: Dec 19, 2017
L Linctex Joined Dec 31, 2016 Messages 10,144 Location Waco, TX Dec 19, 2017 #10 Originally Posted By: mattwithcats A 4A, 60BC, or larger, is what I prefer... At least ONE somewhere in the home or attached garage, is really needed. A small 10BC is good for small fires. A 60 BC is what you run to GO get after the 10BC is empty.
L Linctex Joined Dec 31, 2016 Messages 10,144 Location Waco, TX Dec 19, 2017 #11 Originally Posted By: pda1122 Well I furnished my boat and home with the recalled kidde brand with the plastic handle...so not those..... I have NEVER had one fail, and have used several. The recall doesn't phaze me - use with confidence.
64bawagon Joined Jan 10, 2017 Messages 1,419 Location Michigan Dec 19, 2017 #12 I had 2 old Kidde plastic head 10BC that I sent back and got replaced at zero cost, one of them was over 30 yrs old.
X xxch4osxx Joined Mar 11, 2009 Messages 2,995 Location Cedarbrae, Ontario Dec 19, 2017 #13 I have an Amerex 10lb and 5lb in the house. An Amerex 2 1/2lb Halotron in each vehicle. A First Strike 10lb CO2 and an Amerex 20lb in the shop.
