VW Passat R36 504 00/ 507 00 oil
by antik. 03/23/19 04:43 AM
Oil for 2015 Ford Explorer
by oilnut12. 03/23/19 12:48 AM
Blains farm and fleet citgo syn
by BTLew81. 03/22/19 10:48 PM
2003 Duramax 208, XXX miles Rotella T4
by TurboJW. 03/22/19 08:11 PM
Turn signals on the freeway?
by das_peikko. 03/22/19 08:05 PM
Running Boards Restored
by kstanf150. 03/22/19 07:38 PM
QSUD at Canadian Tire
by Snagglefoot. 03/22/19 07:29 PM
Camry vs Accord vs ???
by Joe1. 03/22/19 07:26 PM
Fire up
by Matagonka. 03/22/19 07:16 PM
Mobil-1 AFE Discounted at Sam's Club
by ekpolk. 03/22/19 06:20 PM
Test drove a Tesla Model 3
by y_p_w. 03/22/19 05:54 PM
Did i make a mistake? Hilux 3.0 d4dhello
by Anton93. 03/22/19 05:52 PM
WM Valvoline Full Syn Modern Eng Clearance
by Spartanfool. 03/22/19 04:22 PM
Need Moly basic training
by Bill_W. 03/22/19 04:03 PM
P0420 code goes away in warmer weather
by 2010Civic. 03/22/19 03:54 PM
Customer declined new belt
by Chris142. 03/22/19 03:13 PM
How to deep clean back of wheels?
by qdeezie. 03/22/19 02:51 PM
RK oil sale T4 15w40
by 1978elcamino. 03/22/19 01:57 PM
duradick, Harold1031, Skendread, NGK, Thomas1
67589 Registered Users
36 registered members (BobFout, AurionX2, 4WD, CB900F2, bubbatime, Burks21, 5 invisible), 647 guests, and 58 spiders.
Topics286,267
Posts4,905,527
Members67,589
Most Online2,967
Mar 10th, 2019
Buzzing oil filter housing! #4608051
12/19/17 10:54 AM
12/19/17 10:54 AM
London
alexanderfitu Offline OP
London
Hi all
Odd one on my V12 Mercedes. The oil filter housing has started buzzing randomly at idle.
The noise is quite loud. Can be heard at 30 seconds on the attached video:
https://www.youtube.com/watch?v=R5u3kvaY_9k
Oil is Shell Helix Ultra L 5W-40 and is approximately 500 miles old.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608081
12/19/17 11:22 AM
12/19/17 11:22 AM
New York
NoNameJoe Offline
NoNameJoe  Offline
New York
Have you used a mechanic's stethoscope to prove it is indeed coming from the housing? If not that should be your first step and may pinpoint the actual source.
Or a long handle screwdriver in a windshield washer fluid jug cut in half also works.
2015 Civic LX Coupe
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608082
12/19/17 11:23 AM
12/19/17 11:23 AM
London
London
Hi there
Yes indeed, I have used a stethoscope, its 100% coming from the oil filter housing.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608090
12/19/17 11:27 AM
12/19/17 11:27 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Fluttering bypass valve or ADBV? Only thing I can think of.
Ditch the filter to confirm.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608095
12/19/17 11:29 AM
12/19/17 11:29 AM
London
London
I think it may be bypass valve related but struggling to find its location on the parts catalogue.
Sorry, forgot to mention, new MB filter and O rings installed with no change.
I think next step is to measure the oil pressure....
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608098
12/19/17 11:31 AM
12/19/17 11:31 AM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Lots of engines produce extreme oil pressure pulses at different speeds, either because the oil pump puts out pulses, because various oil passages open and close as the engine turns, or (really) a combination of both. For example, the #4 cam bearing in Mopar v8s I work on "gates" pulses of oil to each bank's rocker shaft one at a time as it spins, and causes a noticeable dip in oil pressure when the passages line up for example, but every main bearing in virtually every engine design is also doing the same thing as the crank oil port aligns with the block oil port. Oil pressure gauges usually smooth those out unless you get an oil tube filled solid with oil on a mechanical gauge, in which case the needle just swings wildly and the gauge "sings" (ask me how I know...). So I can totally envision that a polymer or thin metal cylinder exposed to those pulses would 'buzz'. The real question is "why now and not before?" That's the only red flag for me- what changed, and is it a problem? Are you using a different oil filter cartridge? Did it get installed incorrectly? Is an O-ring missing, or is the ADBV not working right?
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Buzzing oil filter housing! [Re: 440Magnum] #4608105
12/19/17 11:34 AM
12/19/17 11:34 AM
London
London
Originally Posted By: 440Magnum
I agree. What changed!
Mercedes OEM oil filter a year ago.
Mercedes OEM oil filter this year.
Same oil as last year as well.... I replace the oil filter (and o rings) in case it was that but no change.
Copme to think of it, the only work I have done on the oil side is replace an O ring on the oil cooler thermostat as the old one was leaking. I wonder if this is causing a restriction until it opens up (max oil temp).
I suppose oil pressure measurement will indicate if this is the case.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608159
12/19/17 12:24 PM
12/19/17 12:24 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
It depends on the oil system. Some of them have so much going on that old school "watch the gauge" methods don't work well or at all. Some use the oil pressure sensor to vary the output of the oil pump and maintain a constant pressure... all well and good until something goes wrong and the system compensates and hides the issue until a major failure happens. Or, the sensor goes bad and the oil pressure shoots to max ("safe" mode) and throws a code :-/
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608170
12/19/17 12:34 PM
12/19/17 12:34 PM
London
London
Luckily this car is "dumb" A non variable oil pump and no oil pressure sensor in the system (which is stupid imo).
Just went out to satisfy my curiosity. 2 bar at idle @60 deg oil temp. So pressure isnt the problem.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608275
12/19/17 02:01 PM
12/19/17 02:01 PM
Texas
440Magnum Offline
440Magnum  Offline
Texas
Its not the problem IF that's pressure downstream of the filter. Also, "buzzing" could indicate the bypass valve is fluttering, and that's not something I'd like to have happening.
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608276
12/19/17 02:01 PM
12/19/17 02:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
L..... no oil pressure sensor in the system (which is stupid imo)
So much for "advanced" german engineering.... bop no-no
Re: Buzzing oil filter housing! [Re: 440Magnum] #4608278
12/19/17 02:03 PM
12/19/17 02:03 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I wouldn't worry - - it's lubricated well,
and as long as min oil pressure is established,
the engine isn't in jeopardy.
Re: Buzzing oil filter housing! [Re: Linctex] #4608283
12/19/17 02:09 PM
12/19/17 02:09 PM
London
London
Tell me about it.
Re: Buzzing oil filter housing! [Re: 440Magnum] #4608285
12/19/17 02:12 PM
12/19/17 02:12 PM
London
London
The oil test port is here:
In red.
Not sure if this is before or after the filter, looks probably before as oil will flow inwards from the outside of the filter media.
Ill pull the filter again tomorrow and take a good look down the housing neck to make sure there isnt a stray o-ring stuck in there etc.
Looking at this picture, I would say the test port is after the filter :
https://i.ebayimg.com/images/g/1TcAAOSw88NZ8DBy/s-l1600.jpg
https://i.ebayimg.com/images/g/xE8AAOSwZqZZ8DBw/s-l1600.jpg
Re: Buzzing oil filter housing! [Re: alexanderfitu] #4608638
12/19/17 08:08 PM
12/19/17 08:08 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Late in the R129/W129 life, Mercedes decided that their engines were so good that oil pressure monitoring was not nearly as necessary as knowing oil temp, so you would know when you could beat on it.
Oil temp gauge replaced oil pressure gauge.
